Picares F5J Langohr un fulg de 2 500mm
#241
Postat 13 February 2017 - 08:53 AM
De fapt ai destule si acolo, nu ai studiat matale indeajuns... astea doua sunt echivalentele graupnerului aici...
http://www.mountainm...php?cPath=25_28
http://www.skybench.....com/sloly.html
#242
Postat 13 February 2017 - 07:44 PM
#243
Postat 18 February 2017 - 11:42 PM
Aripa este gata. Completa, gata de zbor, are 172g. Este OK?
Sa nu radeti de mine, dar nu am mai avut spoiler. Pe ce buton, slider, etc, se pune deobicei?
Number of downloads: 36 -
Aceasta postare a fost editata de dan_mitea: 18 February 2017 - 11:47 PM
#244
Postat 18 February 2017 - 11:47 PM
Number of downloads: 30 -
Aceasta postare a fost editata de dan_mitea: 18 February 2017 - 11:48 PM
#245
Postat 19 February 2017 - 12:46 AM
dan_mitea, la 18 February 2017 - 11:42 PM, a spus:
#246
Postat 19 February 2017 - 08:57 AM
Tot nu pot crede greutatea aia...
De curiozitate, ce coarda ai ? Doar o coarda mai mica de 18 cm ar putea explica... oarecum :unsure:
#247
Postat 19 February 2017 - 06:58 PM
Eu zic ca este de la folie, aliphatic, balsa bine aleasa si proiect.
Aceasta postare a fost editata de dan_mitea: 19 February 2017 - 06:59 PM
#248
Postat 19 February 2017 - 07:12 PM
Totusi curios de ce pe net este data mult mai mare greutatea. E ceva acolo la voi in Canada, precis :) aerul mai rarefiat, care trage obiectele in sus :)
Aceasta postare a fost editata de renatoa: 19 February 2017 - 07:13 PM
#249
Postat 19 February 2017 - 08:16 PM
Asa, ca idee, ceilalti au folosit folia mea?
Cu spoilerul ramane cum a spus Stiganas?
Aceasta postare a fost editata de dan_mitea: 19 February 2017 - 08:17 PM
#250
Postat 19 February 2017 - 09:16 PM
#251
Postat 19 February 2017 - 10:15 PM
Am imbatranit, cred ca voi alege calea mai usoara.
Cum reactioneaza modelul cand ridic spoilerul? Trebuie sa ma astept sa actionez elevatorul, nu-i asa?
Nu am gasit un planor cu spoiler in RF sa experimentez.
#252
Postat 24 February 2017 - 05:14 AM
Number of downloads: 33 -
Aceasta postare a fost editata de dan_mitea: 24 February 2017 - 05:14 AM
#253
Postat 24 February 2017 - 08:12 AM
dan_mitea, la 19 February 2017 - 10:15 PM, a spus:
#254
Postat 24 February 2017 - 08:18 AM
Ca aparusera smecheri cu spoiler pe burta, si care il foloseau la lansare ca sa triseze :D
#255
Postat 24 February 2017 - 07:27 PM
Ma gandesc ca i-ar dezavantaja pe cei cu un spoiler pe mijloc.
#256
Postat 25 February 2017 - 07:11 AM
Number of downloads: 22 -
#257
Postat 25 February 2017 - 08:56 AM
Aceasta postare a fost editata de renatoa: 25 February 2017 - 08:56 AM
#258
Postat 25 February 2017 - 03:05 PM
#259
Postat 26 February 2017 - 03:34 AM
Number of downloads: 21 -
Number of downloads: 25 -
#260
Postat 27 February 2017 - 04:27 AM
Intrebare de o mie de puncte: ar fi complet ridicol daca as prinde, cu suportul sau de cauciuc, antena in aceasta pozitie? As fi mai confortabil, deoarece in interior am fire, receptorul, etc, etc si nu am gasit o solutie mai eleganta.
Intrebare si mai frumoasa. M-am capatat de ziua mea cu un printer 3D, nu foarte sofisticat, dar frumusel. Ce as putea face cu el pentru zburatoarele mele?
Number of downloads: 23 -
Aceasta postare a fost editata de dan_mitea: 27 February 2017 - 04:29 AM
#261
Postat 27 February 2017 - 09:45 AM
In toate cazurile, prin "antene" inteleg ca este vorba de antena Tx si unica antena Rx. Daca ai fi avut receptor cu 2 antene, atunci enunturile era valabile pentru antena Tx si oricare din antenele Rx
- daca sunt paralele este perfect
- daca sunt la 45 grade ai pierdere de 3 dB, adica 1.4x range, neglijabil la cei peste 2 km cat poate sistemul Hitec.
- daca sunt perpendiculare ai pierdere de 26 dB, adica range/8, nu mai e neglijabil... la 250-300m ai sanse mari sa pierzi semnalul
- daca sunt colineare, ai gaura neagra, pierzi semnalul poate si in 100m.
De aici ar rezulta ca o pozitie cu antena Tx la 45 grade atat fata de verticala si orizontala, dar si in fata, ti-ar fi cea mai avantajoasa daca ai pune antena pe model ca mai sus.
Atentie, 45 grade fata de sistemul de axe, nu fata de statie ! Deci unghiul asta va varia mult si din manipularea statiei si modul cum o tii inclinata.
Cu mentiunea sa ai grija ca niciodata sa nu iti vina modelul di lateral drept spre matale pe o directie de-a lungul axei antenei, ca intri in ultimul caz, si e nasol.
In mod normal nu ar trebui sa iti faci griji pentru ca ai telemetrie si vei fi semnalizat acustic cand incepi sa pierzi semnal si vei putea orienta statia in functie de pozitia modelului pentru cel mai bun unghi.
Sau nu ai ? :unsure: in cazul asta am scris degeaba, eu nu am intrat in 2.4G pana cand nu a fost disponibila telemetria, este o loteria taria semnalului in GHz daca nu o cunosti la sol. De asta nu ii inteleg pe cei care pentru 20 lei economie cumpara receptoare fara telemetrie...
Cu 3D printul... ai putea sa iti faci mana printan un suport dragalas pentru antena Rx :D
O variatiune dupa vreuna din cele listate aici:
http://www.thingiver...tenna+mount&sa=
Aceasta postare a fost editata de renatoa: 27 February 2017 - 09:50 AM
#262
Postat 27 February 2017 - 10:02 AM
Ii poti creea tu spoilere in editarea modelului fizic . In zbor nu le vei vedea grafic insa odata actionate se va simti in comportamentul de zbor .
Modele FPV
Piper-Wot4
Modelare 3D
Modele pt.simulator - RealFlight :
LazyBee;SpeedyBee;Aurora Scimitar;Sbach 342;BV 141;Heptad
#263
Postat 27 February 2017 - 07:33 PM
Am sa incerc sa vaz de sunt in stare sa fac ceva in RF-X.
Referitot la antena, intrebam daca este total de prost gust s-o pun afara, asa cum este in fotografie. Voi aseza antena de la radio la 45 de grade. Totusi, nu mi-e clar, antena de la receptor este, sau nu, omnidirectionala? Hitec asa se lauda. Ce inseamna, de fapt, acest lucru?
Aceasta postare a fost editata de dan_mitea: 27 February 2017 - 07:37 PM
#264
Postat 27 February 2017 - 08:37 PM
Radiatia maxima e imprejur, inelar.
Sigur nu e sferica, aia este antena ideala izotropica, de zero decibeli.
#265
Postat 28 February 2017 - 06:19 PM
dan_mitea, la 27 February 2017 - 04:27 AM, a spus:
Un exemplu ce mi-am printat pentru scos antenutele afara la un planor. Ce-i drept la Hitec nu va merge cu capetele groase, doar pentru idee.
Cum zicea si Renatoa, uite-te pe thingiverse.com, gasesti foarte multe trebusoare utile, multe RC related. Printeaza cat mai mult, piese simple dar si mai complexe pana te obisnuiesti cu jucaria noua si inveti ce si cum poate sa faca.
Apoi, pentru design de piese, daca nu ai experienta in 3d modelling, iti recomand www.tinkercad.com
Este un fel de soft de design, totul online, nu trebuie instalat nimic si este foarte simplu (ce-i drept si cam limitat) dar foarte util. Practic drag-and-drop modele de baza si le faci resize din oricare parte, cu alte forme le 'decupezi', lipesti, pana ajungi la ce ti-ai dorit.
Am pus destul de multe piese aici: https://www.rcgroups...arts-repository
Mai toate le-am facut in tinkercad.
10-22-2015 11-15-46 AM.jpg (88.58K)
Number of downloads: 12 -
#266
Postat 28 February 2017 - 07:38 PM
Am incercat sa ma conectez la softul online, dar crapa. Voi incerca acasa.
#267
Postat 28 February 2017 - 10:35 PM
dan_mitea, la 28 February 2017 - 07:38 PM, a spus:
Sau "ai putintica rabdare" si poti sa tiparesti avioane ....
daca te duci si descarci ultimele kituri de drivere/software de la Prusa (pentru Prusa i3 Mk2) vei avea surpriza sa gasesti fisierele de tiparire (format g-code.... deci nu modelul 3D in format STL) pentru Spitfire de la 3dPrintLabs.
Sau poti sa cumperi cu vreo 25 de dolari parca Kraga Kodo ...asta merge tiparit si pe imrpimante mai micute (format 15x15 cm).
Sau in curand voi avea posibilitatea sa modelez 3D cam orice fel de aripa si fuselaj .... ( e aproape gata, mai am cam o zi de lucru pentru modelarea spatiilor pentru servo, nu e mare smecherie dar am facut o "pauza" si construiesc acum de zor imprimante 3D).
Dar eu te sfatuiesc sa faci download de pe thingiverse la capatul de aripa Kraga kodo ... si sa incerci sa o tiparesti (o data, de doua ori...si sa incerci sa imbunatatesti procesul pina iti iese ceva utilizabil).
Si dupa ce ai gasit setarile perfecte de material / temperatura / suport / viteza de printare / flow (si o gramada de alti parametri) si poti tipari REPETABIL piesa care sa arate si bine si sa fie si rezistenta si sa o poti desprinde de pe patul de printare ...atunci poti sa treci la tiparirea unui proiect complet.
De exmplu... autorul lui Kraga Kodo zice ca piesa aia de test are cam 8 grame (tiparita cu PLA). Ultimele 4 bucati (tiparite zilele trecute) au 6.2 grame, 4.6 g, 4.4 g si 4.3 grame. si sunt tiparite cu ABS (mai usor, mai prelucrabil si mai rezistent decat PLA...si mecanic si termic).
Iar pentru proiectare 3D ... daca ai ceva cunostinte de programare iti recomand OpenSCAD.
#268
Postat 01 March 2017 - 09:57 AM
Si sa vezi atunci belea ca alifaticu nu mai lipeste PLA-ul... :p
#269
Postat 01 March 2017 - 02:05 PM
Ca sa-mi iert ratacirea electrica, am comandat si sambata il am, o bijuterie: Cox Queen Bee .074. Am primit deja si doua Norvel .074.
#270
Postat 01 March 2017 - 03:06 PM
