Modelism - RHC Forum: incarcator li-po,ni-mh,ni-cd,pb - Modelism - RHC Forum
incarcator li-po,ni-mh,ni-cd,pb 8s lipo,27cell nimh nicd, 36v pb
#1 Useril este offline   robert_801
  • Postari: 174
  • Inregistrat: 18-February 15
Postat 17 May 2016 - 09:30 PM
Incarcator acumulatori universal ,parametrii in descrierea de mai jos. Produs nou ,deschis doar pt. verificare.Pret 250 cu transport inclus.tel.0747875429
ECO8 150W 7A 8S Charger is capable of charging any capacity Lipoly battery up to 8 cells at 7A. It includes Auto current detect and temp, amp, voltage safety features to prevent over-charging. The ECO-EIGHT includes an array of charging plugs and wires to suit almost any application and comes with JST-XH balancing plugs so you can balance charge most packs easily.
Input power is 11-18v, so it can be powered by automotive batteries or a modified pc/laptop powersupply if you don't have a dedicated 12v power supply.
Features:
• Microprocessor controlled
• High power and High performance circuit with maximum power of 150W
• Delta-peak sensitivity (NiMH/NiCd)
• Individual cell balancing
• Li-ion, LiPo and LiFe capable
• Ni-Cd and NiMH capable
• Large range of charge currents
• Fast & Store function, allows safe storage current
• Time limit function
• Input voltage monitoring. (Protects car batteries at the field)
• Data storage (Store up to 10 packs in memory)
Spec.
Input Voltage: 11~18v
Circuit power: Max Charge: 150W / Max Discharge: 5W
Charge Current Range: 0.1~7.0A
Ni-MH/NiCd cells: 1~27
Li-ion/Poly cells: 1~8
Pb battery voltage: 2~36v
Weight: 574g
Dimensions: 170x110x35mm
Note: Requires external power supply.
#2 Useril este offline   robert_801
  • Postari: 174
Postat 03 June 2016 - 07:52 AM
UP , transport gratuit prin curier ,mai ieftin ca la HK !
#3 Useril este offline   robert_801
  • Postari: 174
Postat 13 June 2016 - 09:02 PM
UP
