Modelism - RHC Forum: Radiocomenzi - Modelism - RHC Forum
Radiocomenzi
#1 Useril este offline   Stavrica George Cristian
  • Postari: 734
  • Inregistrat: 14-August 08
  • Interests:Pescuit, Modelism
Postat 05 August 2015 - 09:02 AM
HobbyKing HK6S 2.4Ghz FHSS 6Ch Tx & Rx
Key Features:
6-channel 2.4GHz transmitter.
Servo reversing function .
Elevon and V-tail mixing available.
Features build-in antenna.
Easy to use control for basic models.
FHSS 2.4ghz Technology
Includes 6-channel receiver
Mode 2 (THROTTLE ON THE LEFT)
Included:
1 x 2.4Ghz transmitter
1 x 2.4Ghz Receiver
1 x Bind Plug.
Pret 290 lei
0722359121
Aceasta postare a fost editata de Stavrica George Cristian: 05 August 2015 - 09:02 AM
tel.0722359121
stavrica.george@gmail.com
#2 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 05 August 2015 - 09:06 AM
Turnigy TGY-i6 AFHDS Transmitter and 6CH Receiver
Features:
• Entry level 6 channel 2.4ghz radio with telemetry capability
• Dual Rate/Trims/Gear/Flap/Gyro Gain Adjust/Flight Mode/Throttle Hold/Hover Pitch Switches
• Easy to use Programming & Navigation Buttons
• Supports Heli/Standard Wing/Elevon/V-Tail
• 20 Model Memory
• 8 Character Model Name
• Trainer and charging ports
• Backlit LCD Screen displays real time transmitter and receiver voltage
• 4 Stick Mode Selectable
• Optional telemetry receivers and sensors available separately
Basic Programm Functions:
Dual Rates
Sub Trim
Travel Adjust
Channel Reverse
Swash Mix
Gyro Sensitivity
Throttle Curve
Monitor
Pitch Curve
Throttle Hold
Model Name
Timer
Turnigy TGY-i6 Transmitter Specs:
Frequency: 2.4ghz ISM Frequency Range
Modulation: GFSK
Spread Spectrum Mode: AFHDS 2A and AFHDS
Band: 142
Number of Frequency Channels: 20
Output Power: <=20dbm
Working Current: <=100mA
Working Voltage: 1.5v x 4 AA
Dimensions: 174x89x190mm
Weight: 392g
Resolution: 1024 bit
Stick Mode: Mode 2 (Throttle Left)
Turnigy iA6 Receiver Specs:
Channel: 6
Frequency: 2.4g ISM Frequency Range
Power: 4.5V~6.6V/<30ma
Net Weight: 6.4g
Dimensions: 40.4x21.1x7.35mm
Requires:
4 x AA Type Battery For Operation
Pret 320 lei
0722359121
Aceasta postare a fost editata de Stavrica George Cristian: 05 August 2015 - 09:11 AM
tel.0722359121
#3 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 05 August 2015 - 09:12 AM
Hobby King 2.4Ghz 6Ch Tx & Rx V2
Key Features;
6-channel 2.4GHz transmitter with servo reversing.
Trainer system option.
This system must be programmed via PC cable.
Included;
1 x 2.4Ghz Receiver
1 x Bind Plug.
Pret 230 lei
0722359121
tel.0722359121
#4 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 17 August 2015 - 04:42 PM
up
tel.0722359121
#5 Useril este offline   zaharia007
  • Postari: 7
  • Inregistrat: 16-January 14
Postat 18 August 2015 - 02:28 PM
Buna ziua ,vreau sa stiu ce raza de actiune are pe apa radiocomanda cu afisaj ?
Aceasta postare a fost editata de zaharia007: 18 August 2015 - 02:28 PM
#6 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 24 August 2015 - 04:20 PM
up
tel.0722359121
#7 Useril este offline   Mircea S.
  • Postari: 1
  • Inregistrat: 18-January 14
  • Interests:multi-rotor , fpv
Postat 26 August 2015 - 02:17 PM
Buna ziua,
Reciverul pentru HK6S il vindeti separat? si daca da,la ce pret?
Multumesc anticipat!
O zi buna
Aceasta postare a fost editata de Mircea S.: 26 August 2015 - 02:18 PM
#8 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 27 August 2015 - 02:13 PM
Va pot aduce. Momentan nu am decat seturi complete.
tel.0722359121
#9 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 11 September 2015 - 12:32 PM
up
tel.0722359121
#10 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 22 September 2015 - 11:27 AM
up
tel.0722359121
#11 Useril este offline   Doru Brad
  • Postari: 165
  • Inregistrat: 25-June 15
Postat 22 September 2015 - 10:24 PM
Receptor pt fs-t6 se poate aduce ? Daca da in cat timp si la ce pret ? Ms
#12 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 23 September 2015 - 09:18 AM
Se poate aduce.
tel.0722359121
#13 Useril este offline   flores2064
  • Postari: 13
  • Inregistrat: 30-June 14
Postat 14 October 2015 - 08:34 AM
Salut!
Ma intereseaza un receiver pentru HK 6S 6 canale.
Am înteles ca poti sa aduci. Te rog sa-mi zici cînd si la ce pret?
Multumesc.
Florin
#14 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 14 October 2015 - 12:22 PM
Pot sa aduc. V-am trimis pe privat detalii.
tel.0722359121
#15 Useril este offline   flores2064
  • Postari: 13
Postat 14 October 2015 - 02:49 PM
Multumesc!
La fel, detalii pe privat.
Cu stima,
Florin
#16 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 20 October 2015 - 11:10 AM
up
tel.0722359121
#17 Useril este offline   djkane
  • Postari: 10
  • Inregistrat: 15-March 15
  • Interests:Aeromodele, biciclete si acvaristica.
Postat 20 October 2015 - 06:13 PM
Buna seara.
Ma intereseaza daca puteti aduce receptoare pt Turnigy TGY-i6 AFHDS. ma intereseaza pretul cu si fara telemetrie.
O seara buna.
Sa aveti zboruri line.
#18 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 22 October 2015 - 08:16 AM
Pot aduce. V-am trimis mesaj privat.
tel.0722359121
#19 Userul este online   nicagabriel
  • Postari: 120
  • Inregistrat: 10-March 12
Postat 30 October 2015 - 10:17 AM
Vezi postareaStavrica George Cristian, la 22 October 2015 - 08:16 AM, a spus:
Doresc sa stiu daca puteti aduce un receptor pentru statia mea Futaba T4YF-2.4G (FHSS) si la ce pret ?
Multumesc anticipat !
#20 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 01 November 2015 - 09:43 PM
Buna seara,
Pot aduce. Va voi trimite mesaj privat.
tel.0722359121
#21 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 09 November 2015 - 12:18 PM
up
tel.0722359121
#22 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 17 November 2015 - 02:13 PM
up
tel.0722359121
#23 Useril este offline   DaniR
  • Postari: 33
  • Inregistrat: 02-July 15
  • Interests:aeromodelism
    navomodelism
    ciclism
Postat 17 November 2015 - 04:00 PM
Aduceti si LCD pentru Tgy-i6?
#24 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 08 December 2015 - 02:58 PM
up
tel.0722359121
#25 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 26 December 2015 - 07:21 PM
up
tel.0722359121
#26 Useril este offline   marianspy
  • Postari: 4
  • Inregistrat: 05-March 09
Postat 08 March 2016 - 10:08 AM
Va salut. Ma intereseaza si pe mine receptoare pt Turnigy TGY-i6 AFHDS. ma intereseaza pretul cu si fara telemetrie,speed controler 10-15 amp si microservo de 9gr.
#27 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 10 March 2016 - 05:31 PM
V-am trimis mesaj.
Cel mai bine sunati ca nu intru mereu aici si nu vad mesajele in timp real.
0722359121
tel.0722359121
#28 Useril este offline   Loredan
  • Postari: 16
  • Inregistrat: 03-March 16
Postat 19 March 2016 - 03:27 PM
Buna ziua. Aduceti receptor turnigy xr7000 fhss 7ch?
#29 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 29 March 2016 - 02:01 AM
Da, pot aduce.
0722359121
tel.0722359121
#30 Useril este offline   azabacher
  • Postari: 36
  • Inregistrat: 23-January 15
Postat 11 April 2016 - 06:17 AM
Poti aduce si receptorul pentrul HobbyKing HK6S separat? Daca da la ce pret si in cat timp ?
