Modelism - RHC Forum: Ajutor cu achizitia electronicii - Modelism - RHC Forum
#1 Useril este offline   Teomor
  • Postari: 1
  • Inregistrat: 09-January 16
Postat 23 March 2016 - 08:10 PM
Sunt incepator intr-ale aeromodelismului si de curand m-am apucat sa construiesc acest model (X-41 deltastorm): http://www.rcgroups....d.php?t=779331. As vrea sa imi cumpar electronica iar lista de materiale necesare este urmatoarea:
Motor Turnigy Aerodrive DST-1100:
Kv: 1100 rpm/v
Voltage:7.4~11.1v (2~3s)
No load Current: 1.0A
Max Current: 18A
Max Power: 170W
Shaft Size: 3mm
Shaft Length: 17mm
Dimension: 32.4mm x 30mm
Thrust: 750g
Weight: 65g
Turnigy AE-25A Brushless ESC:
Output: Continuous 25A, burst 35A up to 10 seconds.
Input Voltage: 2-4 cells lithium battery or 5-12 cells NIMH battery.
BEC: Linear 2A @ 5V
Control Signal Transmission: Optically coupled system.
Max Speed:
2 Pole: 210,000rpm
6 Pole: 70,000rpm
12 Pole: 35,000rpm
Size: 50mm (L) * 26mm (W) * 12mm (H).
Weight: 25g.
ZIPPY Compact 2200mAh 3S 25C Lipo Pack:
Capacity: 2200mAh
Voltage: 3S1P / 3 Cell / 11.1V
Discharge: 25C Constant / 35C Burst
Weight: 163g (including wire, plug & case)
Dimensions: 107x21x34mm
Balance Plug: JST-XH
Discharge Plug: XT60
TGS Precision Propeller 6x4 Black
HXT900 Micro Servo 1.6kg / 0.12sec / 9g
Turnigy iA6 Receiver 6CH 2.4G AFHDS 2A Receiver:
Channel: 6
Frequency: 2.4g ISM Frequency Range
Power: 4.5V~6.6V/<30ma
Net Weight: 6.4g
Dimensions: 40.4x21.1x7.35mm
Turnigy TGY-i6 AFHDS Transmitter and 6CH Receiver (Mode 2)
Channel: 6
Net Weight: 6.4g
Prima intrebare este: am un incarcator ca cel din poza:
https://drive.google...jM4UkQ1VEE/view
Este compatibil cu acumulatorul pe care vreau sa il iau?
A doua intrebare: motorul, ESC-ul si acumulatorul sunt compatibile intre ele, mai am nevoie de adaptori/conectori, etc?
Va multumesc pentru ajutor.
#2 Useril este offline   gyany_eugen
  • Postari: 977
  • Inregistrat: 17-December 10
  • Interests:Electronica, IT
    Aeromodelism
Postat 24 March 2016 - 06:19 AM
Salutare si bine ai venit printre noi.
Referitor la incarcator, raspunsul este nu. Dupa cum arata mufa, cel din link pare a fi pentru acumulatori NI-Cd. Achizitioneaza un incarcator pentru lipo, cu egalizare. Incearca sa nu faci rabat la calitatea incarcatorului, va fi folosit foarte des.
Referitor la motor, pentru tipul de aeromodel care doresti sa il construiesti, KV-ul trebuie sa fie pe la 2200 cu elicie 6 x 4, 6 x 5. (motoarele cu KV mai mic merg cu elicie mai mare: 1100 KV - elicii de 9 - 10 inch)
Turnigy 9x -Er9x
#3 Useril este offline   Teomor
  • Postari: 1
Postat 24 March 2016 - 08:29 AM
Multumesc pentru raspuns. Intr-adevar, incarcatorul il am de la un acumulator NiCd. Trebuia sa-mi fi dat seama.
Aceasta postare a fost editata de Teomor: 24 March 2016 - 08:29 AM
