combustibil
Postat 06 February 2005 - 11:37 AM
am vrut sa vad ce combustibil recomanda hpi ptr rodaj...daca trebuie neaparat fara nitro...si iata ce spun ei:
Do I need break-in fuel?
We have not found any special properties or advantages of using these break-in fuels. We use and recommend regular fuel to break in engines, using the same nitro content and brand fuel that we will run in the engine when racing.
Dupa asta m-am intrebat de ce recomanda combustibil cu 20 % nitro..oare cum merge fara nitro etc...
Fuel
What kind of fuel should I get?
We recommend a high-quality, brand name fuel made especially for cars. Model fuels for airplanes or helicopters will not work properly and will ruin your engine. HPI Power Fuel is available in both quart and gallon sizes for the hobbyist (in 20% nitro content) or the serious racer (30% nitro content).
Deci recomanda 20 % nitro..iar ptr curse se foloseste chiar 30 %...dar de ce asa mult..am cautat informatii si iata ce am gasit:
This is an “It depends who you ask†question; in fact, no fuel is ideal for every application. Nor is it a given that a higher percentage of nitro results in better performance. The correct percentage of nitro and its effects on engine performance are rather complex issues, but I'll try to cover the basics. To understand how nitro content affects engine performance, it helps to have a basic understanding of nitro. A derivative of propane, nitro can be considered an oxygenator; suitable as a fuel by itself, it carries its own oxygen component. Nitromethane contains nitrogen and oxygen, which provides more “fuel†for the combustion process; more oxygen allows more fuel to be burned in the same amount of space. More fuel plus more air typically equals more horsepower—much like the benefits a turbocharger or supercharger give a full-size car engine. There is a great deal more technical complexity to nitromethane, but this explains why you can produce more power with it.
NOW, HOW MUCH NITRO SHOULD YOU RUN?
Maximum performance means an engine is running at maximum efficiency with maximum horsepower. The bottom line is that using high-nitro fuel that far exceeds the parameters of your engine may only net a slight gain in horsepower, but overall performance is compromised; so, more isn't necessarily better where nitro content is concerned.
When engineers design an engine, one of their primary considerations is the type of fuel to be used. The compression ratio and the timing and duration of the intake and exhaust ports take fuel composition into consideration. For example, Fedération Aeronautique Internationale engines—popular in model airplane competitions—are designed to run on pure methanol. The competition rules specify that fuel must not contain nitro. Adding nitro to the fuel used in these high-compression engines usually results in poor performance and high running temperatures.
Similarly, RC car engines are designed to run with a certain percentage of nitromethane. An engine designed to run on fuel with 20 percent nitro is configured for a certain compression ratio and a fuel/air ratio that provides ideal performance. Introducing a considerably higher concentration of nitro allows a greater overall amount of fuel volume. It can result in higher compression (air is the only compressible component in the fuel mix), detonation (when fuel explodes rather than burns) and higher operating temperatures. These outcomes show the fuel exceeds the design limitations of the engine. Even if none of these symptoms are patently obvious, combustion is compromised, and that prevents fuel from being completely burned. It can create an unstable idle and erratic fuel-mixture settings. These conditions are common in engines running on higher than recommended percentages of nitromethane. Essentially, the answer to the “How much nitro?†question is that you should follow the engine manufacturer's recommendations.
There is a “window†of about 5 percent both above and below the recommended percentage of nitro you can have in your fuel before engine performance will be noticeably affected. If a manufacturer recommends 20 percent nitro, you can get away with 25 percent. Go beyond that, and you are likely to wind up with an engine that runs hotter, gets poor fuel economy and is more difficult to tune. If your engine's manufacturer doesn't recommend a specific percentage of nitro, you may have to experiment to establish the proper balance of horsepower and efficiency.
Postat 06 February 2005 - 12:01 PM
spunea tot acolo ca adaugarea de nitro in aceste "high-compression engines" normal cauzeaza slabe performante si temperaturi mari ale motorului...asta ar veni in contradictie cu producatorul care recomanda 20% nitro dar....
deci din cate am inteles nitro are rolul de a oxigena combustibilul...si in felul acesta arderea va fi mult mai buna...si e si un surplus de combustibil...
deci daca producatorul recomanda 20 % nitro...inseamna ca acest motor e proiectat sa mearga in conditii
optime cu 20 % nitro...poate merge si cu 0 sau 5 % nitro...dar asta ar insemna ca nu mai merge motorul la parametrii optimi de functionare ....
Postat 09 February 2005 - 10:04 PM
...si era 30.000 litru, pai daca merge este o adevarata afacere ca nu mai stau sa dau 1,3 mil pe 5 litri :D
Postat 10 February 2005 - 12:40 AM
Nu nu poti.
Singurul lucru care il vei face este acela ca vei strica uleiul de ricin si eventual nitro (daca pui),degeaba.
Mai bine cumpara combustibil gata facut ca si asa dai un pret destul de bun. Iti dai seama ca daca era bun se folosea demult.In primul rand ca alcolul etilic nu arde la fel de puternic ca alcolul metilic.Sunt multe de zis.
Deci nu incerca ca nu faci nici o afacere decat eventual pagube.
Postat 10 February 2005 - 12:51 AM
PS. Nu vreau de la masina performante, vreau fun si fun nu este atunci cand strang din buci 2 luni sa cumpar 5 litri http://www.rhcforum....tyle_emoticons/default/mad.gif
Aceasta postare a fost editata de Tal-u: 10 February 2005 - 12:53 AM
Postat 10 February 2005 - 02:33 AM
Mai incearca poate reusesti vreo reteta d ecombustibil ieftin.La masininile mari ca s ascape d ebanzina scumpa au trecut pe gaz.......................acuma tu pe ce vrei sa treci? eventual poate iti faci o instalatie de gaz care iar nu cred ca va merge dar incercarea moarte nu are.................................moare cine incearca... http://www.rhcforum....tyle_emoticons/default/laugh.gif :)
Glumeam
Postat 10 February 2005 - 08:51 AM
Cit priveste care e mai performant, etilicul sau metilicul, nu pot sa-ti spun ca nu am experienta mesterilor de pe aici. Au mai fost discutii pe tema asta.
Aceasta postare a fost editata de navigator: 10 February 2005 - 08:52 AM
Postat 10 February 2005 - 10:28 AM
mai ales cind vad ca e p-aci si poctanus, care, mai "vechi" fiind, ar trebui sa stie si sa va spuna ca s-a mai "mestecat"(si inca bine!) treaba cu combustibilul, o minima si decenta documentare (chiar aici pe forum) v-ar scuti de inevitabile episoade "luzeresti"...!
bafta si minuni!
Postat 10 February 2005 - 10:56 AM
Aceasta postare a fost editata de bMaNiAc: 10 February 2005 - 10:57 AM
O == = O
"BURN RUBBER NOT YOUR SOUL!!"
Postat 10 February 2005 - 11:07 AM
Postat 10 February 2005 - 11:43 AM
cum trimiti tu lumea sa ia METANOL de la veterinar, cine dracu crezi ca-ncalca legislatia(foarte dura!, atentie!), in conditiile in care, in mod CLAR, e prevazuta in codul penal chiar si instigarea la savirsirea de infractiuni, facuta in mod public.
de ce te prevalezi de faptul ca astia mici poate nu cunosc legislatia cu privire la metanol(precursor in sinteza de psiholeptice!), si-i trimiti dupa cai verzi pe pareti, in loc sa-i indrumi catre prezentul furnizor LEGAL de combustibil rc, pe al carui site si forum evoluam acum?
ia spune-ne!
tuturor, bafta si minuni!
Postat 28 August 2007 - 10:13 AM
De regula uleiul de ricin si alcoolul metilic sunt componentele de baza pentru un combustibil. Ma refer la motoarele in 2 timpi, cu cap incandescent (hai sa-i zicem bujie, ca e mai cunoscut termenul).
Mai gasesti motoare pe benzina, motoare diesel, si cine stie ce fel de motoare or mai exista. Lista nu e lunga dar n-o stiu pe toata.
Atentie, nu e vorba de alcool medicinal sau nu in concentratia in care-l cumperi din magazin. Mai sunt discutii despre motoare si combustibili pe forum. Cred ca gasesti mai multe amanunte acolo.
Aceasta postare a fost editata de bitex: 28 August 2007 - 10:17 AM
Postat 28 August 2007 - 11:03 AM
#20
Postat 28 August 2007 - 11:14 AM
Astea de modelism sunt ceva mai pretentioase.
Nu mai pun la socoteala faptul ca-ti trebuie multa rabdare sa amesteci uleiul de ricin cu spirtul medicinal.
Daca nu crezi, convinge-te singur.
Iti dai seama ca daca ar merge cu spirt medicinal mi-as pune mortor termic si la ascutitoare...
Postat 28 August 2007 - 11:30 AM
Mi se pare ciudat, ca pentru 1 milion, cat costa un bidon de combustibil performant, sa te chinui atat, si sa risti sa distrugi si motorul, care oricum, costa mai mult...
Concluzionand: cumpara combustibil de fabrica (gasesti de la vreo 3 producatori in magazinele din tara noastra) si ai sa fii mult mai fericit... TIMPUL PIERDUT cu gasirea etanolului, metanolului, nitroglicerinei, etc cred ca te va costa mai mult de 1 milion.
Locuri de munca - Angajari - Companii: myFirstJob.ro
Publicitate aproape gratuita: tag-uri.ro
#22
Postat 28 August 2007 - 11:36 AM
#23
Postat 28 August 2007 - 11:46 AM
#24
Postat 28 August 2007 - 11:47 AM
later edit daca mergi doar pe spirt garantez ca o sa moara destul de repede...sau ai mers cu el doar la relanti sau cum...l-ai folosit in sarcina adica in aer
Aceasta postare a fost editata de Flo234: 28 August 2007 - 11:49 AM
#26
Postat 28 August 2007 - 11:53 AM
#27
Postat 28 August 2007 - 12:02 PM
Roktane 5% nitrometan (pentru aero) - 94 RON/5litri la magazinul STII-TU-CARE!
Intr-adevar, pentru competitii vei folosi un combustibil mai performant, pe care il gesesti la autorc.ro - asta daca faci performanta si nu doar joaca.
#28
Postat 28 August 2007 - 12:14 PM
Si mai toti au motoare scumpe, modele scumpe. Nu isi permite nimeni sa uzeze fara rost un motor scump. Regimul de functionare la auto e draconic, turatii foarte mari, acceleratii bruste, franari cam la fel.
La aero nu-ti permiti sa se opreasca motorul in aer, deci si acolo motorul trebuie sa se impace bine cu combustibilul, chiar daca la aero regimul e mai linistit.
Merge si cum zici tu, dar nu aici. Cauta detalii despre pretul combustibilului de fabrica. O sa ai surprize sa constati ca nu-i foarte scump.
Aceasta postare a fost editata de bitex: 28 August 2007 - 12:15 PM
Postat 28 August 2007 - 12:20 PM
#30
Postat 28 August 2007 - 05:35 PM
hacktris, la 28 Aug 2007, 12:20, a spus:
Cred ca nu ne intelegem la discutie...
La palatul copiilor se folosea pe vremuri alcool metilic, nu etilic. Adica metanol si ulei de ricin. In cazul in care banuiesti ca gresesc si daca esti sigur ca se folosea alcool etilic, spune-mi ce te face sigur sa afirmi ca era alcool etilic.
Spirtul medicinal nu-i metilic si nici nu are concentratia potrivita.
Daca ai sursa de alcool ETILIC pur e alta treaba. Un dezavantaj ar fi ca e mult mai scump decat acloolul METILIC pur, un avantaj ar fi ca nu-i supus restrictiilor legale... bla, bla, bla.
Hai s-o iau si altfel. Tu acum pornesti modelul cu spirt medicinal din ala cumparat de la orice farmacie? Ala albastru, botezat alcool sanitar, cu 70% concentratie? Ce fel de ulei folosesti? Cum se ameste alcoolul cu uleiul daca are atat de multa apa? Daca ai ceva care se amesteca, ce fel de ulei folosesti?
La concentratie mare sunt ceva sanse sa porneasca, dar nu cred ca la 70% este posibil. Sper sa ma insel, desi nu-i greu sa verific si asta.
