Modelism - RHC Forum: vand servo tester - Modelism - RHC Forum
vand servo tester turnigy
#1 Useril este offline   luci25gold
  • T-REX Helii
  • Postari: 2124
  • Inregistrat: 05-April 10
  • Interests:DOAR Elicoptere
Postat 05 January 2016 - 12:56 PM
The Turnigy 760HV servo tester was custom designed to be the most accurate and accommodating servo tester available. It's quality case design reflects the thought and design of this device.
Designed to handle Narrow (760us/560Hz) and Normal (1520us/66.6Hz) pulse servos plus being able to run with as little as 3v up to 12.6v. Making this a servo tester you can use with almost any servo!
The 760HV's versatility comes from the high-spec potentiometer and it's high-end NEC chip which can handle low(3v) and high(12.6v) voltages.
Spec.
Servo Type: (760us/560Hz) or (1520us/66.6Hz) HV or Standard
Input voltage: DC3~12.6V (1~3S Lipoly)
Plug: Futaba & JR
Weight: 35g
Dimensions: 63x55x21mm
Attention: Do not input a voltage that is higher than your servo can handle.
plus cutie pentru bateri AA
50lei
Ne traim viata in mare viteza, incercam sa rascumparam timpul,
insa de cele mai multe ori deciziile pe care le luam in pripa nu sunt cele mai bune!
07470130360
#2 Useril este offline   luci25gold
  • T-REX Helii
  • Postari: 2124
Postat 19 January 2016 - 08:54 AM
up!
07470130360
#3 Useril este offline   luci25gold
  • T-REX Helii
  • Postari: 2124
Postat 30 January 2016 - 04:06 PM
up
07470130360
#4 Useril este offline   luci25gold
  • T-REX Helii
  • Postari: 2124
Postat 25 February 2016 - 10:27 PM
up
07470130360
