Modelism - RHC Forum: Vand planor 2m pt competitie clasa F4J (PEGASUS V2) - Modelism - RHC Forum
Vand planor 2m pt competitie clasa F4J (PEGASUS V2) echipat complet-( fara statie)
#1 Useril este offline   grig
  • Postari: 263
  • Inregistrat: 24-March 02
Postat 19 December 2015 - 11:31 AM
Light thermic electric glider for competitions flying F4J category. Wingspan 2 m.
Light fuselage moulded in white tinted epoxy fiberglass with rear strut and blue tinted fiberglass canopy
Two piece wing, controlled by the ailerons and flaps, is made in balsa framework with carbon leading edge and wing spar made of carbon tube and covered with Oracover®
Tailplane is made in a balsa framework with carbon beam and leading edge and covered with Oracover®
Top quality accessories (servo covers, servo mount, rods, ending ties, control horns, tape for sticking flaps, fiberglass motor mount,...)
https://www.youtube....h?v=-ZhlZhLf9iU
Spécifications
Envergure : 1999mm
Longueur : 1100mm
Masse : 0.6 - 0.75Kg
Surface alaire : 34.8dm²
Charge alaire : 17.2 - 21.6 g/dm²
Profil : AG
Fonctions RC : dérive, profondeur, ailerons, volets, moteur
echipat cu :servo HItec HS45 eleroane ( 2 buc)
servo HITEC HS65 flaps ( 1 buc )
servo HITEC HS55 V tail ( 2 buc)
motor 2830
regulator 30 amp
con dural
elice Cam folding prop Graupner 9x5 (pt 3 lipo)
acumulator 3S lipo 2000mah
http://www.topmodelc...top=foto&id=748
este in perfecta stare se poate vinde si cu proba
este varianta verde
PRET 300 euro
tel 0722.244.615
#2 Useril este offline   nicajohn
  • Postari: 534
  • Inregistrat: 20-August 06
  • Interests:aeromodele
Postat 21 December 2015 - 11:13 AM
Aceasta postare a fost editata de nicajohn: 21 December 2015 - 11:16 AM
pasarile fac oua si din ele ies pui iar avioanele fac oua de aluminiu si ies aeromodele....din intelepciunile lui fiu-meu<span style='font-size:8pt;line-height:100%'> </span><!--coloro:red--><span style="color:red"><!--/coloro--> <!--colorc--></span><!--/colorc-->
#3 Useril este offline   nicajohn
  • Postari: 534
Postat 21 December 2015 - 11:14 AM
Ce greu e limbă românește :(
#4 Useril este offline   grig
  • Postari: 263
Postat 21 December 2015 - 02:07 PM
:huh: :blink:
Aceasta postare a fost editata de grig: 21 December 2015 - 02:09 PM
#5 Useril este offline   Men
  • Postari: 634
  • Inregistrat: 05-May 03
Postat 22 December 2015 - 11:40 PM
Ceva poze? Am vazut link-ul dar realul cum arata?
#6 Useril este offline   grig
  • Postari: 263
Postat 29 December 2015 - 02:42 PM
Vezi postareaMen, la 22 December 2015 - 11:40 PM, a spus:
se poate vinde si la 230 euro fara motorizare..
#7 Useril este offline   grig
  • Postari: 263
Postat 29 December 2015 - 02:44 PM
Vezi postareagrig, la 29 December 2015 - 02:44 PM, a spus:
#8 Useril este offline   grig
  • Postari: 263
Postat 03 February 2016 - 10:19 PM
postare inchisa
