Modelism - RHC Forum: Navomodel Nadit - proiectul meu - Modelism - RHC Forum
Navomodel Nadit - proiectul meu navo, plantat, barca, carponizer, carp range
#1 Useril este offline   ahmoola
  • Postari: 409
  • Inregistrat: 14-February 13
Postat 15 November 2015 - 07:36 PM
Salutare
Dupa mult timp am finalizat unul din proiecte - Carp range
echipare
- Coca Carp Range 2 - varianta de viteza = 270 Ron
- Motor Electric POWER 755/ 40 = 93 Ron
- Regulator electronic ROOKIE 25 - 12V/ 25A = 193 Ron
- Carma din alama 50 x 36 mm = 53 Ron
- Modul 2 pentru navomodele (lumini + cuve = 69 Ron
- Elice aluminiu navo 3 pale 40 mm dreapta = 119 Ron
- Servo Futaba S3003 Standard = 53 Ron
- Servo Futaba S3305 BB Standard - 2 buc = 290 Ron
- Telecomanda Fly Sky FS-CT6B Second hand = 220 Ron
- Cuplaj Filetat M3 = 8 Ron
- Furci Cuplaj M3 (4 buc) = 6 Ron
- Arbore cu tub pupa D4 x 250 mm = 46 Ron
- Protectie antibradis pentru navomodel de plantat = 19 Ron
- Antena pentru receptori in 2.4GHz = 17 Ron
- BEC Extern Turnigy 5-6 V/ 5 A = 59 Ron
- Conector XT60 (2 Mama + 2 Tata)2 set = 25 Ron
- Avertizor LiPo display/ buzzer 1-8S = 23 Ron
- Conector Servo mama cu cablu (d 0.64)30cm x 3 buc = 8 Ron
Total =1571 Ron
Nu sunt incluse materialele de lipire si uneltele necesare taiere, lipire, filetare, etc.
#2 Useril este offline   ahmoola
  • Postari: 409
Postat 15 November 2015 - 07:51 PM
Vezi postareaahmoola, la 15 November 2015 - 07:36 PM, a spus:
Salutare
echipare
Total =1571 Ron
Aceasta postare a fost editata de ahmoola: 15 November 2015 - 07:51 PM
#3 Useril este offline   ahmoola
  • Postari: 409
Postat 15 November 2015 - 08:11 PM
poze
  • Fisier atasat  1.jpg (431.75K)
#4 Useril este offline   ahmoola
  • Postari: 409
Postat 15 November 2015 - 08:55 PM
Teste pe uscat
https://youtu.be/Dc7tIPkBm7o
Aceasta postare a fost editata de ahmoola: 15 November 2015 - 08:57 PM
#5 Useril este offline   adyi01
  • Postari: 12
  • Inregistrat: 14-March 14
Postat 19 November 2015 - 07:57 PM
am inceput si eu sa lucrez la unul . deocamdata am coca , manerul si voltmetru :D
  • Postari: 3555
  • Inregistrat: 25-May 08
  • Interests:Navo
Postat 19 November 2015 - 08:33 PM
Ai tot timpul ,e bine sa dai o mina de lac la interior.
Barcute intinse!
#7 Useril este offline   ahmoola
  • Postari: 409
Postat 21 November 2015 - 04:53 PM
prima plantare
Iata si prima plantare
Consum: 12.1V la 11.6.
Nu am apucat sa reincarc acumulatorul sa vad cati mAh baga.
Am plantat la aproximativ 100 m de 10 ori pentru mine si un prieten :)
#8 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 21 November 2015 - 09:34 PM
Testul nu este elocvent ,plecind de la 12,1 viteza este mai mica, dus la 11,6v este valoarea minima de reincarcare ,ar trebui reluat testul cu un acumulator incarcat full.
Barcute intinse!
#9 Useril este offline   ahmoola
  • Postari: 409
Postat 22 November 2015 - 08:03 AM
Vezi postareamanolo, la 21 November 2015 - 09:34 PM, a spus:
La urmatoarea pescuiala - acumulator full - refacem teste
#10 Useril este offline   ahmoola
  • Postari: 409
Postat 22 November 2015 - 12:47 PM
Credeti ca pot aparea probleme de interferenta in asezarea din poza?
Antena pentru telemetrie in 433 MHz APM 2.6
langa antena in 1.2 Ghz pentru transmisie analogica imagini camera video.
La aproximativ 5 cm distanta antena in 2.4GHz pentru sonar FC500
Astept pareri
  • Fisier atasat  10b.jpg (261.23K)
#11 Useril este offline   stelian
  • NAVOMODELE CNX
  • Postari: 2400
  • Inregistrat: 01-December 08
Postat 22 November 2015 - 08:43 PM
Pai daca tot le-ai montat asa dute si fa o proba ,din cate imi aduc aminte antena de la telemetrie sau GPS trebuie sa montata la o distanta de min 30 cm fata de antena sonarului !
Aceasta postare a fost editata de stelian: 22 November 2015 - 08:45 PM
facebook
0721 241 744 VODAFONE
0762 028 013 COSMOTE
#12 Useril este offline   ahmoola
  • Postari: 409
Postat 22 November 2015 - 09:43 PM
Vezi postareastelian, la 22 November 2015 - 08:43 PM, a spus:
E cam greu cu proba ca nu e gata ansamblul...
o sa mut antena sonarului...
Alte reguli de care trebuie sa mai tin cont?
#13 Useril este offline   adyi01
  • Postari: 12
Postat 23 November 2015 - 07:30 PM
Vezi postareamanolo, la 19 November 2015 - 08:33 PM, a spus:
Coca este din plastic.sa dau lac inainte de montarea pieselor ? coca este goala acuma.nu are nimic montat
#14 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 23 November 2015 - 09:08 PM
Uuuuuuu mai bine da-o altuia.
Barcute intinse!
#15 Useril este offline   adyi01
  • Postari: 12
Postat 24 November 2015 - 05:49 AM
Pai de ce ?
#16 Useril este offline   stelian
  • NAVOMODELE CNX
  • Postari: 2400
Postat 24 November 2015 - 08:41 AM
Vezi postareaadyi01, la 24 November 2015 - 05:49 AM, a spus:
Pai de ce ?
Daca coca este din plastic nu este nevoie sa ii dai lac , oricum oxideaza la interior orice barca daca nu ii scoti capacul de vizitare !!!
facebook
#17 Useril este offline   stelian
  • NAVOMODELE CNX
  • Postari: 2400
Postat 24 November 2015 - 09:01 AM
Fisier atasat  IMG_20151124_084320.jpg (234.37K)
facebook
#18 Useril este offline   adyi01
  • Postari: 12
Postat 24 November 2015 - 10:17 AM
Capacul o sa il scot de fiecare data cand o sa stea pe uscat.
Ce parere aveti de siliconul de etansare garnituri auto...se poate folosi pt etansare si la navomodel ? La carma,ax...
#19 Useril este offline   stelian
  • NAVOMODELE CNX
  • Postari: 2400
Postat 24 November 2015 - 10:30 AM
Vezi postareaadyi01, la 24 November 2015 - 10:17 AM, a spus:
Pentru etansare foloseste silicon de la Bizon iar pentru fixarea suportilor chit de fibra sau rasina !
Aceasta postare a fost editata de stelian: 24 November 2015 - 10:30 AM
facebook
#20 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 24 November 2015 - 12:24 PM
Pe o coca de plastic mai greu ,merge cu montaj kit,dar in prealabil smirghel grosier ,oricum alegerea unei coci din plastic eu o consider gresita.
Barcute intinse!
#21 Useril este offline   adyi01
  • Postari: 12
Postat 24 November 2015 - 04:00 PM
Pt etansare am ales silicon etansare de la Victor Reinz...
#22 Useril este offline   stelian
  • NAVOMODELE CNX
  • Postari: 2400
Postat 24 November 2015 - 04:26 PM
Vezi postareaadyi01, la 24 November 2015 - 04:00 PM, a spus:
Esti asa sigur de priceperea ta si de calitatea pieselor pe care o sa le montezi in barcuta in cat sa intervii pentru services la 2-3 ani ? Eu zic sa te mai gandesti .
facebook
#23 Useril este offline   nab
  • Postari: 5
  • Inregistrat: 20-September 15
Postat 24 November 2015 - 05:56 PM
Receiverul la telecomanda ta da semnal digital sau analog ? Ma refer la canalele ce le folosesti pentru controlul servomotoarelor.
Multumesc.
Aceasta postare a fost editata de nab: 24 November 2015 - 05:56 PM
Întotdeauna apa învinge piatra. Nu prin forţă, ci prin perseverenţă.
#24 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 24 November 2015 - 06:16 PM
Vezi postareastelian, la 24 November 2015 - 04:26 PM, a spus:
Esti sigur ca acest silicon este mai "tare" decit un silicon de acvarii sa zicem? acest silicon se comporta ca un silicon 2+2 de garnituri ,care ramine elastic ,caci asta e menirea lui.
Barcute intinse!
#25 Useril este offline   stelian
  • NAVOMODELE CNX
  • Postari: 2400
Postat 24 November 2015 - 07:25 PM
Vezi postareamanolo, la 24 November 2015 - 06:16 PM, a spus:
Am in casa un acvariu de 120 L lipit de mine de la varsta de 12 ani lipit cu silicon cumparat din piata Obor asta prin anul '87-'88 . inca nu curge !!!
Acest termen '' SILICON PENTRU ACVARII '' este inventat de vanzatori ambulanti ,si este folosit doar in acvaristica , deoarece dupa 24 de ore se pot adauga animalele in cusca facuta din sticla fara sa le dauneze 'prea ' grav sanatati acestora !!!
facebook
#26 Useril este offline   adyi01
  • Postari: 12
Postat 24 November 2015 - 08:10 PM
nu stiu cat de tare este daca lipeste o baie de ulei la masina . este elastic in mod permanent si rezista de la -50 grade la +300 , rezistent la razele solare ... made in germania.
Sper sa lipeasca bine o coca sau sa etanseze un ax
#27 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 24 November 2015 - 08:34 PM
Iti recomand sa faci o proba ,undeva la interior trage un snur mic de silicon si dupa 24 de ore fa o proba de aderenta.
Barcute intinse!
#28 Useril este offline   adyi01
  • Postari: 12
Postat 24 November 2015 - 10:01 PM
Acuma daca il am pe acesta raman cu el...nu zic ca varianta ta nu e buna.iti multumesc oricum pt sfat.daca nu sunt multumit de cum lipeste si etanseaza o sa apelez la varianta ta
Pe langa bucsile de la becuri e nevoie de etansare ?
#29 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 24 November 2015 - 11:38 PM
Da e bine ,in interior.
Barcute intinse!
#30 Useril este offline   adyi01
  • Postari: 12
Postat 30 November 2015 - 05:04 PM
4 becuri rosii pe spate si 2 mai mici pe fata undeva in lateral + voltmetru . am si manerul dar nu este pus.
Aceasta postare a fost editata de adyi01: 30 November 2015 - 05:04 PM
26 useri citesc topicul
0 membri, 26 vizitatori, 0 utilizatori anonimi
