Modelism - RHC Forum: Programez Arduino - Modelism - RHC Forum
Programez Arduino
#1 Useril este offline   Danieltnokia2000
  • Postari: 333
  • Inregistrat: 21-October 07
  • Interests:discussion
Postat 09 October 2015 - 08:02 PM
Programez module arduino pt orice aplicatie. Lcd, servo, mpp, encodere, gsm, wifi, bluetooth etc. Pt informatii aici sau pe mail la tical.daniel@gmail.com.
#2 Useril este offline   mellbo
  • Postari: 508
  • Inregistrat: 26-August 13
Postat 09 October 2015 - 10:25 PM
Vezi postareaDanieltnokia2000, la 09 October 2015 - 08:02 PM, a spus:
ai putea programa un atmega328P sa-si scrie singur LB pe 0xCC ?
Aceasta postare a fost editata de mellbo: 09 October 2015 - 10:25 PM
TEL: 0786.607.466
#3 Useril este offline   Danieltnokia2000
  • Postari: 333
Postat 16 October 2015 - 07:32 PM
Vezi postareamellbo, la 09 October 2015 - 10:25 PM, a spus:
nu stiu ce e LB...
Postat 16 October 2015 - 08:26 PM
lock bits
#5 Useril este offline   mellbo
  • Postari: 508
Postat 16 October 2015 - 09:09 PM
Vezi postarearenatoa, la 16 October 2015 - 08:26 PM, a spus:
lock bits
multumesc renatoa.
TEL: 0786.607.466
#6 Useril este offline   Danieltnokia2000
  • Postari: 333
Postat 14 November 2015 - 11:21 PM
Vezi postareamellbo, la 16 October 2015 - 09:09 PM, a spus:
multumesc renatoa.
nu am incercat pt ca nu am avut nevoie pana acum. am cateva proiecte de terminat si apoi o sa pot stuidia aceasta parte.
#7 Useril este offline   mellbo
  • Postari: 508
Postat 17 November 2015 - 06:07 AM
Vezi postareaDanieltnokia2000, la 14 November 2015 - 11:21 PM, a spus:
multumesc. o sa astept pana cand ai timp...
TEL: 0786.607.466
#8 Useril este offline   Danieltnokia2000
  • Postari: 333
Postat 30 November 2015 - 02:09 PM
UP
#9 Useril este offline   Danieltnokia2000
  • Postari: 333
Postat 07 March 2016 - 11:02 AM
Valabil.
#10 Useril este offline   Sami
  • Postari: 7
  • Inregistrat: 26-March 10
Postat 16 March 2016 - 01:38 PM
Salutare,
As vrea sa te intreb daca ai programat ceva arduino pentru aeromodelism. Si daca da, pentru ce aplicatii? ( adica ce faceau mai exact)
Multumesc anticipat
#11 Useril este offline   Danieltnokia2000
  • Postari: 333
Postat 18 March 2016 - 09:36 AM
Vezi postareaSami, la 16 March 2016 - 01:38 PM, a spus:
Salutare,
Multumesc anticipat
nu am programat , dar sigur pot face ce vrei.
ca idee de aplicatie: am facut recent un arduino care controleaza un strung pe partea de filetare. deci citeste pozitie universal si sincronizeaza avansul ca sa faca filet. asta pe scurt. spunce ce vrei sa faci si iti spun cum facem.
Postat 18 March 2016 - 09:41 AM
Adica nu ai programat pentru aeromodelism, ca altfel nu prea are sens postarea ta :)
#13 Useril este offline   Sami
  • Postari: 7
Postat 18 March 2016 - 10:09 AM
Salutare,
Ok. Hai sa vedem. Eu am arduino nano ( ca e mai mic) , senzori de tot felul printre care si de proximitate. Cum poti face ceva sa vezi altitudinea spre exemplu in timp real si sa o transmiti la un TX ( spektrum dx7 spre exemplu). Vreau sa mentionez ca stiu de telemetrie, si stiu sa imi programez arduino sa imi citeasca distanta dar cum l-ai integra tu cu TX? Desigur daca se poate.
Mersi fain si astept parerile tale
#14 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3622
  • Inregistrat: 09-June 07
Postat 18 March 2016 - 11:42 AM
Cu senzor de proximitate am încercat și eu să citesc altitudinea dar la 5 m nu mai functioneaza.
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
Postat 18 March 2016 - 02:54 PM
Trebuie senzor barometric/presiune, conectat pe i2c la Arduino, ca sa citesti altitudinea, cel de proximitate (sonar) merge cu ultrasunete si reflexie, nu are cum sa bata prea mult.
Ca sa scapi de calculul altitudinii in fc de presiune, care implica si o corectie cu temperatura, formule cunoscute, nimic obscur, poti folosi biblioteca OpenVario/OpenSensor.
Dar nu asta este problema voastra principala, ci trimitere datelor la sol, si mai ales afisarea, care inteleg ca se doreste sa se faca pe ecranul statiei... unobtainium cu un DX7 in regim de amator, e treaba de hacker.
Asa ca mai bine folositi un modul original TM1000, nu cred ca iesiti mai ieftin artizanal.
Aceasta postare a fost editata de renatoa: 18 March 2016 - 02:55 PM
#16 Useril este offline   ERASER
  • Vintage
  • Postari: 2259
  • Inregistrat: 23-March 03
  • Interests:F3A , veliere
Postat 19 March 2016 - 03:37 PM
Salutare !
Stii sa programezi un Arduino sa scrie si sa citeasca autonom de pe un card SD ? Ideea este ca la pornire sa incarce un programel de pe card, sa-l execute (adica sa monitorizeze niste parametri) si apoi sa salveze periodic rezultatele pe card. Totodata sa si afiseze ultima valoare pe display-ul LCD simplu de tip 2 x 16 sau 4 x 20 ?
S-ar putea chiar sa te si platesc...
TEL. 0726.191.725
Postat 19 March 2016 - 04:26 PM
Vezi postareaERASER, la 19 March 2016 - 03:37 PM, a spus:
...S-ar putea chiar sa te si platesc...
:rofl:
#18 Useril este offline   Danieltnokia2000
  • Postari: 333
Postat 19 March 2016 - 07:23 PM
Salutare !
da pot. de ce sa incarce programelul de pe sd? zici ce senzori vrei sa monitorizezi si salvam datele pe care intrun fisier. de ce vrei sa il incarci de pe card? sunt diferiti parametri ca nu inteleg?
#19 Useril este offline   Danieltnokia2000
  • Postari: 333
Postat 19 March 2016 - 07:32 PM
Vezi postareaSami, la 18 March 2016 - 10:09 AM, a spus:
Salutare,
nu am facut asa ceva si cred ca nu o sa fac pt ca nu am respectivele dispozitive. dar, cum sa trimiti catre un tx? poti trimite catre un rx. adica in telecomanda aia daca nu ai un receiver nu ai cum sa trimiti. sa zic ca pe arnuino ala mini pui un modul radio dar trebuie ca ai un receiver.!! doar sa faci si un receiver unde poti sa primesti ce trimiti din aer. altfel nu vad. dar cum ziceam stiu prea putin despre acele dispozitive dedicate.
#20 Useril este offline   ERASER
  • Vintage
  • Postari: 2259
Postat 21 March 2016 - 09:34 PM
Vezi postareaDanieltnokia2000, la 19 March 2016 - 07:23 PM, a spus:
Programelul poate sa ramana in memoria lui. Ideea este ca la intreruperea alimentarii datele sa nu se piarda si la reluara alimentarii sa porneasca singur din nou, fara interventie din exterior. Sunt niste ecuatii care transforma microvoltii cititi de senzor in valorile parametrului respectiv (adica sa afiseze procente de umiditate nu valorile in biti ale semnalului, asta s-ar putea sa ma descurc sa programez si eu). Datele trebuiesc scrise pe un SD ca sa poate fi citite ulterior pe un calculator, fara a merge cu laptop-ul unde se afla Arduino. Merg dupa o luna sa zicem, iau SD-ul scris si pun un SD gol pe care va inregistra in continuare. Ar fi un fisier text de 2000 - 3000 lini a 20 caractere, deci cativa KB.
Trebaba nu e prea urgenta, colaborarea ar putea avea loc candva in intervalul 1 mai - 31 iulie. Esti din Bucuresti ?
Apropo de faza cu plata de care rade Renato, treaba e simpla: e munca de cercetare la facultate, neplatita. Daca treaba iese bine si ma va ajuta la teza de doctorat, evident ca te voi plati. Failure is not an option...
Aceasta postare a fost editata de ERASER: 21 March 2016 - 09:36 PM
TEL. 0726.191.725
#21 Useril este offline   Danieltnokia2000
  • Postari: 333
Postat 24 March 2016 - 10:58 AM
Vezi postareaERASER, la 21 March 2016 - 09:34 PM, a spus:
da pe mail formule su ce mai trebuie si iti fac codul. tical.daniel@gmail.com
#22 Useril este offline   Bughy
  • Postari: 188
  • Inregistrat: 09-June 10
  • Interests:Robotica, Electronica, Mecanica
Postat 28 March 2016 - 02:54 PM
Cum calculezi preturile? Da-mi te rog niste exemple.
Mersi,
Bogdan
"I reject the reality and substitute my own"
Bogdan
0742 796 172
#23 Useril este offline   Danieltnokia2000
  • Postari: 333
Postat 29 March 2016 - 08:57 AM
Vezi postareaBughy, la 28 March 2016 - 02:54 PM, a spus:
Mersi,
Bogdan
Ca sa ce?
#24 Useril este offline   Mihai Stancu
  • Postari: 161
  • Inregistrat: 19-February 10
Postat 05 April 2016 - 11:35 AM
Ai PM, multumesc anticipat.
Bunul simt ar trebui sa fie de "common sense'.
5 useri citesc topicul
