Modelism - RHC Forum: OFERTA BOMBA BY DULULUTU. 50 LEI - Modelism - RHC Forum
#1 Useril este offline   dululutu
  • Postari: 1476
  • Inregistrat: 14-July 09
Postat 26 September 2015 - 11:51 PM
Aeromodel Cloud Surfer 60I
anvergura 100 cm.
ideal pentru sezonul rece
echipat si infoliat ca de obicei si la aceeasi calitate by dululutu
nu contine electronica
PRET 50 LEI CU FAN CURIER INCLUS
OFERTA VALABILA O ANUMITA PERIOADA
COMENZI PE PM
#2 Useril este offline   Zeus
  • Postari: 2455
  • Inregistrat: 15-January 09
Postat 27 September 2015 - 08:34 AM
O poza?
#3 Useril este offline   dululutu
  • Postari: 1476
Postat 27 September 2015 - 12:05 PM
Vezi postareaZeus, la 27 September 2015 - 08:34 AM, a spus:
O poza?
am uitat, scuze
Vezi postareadululutu, la 27 September 2015 - 12:04 PM, a spus:
am uitat, scuze
#4 Useril este offline   NAVOMARIUS
  • MARIUS
  • Postari: 4699
  • Inregistrat: 04-October 10
  • Interests:AEROMODELE
Postat 27 September 2015 - 08:01 PM
Gata de joaca la ce bani ajunge?
Tel 0740850863
Grea 6--POZE CET VEST
#5 Useril este offline   dululutu
  • Postari: 1476
Postat 27 September 2015 - 10:48 PM
Vezi postareaNAVOMARIUS, la 27 September 2015 - 08:01 PM, a spus:
momentan nu mai am electronica
complet echipat ar ajunge la max. 500 g asa ca vezi si tu
#6 Useril este offline   PETT
  • Postari: 362
  • Inregistrat: 26-May 15
Postat 28 September 2015 - 07:23 AM
Aveti PM.
#7 Useril este offline   cata123
  • Postari: 986
  • Inregistrat: 17-December 10
Postat 28 September 2015 - 07:57 AM
Felicitari Dululutu! Arata foarte bine si cred ca este si stabil in aer.
De data asta ma bag si eu, iti las detalii pe PM. :)
#8 Useril este offline   cyberanizer
  • Postari: 73
  • Inregistrat: 26-December 08
Postat 28 September 2015 - 11:55 PM
Ce avengura are?
#9 Useril este offline   Zeus
  • Postari: 2455
Postat 29 September 2015 - 12:48 AM
Vezi postareacyberanizer, la 28 September 2015 - 11:55 PM, a spus:
Ce avengura are?
Citeste mai sus.
Arata super, ma bag si eu la doua.
#10 Useril este offline   Robert_Damian
  • Postari: 255
  • Inregistrat: 03-February 11
  • Interests:Elicoptere
Postat 29 September 2015 - 11:53 AM
Ce electronică foloseşte?
HK 450MT...
#11 Useril este offline   dululutu
  • Postari: 1476
Postat 29 September 2015 - 01:01 PM
Vezi postareaRobert_Damian, la 29 September 2015 - 11:53 AM, a spus:
Trei servo de 9g si un motor sa traga 500g
Acumulator max 1800mah
#12 Useril este offline   cosmin77
  • Postari: 253
  • Inregistrat: 24-March 15
  • Interests:Aeromodelism
Postat 04 October 2015 - 07:51 PM
Un filmulet cu acest model are cineva ?
#13 Useril este offline   Mato
  • Postari: 165
  • Inregistrat: 29-May 11
Postat 05 October 2015 - 04:50 PM
Vreau si eu doua bucati. Una din ele as vrea sa fie tot pe negru iar pentru al doilea nu am preferinta.
Multumesc,
Vali
#14 Useril este offline   dululutu
  • Postari: 1476
Postat 08 October 2015 - 06:13 PM
imi cer scuze pentru cei care nu au primit inca modelul dar fac tot posibilul ca acest lucru sa se intample cat mai repede
am primit in 24 ore peste 20 comenzi si le onorez in ordine cronologica
toti cei care ati comandat o sa primit modelul in cel mai scurt timp posibil
multumesc de intelegere
#15 Useril este offline   stiganas
  • Postari: 8339
Postat 08 October 2015 - 06:26 PM
Modelul arata excelent (ma bate si pe mine gandul sa cumpar unul), ar trebui sa angajezi niste ajutoare.
#16 Useril este offline   Andrei Panainte
  • Postari: 173
  • Inregistrat: 11-December 14
Postat 08 October 2015 - 06:34 PM
Eu am luat unul si l-am echipat si a iesit cu o baterie de 2200 la 520g . acum sa il vedem la zbor.
#17 Useril este offline   Zeus
  • Postari: 2455
Postat 14 October 2015 - 10:16 PM
Au ajuns, arata super, bravo omule, i-ai depasit si pe chinezi la pret calitate.
Cum e modelul cu 2200, nu e prea greu? Ce fel de motorizare ati pus si ce elice?
Aceasta postare a fost editata de Zeus: 14 October 2015 - 10:19 PM
#18 Useril este offline   icsss
  • Postari: 2085
  • Inregistrat: 16-May 10
Postat 14 October 2015 - 10:38 PM
L-am primit si eu azi si arata excelent.
Felicitari si multumesc.
O sa revin cu poze dupa ce-l pregatesc de zbor.
#19 Useril este offline   Andrei Panainte
  • Postari: 173
Postat 15 October 2015 - 08:38 AM
Eu l-am cantarit cu 2200 si are 520grame dar de zburat inca nu l-am zburat astept vremea buna in week-end sa il zbor.
#20 Useril este offline   Zeus
  • Postari: 2455
Postat 15 October 2015 - 08:54 AM
Cg-ul, unde este, intre 1/4 si 1/3 de la bordul aripei?
Care ati zburat modelul, poate ne spuneti si noua ce electronica/setari ati folosit si ce sfaturi dati.
Multumim.
#21 Useril este offline   icsss
  • Postari: 2085
Postat 15 October 2015 - 09:36 AM
Vezi postareaZeus, la 15 October 2015 - 08:54 AM, a spus:
Multumim.
Ai putea sa folosesti un calculator online, ceva de genul asta: http://adamone.rchom...com/cg_calc.htm
Eu inca imi caut un tren de aterizare, dar oscilez intre triciclu si taildragger :)
#22 Useril este offline   dululutu
  • Postari: 1476
Postat 15 October 2015 - 02:56 PM
Cg la 5 cm fata de BA
Ca electronica un motoras sa traga 500g cu elicea aferenta si o baterie de 1000- 1800mah
Servo de 9g
La montarea profundorului sa se aiba grija ca unggiul de incidenta intre el si aripa sa fie 0grade poqte un grad pozitiv dar in nici un caz negativ. Daca se monteaza cu putina grija nu o sa fie nici o problema, o sa cada cuum trebuie
#23 Useril este offline   cata123
  • Postari: 986
Postat 15 October 2015 - 07:42 PM
Salutare,
In primul rand, tin sa-l felicit pe Dululutu pentru model. Am luat doua bucati, si sunt placut impresionat de ambele.
Am fcut cateva teste inainte, si mi-am permis sa fac cateva modificari, deoarece CG-ul nu pica cum trebuie. In momentul de fata este la 3cm de BA. Am sapat putin pentru a deplasa bateria cat mai in spate (in momentul de fata se afla lipita de lemnul in care se prinde aripa), am montat servo profundor in fuselaj la aprox 5cm de planul secund si am adaugat 10g plumb in coada. Ar fi de preferat daca bateria ar putea fi deplasata inca 3cm spre spate.
Oricum, a iesit o jucarie de toata cinstea! Este un model foarte prompt(practic este " una cu mansa"), frumos si foarte accesibil. Il recomand cu placere!
Felicitari Dululutu! Daca esti interesat sa incerci un F22 din polipropilena, imi va face mare placere sa ti-l ofer.
.....am facut un filmulet cu zuratoarea pe o vreme destul de naspa:
https://www.youtube....h?v=r1qDGD_8iOs
#24 Useril este offline   drdream
  • Postari: 614
  • Inregistrat: 29-October 13
  • Interests:Tot ce zboara
Postat 15 October 2015 - 09:55 PM
fratioareeee, nu e acrobat 3d , e trainer cu veleitati de usoare acrobatii...
Dululutu cu ce i-ai ranforsat aripile de a tinut la halu ala de g-uri?
Zboara f frumos si la viteze mici, nu staleaza, e o platforma superba de fpv.
#25 Useril este offline   icsss
  • Postari: 2085
Postat 17 October 2015 - 01:15 AM
Cu 2830 si 2200mah 3s -> 580g
Putin cam greu dar pana imi vine 1800 il incerc asa. Motorul trage cam 700-800g.
I-am pus si un tren de aterizare :)
#26 Useril este offline   stiganas
  • Postari: 8339
Postat 17 October 2015 - 08:19 AM
Nu pune careva niste poze/filmulet de cum a iesit modelul ?
#27 Useril este offline   icsss
  • Postari: 2085
Postat 17 October 2015 - 11:34 AM
hai ca pun eu :)
  • Fisier atasat  a-01.jpg (93.89K)
  • Fisier atasat  a-02.jpg (95.4K)
  • Fisier atasat  a-03.jpg (96.65K)
  • Fisier atasat  a-04.jpg (99.04K)
  • Fisier atasat  a-05.jpg (97.04K)
  • Fisier atasat  a-06.jpg (100.1K)
  • Fisier atasat  a-07.jpg (87.44K)
  • Fisier atasat  a-08.jpg (92.58K)
  • Fisier atasat  a-09.jpg (92.98K)
  • Fisier atasat  a-10.jpg (97.48K)
#28 Useril este offline   Andrei Panainte
  • Postari: 173
Postat 17 October 2015 - 06:09 PM
Bomba mea By Dululutu a explodat inainte de a zbura. L-am echipat saptamana trecuta si pentru ca nu a avut coada lipita nu a putut zbura la camp. Azi l-am dus la camp si am apelat la cineva sa mi-l regleze si cand l-a ridicat in aer cand a tras de profundor sa-l ridice pentru ca nu era lipit s-a infipt in bot.trist ca nu am apucat sa il zbor.
#29 Useril este offline   Andrei Panainte
  • Postari: 173
Postat 17 October 2015 - 06:10 PM
http://i59.tinypic.com/24g0z82.jpg
#30 Useril este offline   Andrei Panainte
  • Postari: 173
Postat 17 October 2015 - 06:14 PM
http://i57.tinypic.com/2le1cia.jpg
loading
