Modelism - RHC Forum: echipare barcuta - Modelism - RHC Forum
  • 5 Pagini +
echipare barcuta
#31 Useril este offline   manolo
  • Postari: 3555
  • Inregistrat: 25-May 08
  • Interests:Navo
Postat 29 August 2015 - 11:24 AM
In principiu e bun,dar cu afisor rosu pe timp de zi si soare nu ai sa vezi nimic,incearca albastru sau verde .
Barcute intinse!
Tel. 0744915775
#32 Useril este offline   laurentiu_mr
  • Postari: 17
  • Inregistrat: 11-September 11
Postat 29 August 2015 - 08:07 PM
Imi puteti spune care e mai bun?
1. AEO RC Model Adjustable Voltage 5V/5A 6V/5A 7.2V/5A R/C Hobby UBEC BEC AC895
Specifications
Brand: AEO
Dimensions (approximately): 45mm x 15mm x 9mm
Input: 7.2V-21V
Output: 5.0V,6.0V,7.2V / 5A
Weight: 12g
2. Turnigy 5A (8-26v) switching BEC SBEC UBEC - Plane/Heli UK Seller Fast Dispatch
Type: Switching
Input protection: Reverse polarity protection
Output (Constant): 5v/5A or 6v/5A
Input: 8v-26v (2-7cell lipo)
Weight: 18g
#33 Useril este offline   DigitAll
  • Postari: 769
  • Inregistrat: 23-January 09
Postat 30 August 2015 - 08:36 AM
Ambele sunt bune.
Aceasta postare a fost editata de DigitAll: 30 August 2015 - 08:37 AM
Tel : 0768080180
#34 Useril este offline   laurentiu_mr
  • Postari: 17
Postat 30 August 2015 - 02:03 PM
Vezi postareaDigitAll, la 30 August 2015 - 08:36 AM, a spus:
Ambele sunt bune.
Multumesc frumos.
#35 Useril este offline   laurentiu_mr
  • Postari: 17
Postat 31 August 2015 - 11:33 AM
Salut.
Ma puteti ajuta cu un sfat despre ce acumulator sa cumpar?
Precizez ca motorul va fi 755/40.
Multumesc si o zi frumoasa
#36 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 31 August 2015 - 01:05 PM
Caranda 12v-7,2Ah sau lipo3S-5000-8000mAh.
Barcute intinse!
Tel. 0744915775
#37 Useril este offline   laurentiu_mr
  • Postari: 17
Postat 31 August 2015 - 01:27 PM
Vezi postareamanolo, la 31 August 2015 - 01:05 PM, a spus:
Cred ca iau Caranda. Ca servo pentru cuve, sunt ok astea?
MG996R Torque Digital Metal Gear Servo for Helicopter RC Car Boat Model
Descriptions:
Gear Type: All Metal Gears
Operating Speed: 0.17sec / 60 degrees (4.8V no load)
Operating Speed: 0.13sec / 60 degrees (6.0V no load)
Stall torque:12kg/cm(6V)
Operation Voltage : 4.8 - 7.2 V
Temperature range: 0℃ to 55℃
Power Supply: Through External Adapter
Stable and Shock Proof. - Metal Gear - Double Ball Bearing - Connector Wire Length 300mm
Compliant with most standard receiver connector: Futaba, Hitec, Sanwa, GWS etc...
Great for truck, Boat, Racing Car, Helicopter and Airplane
Specifications:
Connector wire length:300 mm
Dimension: 54 x 38 x 20 mm
Color: Black[/b]
#38 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 31 August 2015 - 04:51 PM
Power HD1201 sint bune si au consum redus.
Barcute intinse!
Tel. 0744915775
#39 Useril este offline   laurentiu_mr
  • Postari: 17
Postat 31 August 2015 - 05:11 PM
Vezi postareamanolo, la 31 August 2015 - 04:51 PM, a spus:
Merci mult de ajutor.
Ai idee de la ce model de Dacia pot folosi motorul de aeroterma?
#40 Useril este offline   laurentiu_mr
  • Postari: 17
Postat 02 September 2015 - 07:40 AM
Aveti idee ce motor pot sa folosesc ca inlocuitor pentru 755/40? Nu gasesc sa cumpar si vreau sa pun altceva.
Parca nu as vrea sa pun nici de aeroterma de dacia, e destul de vechi si te poate lasa oricand.
#41 Useril este offline   Stavrica George Cristian
  • Postari: 734
  • Inregistrat: 14-August 08
  • Interests:Pescuit, Modelism
Postat 02 September 2015 - 08:32 AM
Cumpara motor de aeroterma de Cielo nou.
tel.0722359121
stavrica.george@gmail.com
#42 Useril este offline   laurentiu_mr
  • Postari: 17
Postat 04 September 2015 - 10:36 AM
Vezi postareaStavrica George Cristian, la 02 September 2015 - 08:32 AM, a spus:
Salut.
Am achizitionat un motor de aeroterma Cielo.
Care e cea mai potrivita coca pentru acest motor? Vreau cu doua cuve.
Ce tip de speed controler sa cumpar si ce tip de baterie e cel mai indicat?
#43 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 04 September 2015 - 12:31 PM
Carp range 3,acumulator 7,2Ah,esc 30A.
Barcute intinse!
Tel. 0744915775
#44 Useril este offline   laurentiu_mr
  • Postari: 17
Postat 04 September 2015 - 12:42 PM
Vezi postareamanolo, la 04 September 2015 - 12:31 PM, a spus:
Merci mult.
E ok asta?
Specifications:
Max cont.current: 30A
Peak current: 40A (10s)
Voltage: 2-3S lixx
BEC: 5V/3A
Item size: 50 * 25 * 8mm / 2.0 * 1.0 * 0.3in
Net weight: 25 g
Package weight:35 g
sau asta
Features:
BEC Power: Yes
Cut Off Voltage: 4V
BEC: Yes
BEC Power: 1.5A/5V
Reset: Throttle Lowest Con.
Current: 30A
Battery Range: 5-10 Cells
#45 Useril este offline   laurentiu_mr
  • Postari: 17
Postat 04 September 2015 - 12:52 PM
Baterie Pb-Acid sau LI-PO?
#46 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 04 September 2015 - 01:32 PM
Sint bune amindoua,difera doar costurile.Lipo ar fi bun unul de 8000mAh.
Barcute intinse!
Tel. 0744915775
#47 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 04 September 2015 - 01:33 PM
Cumpara Carp Range 2 daca mergi pe pb acid.
- 3 daca mergi pe LIPO
Aceasta postare a fost editata de Stavrica George Cristian: 04 September 2015 - 01:33 PM
tel.0722359121
#48 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 04 September 2015 - 03:29 PM
Carp range 2 nu se mai fabrica ,doar 3 si carp range de viteza .
Barcute intinse!
Tel. 0744915775
#49 Useril este offline   laurentiu_mr
  • Postari: 17
Postat 04 September 2015 - 04:07 PM
Vezi postareamanolo, la 04 September 2015 - 03:29 PM, a spus:
Asta inseamna sa cumpar LI-PO.
Cine face carp range 3?
#50 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 04 September 2015 - 06:39 PM
Carp range 3 merge cu plumb.
Barcute intinse!
Tel. 0744915775
#51 Useril este offline   ionutu
  • Postari: 91
  • Inregistrat: 19-February 14
Postat 05 September 2015 - 08:58 AM
salut!
tocmai m-am apucat de montarea cuvelor insa am o dilema,nu vreau sa montez si arcul acela care trage cuva inapoi,este bine ??
#52 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 05 September 2015 - 09:21 AM
Adica sa intelegem ca vrei sa folosesti un singur servo pentru amindoua cuvele? daca cuvele ramin deschise dupa basculare si bate vintul vor avea rolul de vele.
Barcute intinse!
Tel. 0744915775
#53 Useril este offline   ionutu
  • Postari: 91
Postat 05 September 2015 - 11:47 AM
nu,nu vreau sa folosesc un singur servo dar am inteles ca daca folosesc arcuri fortez mai mult servo-urile,totusi din comanda radiocomenzii nu se poate actiona revenirea cuvelor in pozitia initiala ??
Aceasta postare a fost editata de ionutu: 05 September 2015 - 11:50 AM
#54 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 05 September 2015 - 01:32 PM
Daca folosesti 2 servo si legatura cu pirghii intre servo si axe atunci revenirea se face din servouri,telecomanda HK-6S pe canalele 5si 6 face o cursa continua de 90 grade exact cit trebuie pentru cuvare ,chiar nu stiu de unde ideea cu arcuri.
Barcute intinse!
Tel. 0744915775
#55 Useril este offline   ionutu
  • Postari: 91
Postat 06 September 2015 - 08:13 AM
pai asa am facut, actionarea cu parghii (o sa pun poze),dar mai am putintel cu mecanica si voi trece la partea mea preferata electronica,apropo de unde sa cumpar telecomanda HK-6S,este buna (unii zic ca este buna ,,Spring RC'')?
#56 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 06 September 2015 - 09:40 AM
HK-6S o iei direct de la sursa sau de la diversi vinzatori.
Barcute intinse!
Tel. 0744915775
#57 Useril este offline   Rest
  • Postari: 3
  • Inregistrat: 02-November 14
Postat 06 September 2015 - 03:26 PM
Vezi postarealaurentiu_mr, la 04 September 2015 - 12:42 PM, a spus:
Merci mult.
E ok asta?
Specifications:
Voltage: 2-3S lixx
BEC: 5V/3A
Net weight: 25 g
Package weight:35 g
sau asta
Features:
BEC Power: Yes
Cut Off Voltage: 4V
BEC: Yes
BEC Power: 1.5A/5V
Current: 30A
Ti-as recomanda sa nu te complici. Poti contacta pe colegul nostru DigitAll si iti va da exact ce ai nevoie pe partea de electronica.
Omu' este profesionist si functiile modulelor electronice au fost adaptate nevoilor pe parcursul timpului, functii pe care doar in electronicele lui le gasesti.
De exemplu asta am luat si eu : Electronica full si sunt f multumit. De aici nu cred ca este vreun modul care sa nu il fi avut si toate au fost peste asteptarile mele Module
#58 Useril este offline   laurentiu_mr
  • Postari: 17
Postat 08 September 2015 - 07:58 AM
Imi puteti spune ce parere aveti despre cum arata motorul asta?
De miscat se misca bine, dar am nevoie de parerea voastra.
#59 Useril este offline   iony
  • Postari: 2346
  • Inregistrat: 06-April 07
Postat 08 September 2015 - 02:13 PM
ma pui foarte multe intrebari aiurea
ce ai vrea sa vedem noi la motorul acela ??
alege un motor pune-l in serie cu un aparat de masura si vezi cati amp ia in gol daca ia mai mult de 1,5-2 nu este bun , in apa nu trebuie sa treci de un consum mai mare de 6-9amperi
asta daca vrei sa ai fiabilitate
ti s-a spus ce motor sa folosesti ce motare s-ar folosi cu succes la barcute de plantat acum de vrei tu sa inventezi apa calda
cand niste oameni care tot fac barci de nnnnnn ani folosesc doar cateva modele de motoare si ati spun ce sa folosesti tu vii cu alte intrebari despre alte notoare car nu isi au rostul
#60 Useril este offline   laurentiu_mr
  • Postari: 17
Postat 08 September 2015 - 04:00 PM
Vezi postareaiony, la 08 September 2015 - 02:13 PM, a spus:
"ma" baiete, e un forum, am tot dreptul sa intreb. Daca cineva vrea sa-mi raspunda si sa ma ajute, bine, daca nu, nu.
Asta nu inseamna ca trebuie sa sari 3 metri in sus. Daca ai chef de cearta, mergi "ma" pe drumul tau.
Am incheiat orice discutie cu tine "ma"
  • 5 Pagini +
15 useri citesc topicul
