Modelism - RHC Forum: Jurnal de Zbor Bogdan_Bacau - Modelism - RHC Forum
#31 Useril este offline   bogdan_bacau
  • Postari: 778
  • Inregistrat: 23-March 13
Postat 30 September 2015 - 06:01 PM
://www.fireshow.ro/Set-Fumigene-colorate(albastru,verde,galben,portocaliu,rosu)_detalii_126.html
#32 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 01 October 2015 - 01:00 PM
Da...astazi am mai reusit sa fac cate ceva...la morasul asta micut😃 ..am pus elicia..Dar nu prea inteleg o treba...la Rezevor ies 3 tevi..stiu ca una vine la carburator ..una la umplerea rezervorului..dar a 3a??? Aaaa si cu ce fel de benzina merge? Ulei....??? Gasesc la kelemen gata preparat?
í ½í¸í ½í¸í ½í¸í ½í¸
  • Imagine atasata: rps20151001_135652.jpg
  • Imagine atasata: rps20151001_135636.jpg
  • Imagine atasata: rps20151001_135605.jpg
  • Imagine atasata: rps20151001_135547.jpg
  • Imagine atasata: rps20151001_135532.jpg
Aceasta postare a fost editata de bogdan_bacau: 01 October 2015 - 01:01 PM
#33 Useril este offline   cosmin xair
  • Postari: 251
  • Inregistrat: 22-November 14
  • Interests:Distractie
Postat 01 October 2015 - 01:28 PM
Vezi postareabogdan_bacau, la 01 October 2015 - 01:00 PM, a spus:
Da...astazi am mai reusit sa fac cate ceva...la morasul asta micut������ ..am pus elicia..Dar nu prea inteleg o treba...la Rezevor ies 3 tevi..stiu ca una vine la carburator ..una la umplerea rezervorului..dar a 3a??? Aaaa si cu ce fel de benzina merge? Ulei....??? Gasesc la kelemen gata preparat?
a 3 -a e pentru aerisire ca sa nu se vacumeze rez. Benzina la pompa si ulei de la magazin,Raportul ungere: 25: 1 ~ 30: 1 (Break In); 40: 1 ~ 50: 1 (Flying Normal)
#34 Useril este offline   oachidori
  • F22 Raptor Fan
  • Postari: 2391
  • Inregistrat: 05-August 09
Postat 01 October 2015 - 01:50 PM
Bogdan, ia si citeste!! http://www.goldenski...l%20Current.pdf
Olivian Diaconescu
F22 depron
#35 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 01 October 2015 - 04:05 PM
Vezi postareaoachidori, la 01 October 2015 - 01:50 PM, a spus:
Multumesc pt sfaturi 😃😃😃.. Posibil sa gasesc la cei care vand motoscutere...sau Drujbe..??? Cat despre rezervor am inteles...al 3 lea ..sa nu se preseze rezervorul..astazi am facut bancul de probe...am atasat rezervorul..maine pun electrinica.vreau sa pun si un servo pt acceleratie..si sa trag o tija pt soc.Cred ca sambata voi incerca sa il pornesc.
#36 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 02 October 2015 - 11:58 AM
Salutare !!! Astazi am terminat de montat bancul de proba...😃😃 mai ramane de pus intrerupatorul si bateria..si e gata.O sa merg azi sa caut ulei pt benzina..Si sa vad cum fac amestecul..Intrebare ? Cei care aveti motor pe benizna ...cat ulei se pune la un rezervor de 550ml ??? Cateva poze
  • Imagine atasata: rps20151002_125502.jpg
  • Imagine atasata: rps20151002_125427.jpg
  • Imagine atasata: rps20151002_125409.jpg
#37 Useril este offline   oachidori
  • F22 Raptor Fan
  • Postari: 2391
Postat 02 October 2015 - 12:07 PM
Vezi postareabogdan_bacau, la 02 October 2015 - 11:58 AM, a spus:
Cred ca ai pus suportii la motor invers!! sau cel putin eu asa vad din poze.Partea rotunda se pune pe firewall.Eu pun la fiecare litru 33 ml ulei Bel-Ray H1-R Racing 100% Synthetic Ester 2T Engine Oil.
Uite aici ce trebuie sa respecti pentru rodajul motorului:
Start the engine as described above and run the engine using the break-in (Trial) gasoline to oil
mixture (25:1 to 30:1). Use only “Carbon†based 2-cycle oil and not synthetic for the
break-in. Run the engine throughout the allowable rpm range, stopping at incremental setting
between: 1) idle, 2) 25%, 50%, 75%, of max-rpm and at maximum rpm, allowing the engine to run
at each rpm setting for ~ 20% of the run time supported by the fuel tank capacity.
Break in the engine through approximate three to four (3 – 4) gallons of fuel
Olivian Diaconescu
F22 depron
#38 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 02 October 2015 - 03:24 PM
Vezi postareaoachidori, la 02 October 2015 - 12:07 PM, a spus:
😃😃😃😃😃 merci...nu stiu..nu am observat nici eu..le cam pun invers pe toate 😂😂😂😂 Am gasit un ulei sintetic rosu..2T..la rodaj..zice..intre 30/40ml pe Litru.Am sa caut si eu un ulei mai bun.Am fost astazi la 3 magazine...nu prea ai de unde sa alegi..am dat 30 lei pe un litru...erau si sub 10 lei.practic cel mai scump lam luat.Maine o sa incerc sa il pornesc.Sper sa o ia usor..ca nu am demaror.
#39 Useril este offline   Adi-GVA
  • Postari: 739
Postat 02 October 2015 - 03:31 PM
Bogdan, vreau sa-ti zic acum pana nu e prea tarziu: pal-ul acela folosit de tine pentru suportul motor nu o sa reziste la tractiunea si vibratiile motorului.
Acele parti de pal trebuie confectionate din placaj multistrat sau ceva asemanator placii ce ai folosit-o dedesupt (banuiesc un dog de taiat paine in cazul de fata).
Partea frontala pe care ai montat motorul, sta prinsa intr-un eurosurub care de la vibratii se va smulge. Mai cauta pe net cum au facut altii la rodajul motoarelor si foloseste o solutie care a fost verificata.
Succes!
Fly Extreme! __EXTREME FLIGHT
#40 Useril este offline   Mihai_supy
  • Postari: 5156
Postat 02 October 2015 - 03:55 PM
hehe...să filmezi de la distanţă..să nu te lovească dacă o sări...
Nu mai ştiu pe unde am citit, dar rodajul cu ulei sintetic e mai prost decât cel cu ulei mineral. ...adică tocmai a postat cineva ceva în altă limbă despre asta.
La motoarele mele pe benzină scrie să fie rodate cu ulei mineral. Problema la el e că va scoate nişel fum, şi te va face să schimbi bujia mai des...!
#41 Useril este offline   rotax
  • Postari: 109
  • Inregistrat: 15-May 12
  • Interests:zbor 1-1,aeromodelism
Postat 02 October 2015 - 04:52 PM
In Bacau gasesti un ulei marca Motul 710.e un magazin pt motociclisti pe Mioritei,e in jur de 70 lei,eu am facut rodajul la Rotax. si in amestec tot Motul 710 pun.
#42 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 02 October 2015 - 07:04 PM
Vezi postareaAdi-GVA, la 02 October 2015 - 03:31 PM, a spus:
Succes!
Bine ca mi-ai zis...😬😬😬 ma gandeam ca o sa reziste...am bagat vreo 10 negrese de 70mm in el..si am pus si o bucata in "T"...ma gandeam ..ca la relanti...tine.
#43 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 02 October 2015 - 07:07 PM
Vezi postareaMihai_supy, la 02 October 2015 - 03:55 PM, a spus:
Pai...unde am cautat...a zis ca nu exista ulei mineral in 2timpi...doar in 4 timpi..asa mi sa spus.Si eu am cumparat un lei sintetic 2t
https://youtu.be/udYE263WYbc
Un zbor de seara....Scuzati filmarea ...Nu a fost facuta corespunzator.
#44 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 04 October 2015 - 09:48 PM
Salutare.Azi..am incercat timp de vreo 2 ore..sa pornesc motorul.Ma dor mainile la cat am invartit la elicie.Si tot nu am reusit sa il pornesc.Am verificat bujia..dadea scanteie..benzina ii venea..am incercat si cu socul tras..si cu el inchis..in toate felurile.Am strans amandoua jigleoare ..si leam dat o tura jumate..am pus si cu pipeta..benzina direct in carburator..am zis ca poate nu trage benzina....am dat bujia jos..suflata..arsa curatata..schimbat a 2 a bujie..nimik.Nu a vrut sa porneasca.Nici macar un rateu sa dea...ma gandesc ..ca in timpul gauririi pe panou...cand am dat o gaura sa trec o tija pt acceleratie..a intrat poate rumegus..in carburator...zic si eu..nu stiu..o sa desfac carburatorul..si o sa verific.Am alimentat o baterie 1300mh 2c.. ce pot sa mai fac...singura solutie ar fi sa demontez carburatorul sal curat si sa incerc cu demarorul.
Aceasta postare a fost editata de bogdan_bacau: 04 October 2015 - 09:49 PM
#45 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 08 October 2015 - 06:37 PM
Da..Am reusit in sfarsit impreuna cu Dan..sa pornesc acest motor..A pornit usor la el 😃😃 probabil..ia fost frica motorului ce i se va intampla daca nu va porni 😂😂😂
https://youtu.be/agbAmvzsaaE
#46 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 08 October 2015 - 08:58 PM
Pe adresa asta se poate viziona clipul..
https://youtu.be/QyOqgxq_X8o
#47 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 15 October 2015 - 04:45 PM
Salutare.....Azi am iesit la zbor...din pacate am inghetat doar eu 😃😃😃.Nu ....a avut cine sa fimeze..si nici sa faca poze.Doar eu cu ciorile pe camp.Am mai incercat ceva figuri noi ale acrobatiei😉.Ma mai antrenez ...si eu..pentru ca urmeaza sa vina un frate mai mare😃.De data asta ceva mai zgomotos.Daca mai iese cineava la zbor zilele astea sa anunte.Va urma din nou 2 saptamani de ploi si frig.
#48 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 15 October 2015 - 04:49 PM
Si ...era sa uit...Azi am facut primele zboruri din masina.😃😃😃 cica sa te obisnuiesti pentru sezonul rece care va veni.😃😃😃 era sa dau de pamant cu el de vreo 2 ori..e cam greu...dupa care am iesit din masina ..pt siguranta mea.Nu sfatuiesc pe nimeni sa faca asa ceva.
#49 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 15 October 2015 - 08:40 PM
O poza mai veche...😃
  • Imagine atasata: IMG-20151015-WA0025.jpg
#50 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 21 October 2015 - 08:52 PM
Salutare !!! Azi am iesit la un zbor.Eu..Dan si Tudor.Sa zburat cam 2 ore...Vreme perfecta.Ne-am cam luat la intrecere cu Mig-urile 😂😂😂😂 Poate maine daca ne permite vremea o sa mai iesim.
https://youtu.be/Sy74ETT14ys
  • Imagine atasata: rps20151021_214851.jpg
#51 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 22 October 2015 - 08:54 PM
Salutari Dragi Tovarasi 😃😃😯!!!!
Astzi...am avut activitate,nea permis si vremea si am profitat de ocazie.
Sa zburat pana a venit amurgeala.Dan...a zburat un mx2 care avea legata o panglica..😂😂😂 binenteles..motivul era sa o taiem cu elicia...Din 2 modele..adica eu si Tudor nu am reusit sa o taiem.Dar a fost Haossss pe cer 😃😃😃😃 super fain.
  • Imagine atasata: rps20151022_214755.jpg
  • Imagine atasata: rps20151022_214734.jpg
#52 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 22 October 2015 - 08:55 PM
Inca 2 poze..care va urma si clipurile.
  • Imagine atasata: rps20151022_214834.jpg
  • Imagine atasata: rps20151022_214819.jpg
#53 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 22 October 2015 - 09:52 PM
Si un link...cu filmare.😃😃😃
https://youtu.be/vnp_Gp6Y350
#54 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 22 October 2015 - 09:57 PM
Al 2 lea zbor.
https://youtu.be/Q09p6vVk5f4
#55 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 22 October 2015 - 10:03 PM
Si al 3 lea Clip.
A Fost o zi frumoasa.Maine daca tine vremea cu noi...Iesim din nou.La Aerodrom Sarata.incepand cu ora 16:00.Cine mai vrea sa vina ...sunt bine veniti.
https://youtu.be/UWs29PBZ5Ic
#56 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 22 October 2015 - 10:20 PM
Alte poze !
Inca o poza.
  • Imagine atasata: rps20151022_231721.jpg
  • Imagine atasata: rps20151022_231738.jpg
  • Imagine atasata: rps20151022_231750.jpg
  • Imagine atasata: rps20151022_231802.jpg
  • Imagine atasata: rps20151022_231815.jpg
#57 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 23 October 2015 - 07:40 PM
Sa iesit si astazi...la zbor...😃 doar ca de data asta sa zburat la Gheraiesti.Super zi !!! A fost cald...si terenul a foat super.
https://youtu.be/jm3BVmCV7rE
#58 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 25 October 2015 - 06:13 PM
Salutare !!! Astazi...am facut din nou un zbor!!! Eu Dan si Tudor.A fost programat la sarata ora 13:00.Cand am ajuns acolo...aveau activitate cei cu avioanele ultrausoare,asa ca a trebuit sa zburam in alta parte.Am zburat pe un teren in apropiere de centrul de afaceri.Asa ca poze nam facut...nici de filmat nu a avut cine sa ne filmeze...Am facut un ultim zbor cu Sbach-ul .De maine avionul isi schimba detinatorul.Si uite asa trec si eu la urmatorul model.Voi reveni cu cel nou.Pana atunci....Numai de bine.😃😃😃
#59 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 02 January 2016 - 09:48 AM
La Multi Ani 2016!!!
Un an nou...plin de zboruri si aterizari line la toata lumea.A venit mosu din noiembrie...abia astept sa ma apuc de noua achizitie.Ne revedem curand.
#60 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 16 January 2016 - 01:04 AM
Salutare !!! A sosit timpul sa ma mai relaxez si eu...Astazi am reusit sa vad si eu modelul dupa 2 luni.Cam de obicei se intampla tot mai des ca modelele care mi le cumpar sa vina cu defecte din cauza transportului.Am trecut la treaba.Am inceput cu canopia cateva fisuri pe ea..si o gaura pe laterala.😃 Am refacuto cu kit auto.Slefuit..si apoi la vopsit.Si capota are ceva probleme..dar se rezolva.Voi reveni cu poze 😃
  • Imagine atasata: rps20160116_005651.jpg
  • Imagine atasata: rps20160116_005753.jpg
  • Imagine atasata: rps20160116_005813.jpg
31 useri citesc topicul
