Modelism - RHC Forum: OpenXSensor - Modelism - RHC Forum
OpenXSensor Altimetru, Variometru OpenXsensor
#1 Useril este offline   AlexC
  • Postari: 204
  • Inregistrat: 12-June 14
Postat 04 May 2015 - 08:11 AM
https://openxsensor.googlecode.com/svn/wiki/images/OXS_Logo.png
Are cineva de pe forum experienta cu OpenXSensor? A realizat si testat cineva de aici, OpenXSensor ? Mi se pare interesant.
Based on an Arduino platform, it connects to different sensors and transmits the measurements via FrSky telemetry capabilities.
It is both compatible with the D series receivers (HUB protocol) and the new X series rx (Smart Port protocol).
Functionalities provided at your choice :
Altimeter / Variometer (like FrSky Variometer high precision sensor)
Can use a second barometric sensor and switch with TX while flying
Air Speed
Can be used by OXS to compensate vertical speed measurements (dTE)
Up to 6 voltages measurements
Battery voltage measurements (like FrSky FBVS-01)
Lipo battery cell measurements (like FrSky FLVS-01 or FLVSS)
RPM sensor
Current sensor (like FrSky FAS or FCS)
Can calculate the consumed current
Can use any sensor outputting voltage
Temperature sensor
https://code.google.com/p/openxsensor/
Aceasta postare a fost editata de AlexC: 04 May 2015 - 08:15 AM
Postat 04 May 2015 - 10:38 AM
Este o replica la abandonarea de catre Frsky a primului sistem de telemetrie, deoarece nu toata lumea este convinsa de s-port.
A inceput cu OpenVario, pentru a avea un vario adevarat si fara sa ai Taranis, si apoi s-a extins.
Poate fi o solutie cand ai nevoie de o configuratie de telemetrie nesatisfacuta de nici unul din sistemele actuale. Si indemanarea sa te pui la construit :)
#3 Useril este offline   AlexC
  • Postari: 204
Postat 04 May 2015 - 12:39 PM
Vezi postarearenatoa, la 04 May 2015 - 10:38 AM, a spus:
Multumesc pentru detalii. Mi se pare foarte interesant de pus in practica. Totodata cred ca se obtine ceva la un foarte bun raport calitate/pret.
Desi multi zburatori profesionisti nu considera a fi prea util un variometru pentru zborul in termica, concluzia mea dupa mai multe zboruri cu variometru : variometrul este un accesoriu extraordinar si nu util ci foarte util pentru zborul in termica.
Postat 04 May 2015 - 01:27 PM
Dar poti avea variometru si fara sa construiesti ceva ca mai sus, si costa doar 24$, nu vad cum ai scoate ceva mai ieftin... :unsure:
Cei care au zburat langa mine la RR acum 2 zile l-au putut auzi la lucru.
Evident, se poate invoca placerea de a construi :)
Aceasta postare a fost editata de renatoa: 04 May 2015 - 01:30 PM
#5 Useril este offline   AlexC
  • Postari: 204
Postat 04 May 2015 - 01:33 PM
Vezi postarearenatoa, la 04 May 2015 - 01:27 PM, a spus:
Am variometrul FrSky Hiprecision. Este extraordinar si consider ca am facut o alegere buna cumparand acest accesoriu. Are un singur minus. Pe cat de bine functioneaza si pe cat de precis, pe atat de simplist, multe prea simplist, este la capitolul sunete. Consider ca ceea ce ii lipseste este variatia tonalitatii la viteza de urcare. Ar fi ideal daca ar avea posibilitatea sa-ti indice vocal, la un anumit , altitudinea. dar fara sa recurgi la alta statie ci doar la display-ul FLD FrSky.
Aceasta postare a fost editata de AlexC: 04 May 2015 - 01:37 PM
Postat 04 May 2015 - 01:37 PM
De acela vorbeam si eu, mie chiar imi ajunge un singur sunet, cred ca as obosi mai repede daca as avea variatii continue, chestie de gust.
Dar, cum ziceam mai sus, daca te mananca microbu sa faci ceva, stiu cum e :)
#7 Useril este offline   AlexC
  • Postari: 204
Postat 04 May 2015 - 01:41 PM
Vezi postarearenatoa, la 04 May 2015 - 01:37 PM, a spus:
Ma tenteaza sa incerc construirea unui VarioXSensor. Sa fac mai intai o lista cu ce componente imi sunt necesare si apoi mai vad.
8 useri citesc topicul
