Modelism - RHC Forum: F14 - putin ajutor - Modelism - RHC Forum
F14 - putin ajutor
#1 Useril este offline   Loredan
  • Postari: 16
  • Inregistrat: 03-March 16
Postat 04 March 2016 - 01:51 PM
Buna ziua, as avea nevoie de putin ajutor.
Nu stiu ce CWW Prop ar fi bun si daca componentele de mai jos sunt bune. Este primul avion creeat de mine. Multumesc anticipat!
http://gaja.ro/f14-a.jpghttp://gaja.ro/f14-b.jpg
F14 - 87cm - 7.4v
Material: Depron 6mm
Grame: 68 (fara mecanisme)
Toate componentele sunt de pe hobbyking.
----------------MOTOR-------------------
Turnigy 2205/34 1500kv Brushless Motor
RPM/v: 1500kv
Dimensions: 27.5 x 20.5mm
Shaft: 3.0mm
Voltage: 6v~13v
Weight: 33g
No-load current: 0.8A
Max Current: 12A
Max Watts: 130W
Mounting Holes: 19~16mm
Prop Data:
0843 - 7.4v - 360g Thrust
---------------ESC----------------------
TURNIGY Plush 18amp Speed Controller w/BEC
Cont Current: 18A
Burst Current: 22A
BEC Mode: Linear
BEC : 5v / 2A
Lipo Cells: 2-4
NiMH : 5-12
Weight: 19g
-------------Servo----------------------
HXT500 Micro Servo 0.6kg/0.08sec/6.2g
Voltage : 4.8v ~ 6v
Weight: 6.2g
Speed : 0.08 sec/60 (4.8V) 0.07 sec/60 (6.0V)
Torque : 0.6 kg-cm (4.8V) 0.8 kg-cm (6.0V)
Working Temp : -30C~60C
Teflon Bushing, 15cm wire, coreless motor
--------------Battery--------------------
Turnigy nano-tech 1600mah 2S 25~50C Lipo Pack
Capacity: 1600mAh
Voltage: 2S1P / 2 Cell / 7.4V
Discharge: 25C Constant / 50C Burst
Weight: 103g (including wire, plug & case)
Dimensions: 118x32x15mm
Balance Plug: JST-XH
Discharge Plug: XT60
----------Radio&Receiver------------------
Turnigy 6X FHSS 2.4ghz Transmitter and Receiver (Mode 2)
Turnigy 6X Transmitter Specs:
Resolution: 1024
Frequency: 2.4ghz ISM Frequency Range
Modulation: GFSK
Spread Spectrum Mode: FHSS
Number of Frequency Channels: 20
Hopping Rate: 125 jump/s
Output Power: <=20dbm
Working Current: <=150mA
Working Voltage: 1.2v x 4 (AA/Nimh)
Dimensions: 200mm x 185mm x 105mm
Turnigy XR700 Receiver Specs:
Channel: 7 (inc RX Battery Input)
Frequency: 2.4g ISM Frequency Range
Power: 4.5v ~ 9.6v/<30ma
Net Weight: 11.5g
Dimensions: 41mm x 28mm x 14mm
#2 Useril este offline   Robin671
  • Postari: 155
  • Inregistrat: 24-March 15
  • Interests:Aeromodele,Electronica,Mecanica,Fotografie...
Postat 04 March 2016 - 10:09 PM
Maine îți răspund..
#3 Useril este offline   Loredan
  • Postari: 16
Postat 05 March 2016 - 01:19 AM
Vezi postareaRobin671, la 04 March 2016 - 10:09 PM, a spus:
Maine îți răspund..
Ok. Ms!
#4 Useril este offline   nicolas
  • Postari: 697
  • Inregistrat: 06-October 06
Postat 05 March 2016 - 08:59 AM
Eu as pune o elice 7x3.7x4 cu un acumulator de 850-1000mA 3s ,cu doua celule e posibil sa fie cam puturos.
Its nice to be important, but its more important to be nice ...
#5 Useril este offline   Loredan
  • Postari: 16
Postat 05 March 2016 - 12:40 PM
Vezi postareanicolas, la 05 March 2016 - 08:59 AM, a spus:
radio&receiver pt 11.1v is cam scumpe, de aceea am ales pe 7.4v. Telecomanda Turnigy 6x fhss am vazut ca are si elevon mixing, ceea ce imi trebuie si mie pentru acest avion.
#6 Useril este offline   aeromax
  • Postari: 523
  • Inregistrat: 12-May 11
Postat 05 March 2016 - 03:08 PM
Vezi postareaLoredan, la 05 March 2016 - 12:40 PM, a spus:
Nicolas ti-a sugerat sa alimentezi motorul cu o baterie 3S (Li-Po)nu Tx-ul sau RX-ul. Elicea de 8 inch este cam mare si este posibil sa induca o miscare de ruliu. O elice de 6-7''ar fi OK - daca motorul poate fi alimentat cu 3S.
Daca esti la inceput de drum, este util sa ai in preajma ta un areomodelist cu experienta.
Cer senin si zboruri reusite !
#7 Useril este offline   Robin671
  • Postari: 155
Postat 05 March 2016 - 06:35 PM
Felicitari,frumos model.
Si eu recomand,elice maxim 7/4 si o baterie LIPO 3S minim 1000 mah si max 1500 mah.
Poate si servo as fi folosit hxt900 9 grame la acea anvergura si daca ar fi posibil chiar si servo cu angrenaje metalice.(sunt mai rezistente la socuri)
Bafta
#8 Useril este offline   Loredan
  • Postari: 16
Postat 06 March 2016 - 12:13 AM
Va multumesc!
