Sistemul AFHDS2A are functia de identificare automata, care poate comuta automat între modul de comunicare cu un singur sens și modul de comunicare în ambele sensuri (telemetrie).
AFHDS2A este construit in codificare canal multiplu cu corectare a erorilor, care îmbunătățesc stabilitatea comunicării, reduce raportul de eroare si extinde distanța de transmisie.
Fiecare transmițător are un ID unic care impiedica interferenta cu alte radiocomenzi aflate in apropiere
Features:
• 6 channel 2.4ghz radio with telemetry capability
• Dual Rate/Trims/Gear/Flap/Gyro Gain Adjust/Flight Mode/Throttle Hold/Hover Pitch Switches
• Easy to use Programming & Navigation Buttons
• Supports Heli/Standard Wing/Elevon/V-Tail
• 20 Model Memory
• 8 Character Model Name
• Trainer port
• Backlit LCD Screen displays real time transmitter and receiver voltage
• 4 Stick Mode Selectable
• Optional telemetry receivers and sensors available separately
Basic Programming Functions:
Dual Rates
Sub Trim
Travel Adjust
Channel Reverse
Swash Mix
Gyro Sensitivity
Throttle Curve
Monitor
Pitch Curve
Throttle Hold
Model Name
Timer
FlySky - i6 Transmitter Specs:
Frequency: 2.4ghz ISM Frequency Range
Modulation: GFSK
Spread Spectrum Mode: AFHDS 2A and AFHDS
Band: 142
Number of Frequency Channels: 20
Output Power: <=20dbm
Working Current: <=100mA
Working Voltage: 1.5v x 4 AA
Dimensions: 174x89x190mm
Weight: 392g
Resolution: 1024 bit
Stick Mode: Mode 2 (Throttle Left)
FlySky - i6 Receiver Specs:
Channel: 6
Frequency: 2.4g ISM Frequency Range
Power: 4.5V~6.6V/<30ma
Net Weight: 6.4g
Dimensions: 40.4x21.1x7.35mm
Requires:
4 x AA Type Battery For Operation
Pret 310lei.
Transportul (24lei-ramburs inclus) prin Fan Courier il suporta cumparatorul.
Trimit cu Posta Romana doar cu plata in avans 310+14lei.
Telefon 0722608545 Laurentiu
Number of downloads: 42 -
Aceasta postare a fost editata de laurcon: 15 April 2015 - 07:01 AM
