Modelism - RHC Forum: APM:pilot - Modelism - RHC Forum
APM:pilot bad gps health
#1 Useril este offline   mobi
  • Postari: 508
  • Inregistrat: 27-May 04
Postat 11 April 2015 - 07:39 AM
Hello people.
I have a Crius V1/Hobbyking board and Cn-06 gps (i presume it's ublox), flashed with Apm plane 2.74b R4 beta reporting "bad gps health" no matter what. I have strong gps lock with low hdop, and no problem whatsoever with gps. Same board flashed with apm copter reports no gps problem.
As a result, Guided mode can't be activated, it triggers RTL, i presume because of bad gps health issue.
Any suggestion welcomed. Thanks in advance.
  • Imagine atasata: ublox yellow.jpg
#2 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3622
  • Inregistrat: 09-June 07
Postat 11 April 2015 - 10:04 AM
Try to change the firmwear of the GPS .
https://github.com/j...ius%29-CN-06-V2
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
Postat 11 April 2015 - 11:46 AM
In Satu Mare se vorbeste engleza acum ? :)
#4 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3622
Postat 11 April 2015 - 12:46 PM
S-a USA-izat nordul tarii. :rolleyes:
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
Postat 11 April 2015 - 12:48 PM
Primiti imigranti ? :D Green card, loterie ceva ? lol
Aceasta postare a fost editata de renatoa: 11 April 2015 - 12:49 PM
#6 Useril este offline   mobi
  • Postari: 508
Postat 11 April 2015 - 03:15 PM
Scuze, dar am dat copy/paste de pe forumul apm, acolo nu mi-a raspuns nimeni. Lenesul nu se dezminte, am lasat in engleza.
Am pus alt firmware, dar nu mai pot accesa boardul deloc. Doar cu versiunea sus-amintita totul pare ok, mai putin problema cu bad gps health.
E drept, nu am modificat firmware de pe gps, pentru ca nu am adaptor ftdi, si mi-am inchipuit ca daca pe apm copter nu da erori, atunci gps e ok.
Aceasta postare a fost editata de mobi: 11 April 2015 - 03:19 PM
#7 Useril este offline   ctotth
  • Postari: 985
  • Inregistrat: 22-April 04
Postat 12 April 2015 - 12:52 AM
apm mai vechi ai incercat?
#8 Useril este offline   mobi
  • Postari: 508
Postat 12 April 2015 - 08:22 AM
Am avut intentia, dar se pare ca orice flasher iau de pe megapirate, la apm plane nu am decat 2.76 sau 2.74beta.
#9 Useril este offline   ctotth
  • Postari: 985
Postat 22 April 2015 - 02:40 AM
poate ajuta asta? http://dev.ardupilot...ings/gps_input/
sunt diverse info pe-acolo
aici sunt mai multe versiuni de fisiere hex, undeva jos e un folder "stable".. si-s si alea mai vechi. http://firmware.diydrones.com/Plane
#10 Useril este offline   SerjuRO
  • Postari: 887
  • Inregistrat: 23-July 09
Postat 23 April 2015 - 07:43 AM
Este cam ciudat pt ca logic ar fi sa treaca in LAND or circle (asa este la APM), intrucat fara GPS, nu ar avea cum sa faca RTL ..........
#11 Useril este offline   ctotth
  • Postari: 985
Postat 23 April 2015 - 12:22 PM
In APM GPS-ul de la Ublox trebuie configurat in mod binar, cu 38400, 10Hz.
In versiuni mai vechi chestia asta se facea folosind un soft de configurare U-Center de la Ublox, pentru a incarca un fisier de configurare de la 3DR.
GPS-urile cumparate de la 3DR vin deja configurate.
In versiuni mai noi de APM nu mai e necesara preconfigurarea GPS-ului, o face firmware-ul APM-ul la initializare.
Dar si la cele noi am impresia ca depinde de ce optiuni a fost compilat firmware-ul APM.
vezi cum se selecteaza optiuni de compilare aici http://www.hobbyking...1X846863X49.pdf
Asta presupune ca ai incarcate sursele si mediul de compilare. Nu stiu ca n-am folosit APM, doar m-am documentat putin sa vad daca-mi foloseste la alta aplicatie.
Un punct de start ar fi sa verifici cum e setat GPS-ul, pe 9600 cu protocol NMEA sau pe 38000 cu protocol binar Ublox.
Softu Ublox pt configurare e aici: http://www.u-blox.co...r/u-center.html
O problema e daca nu ai adaptor, GPS-ul foloseste comunicare seriala TTL la 3.3V, iti trebuie adaptor USB FTDI. Pentru asta exista un program pentru APM, care pune pilotul APM in mod passthrough serial, a.i. poti folosi placa APM in loc de FTDI pentru comunicarea usb<->serial<->APM<->GPS
aici e softul care transforma placa APM in passthrough pentru GPS http://ardupilot.com/downloads/?did=93
aici povesteste ceilalti pasi, ce ziceam mai sus http://copter.ardupi...mmon-ublox-gps/
Aceasta postare a fost editata de ctotth: 23 April 2015 - 12:24 PM
#12 Useril este offline   icsss
  • Postari: 2085
  • Inregistrat: 16-May 10
Postat 05 May 2015 - 10:21 PM
Pe un setup aproape identic, planeNG-ul 2.76 merge OK in toate modurile.
Singura eroare este "bad compass health", dar se pare ca planeNGul nu foloseste compassul in nici un mod de zbor.
Nu imi este clar daca ai incercat doar 2.74beta sau daca ai aceeasi problema si pe 2.76.
Te-ai gandit ca "beta" ala sa fie problema? Ultima versiune stabila de planeNG e 2.76.
PS: Asta e al 3-lea topic deshis pentru Arduplane. Nu-i OK.
