Modelism - RHC Forum: Componente imprimante 3D - Modelism - RHC Forum
#1 Useril este offline   ldanut
  • Postari: 32
  • Inregistrat: 04-December 14
Postat 16 February 2015 - 05:05 PM
Filament ABS/PLA 1.75mm 1kg - 110RON
Filament ABS/PLA 1.75mm 100g - 12RON
Kit componente plastic Smartrap - 200RON
Kit componente plastic Smartrap (fara carcasele la electronice) - 150RON
Kit componente plastic imprimanta delta Kossel - 150 RON
Surub trapezoidal 8mm - 100 RON
Cupla motor 8mm - 5mm - 20 RON
Rulment liniar LM8UU - 8 RON
Rulment liniar LM6UU - 8 RON
Ax ghidaj 8mm - 20 RON / metru
Ax ghidaj 6mm - 30 RON / metru
Rulment radial 608ZZ - 3 RON
Curea GT2 - 15 RON / metru
Roata dintata GT2 cu 20 sau 16 dinti - 15 RON
RAMPS KIT - 250RON
Arduino ATMEGA2560 - 80RON
RAMPS Shield - 80 RON
LCD + SD 20x4 - 80RON
Driver 2A A4988 - 20RON
Driver 2.5A DRV8825 - 30RON
Placa electronica MKS Gen V1.1 - 200RON
Placa electronica Azteeg X5 mini 32BIT All-in-one Controller - 700RON
Sursa 12V 30A - 150 RON
Motor pas cu pas Nema17 1.7A - 60 RON
Motor pas cu pas cu reductie 5.18:1 - 300RON
Servomotor 3.7G - 25RON
Endstop mecanic - 20RON
Endstop optic - 30RON
Endstop Hall - 50RON
Microcontact SS-5GL - 10RON
Ventilator 12V 40x40x10mm - 20RON
Ventilator 12V 40x40x20mm - 20RON
Cablu usb pentru panou - 20RON
Roata dintata inox MK8 - 30RON
Tub bowden - 10RON / metru
Conector pneumatic bowden (filet 10mm sau 5mm) - 20RON
Cap printare J-Head (complet echipat) - 200RON
Cap printare Aluhotend (complet echipat) - 200RON
Rezistenta de incalzire tip cartus - 20RON
Termistor NTC 100k cablat - 20RON
Kit pat incalzit (sticla borosilicat + arcuri + termistor + fire) - 160RON
Pat incalzit MK2B - 90RON
Pat incalizt MK3 din aluminiu - 150RON
Sticla borosilicata 213mm x 200mm - 100RON
Arcuri diferinte marimi - 5RON/BUC
#2 Useril este offline   Jetsan
  • Postari: 11
  • Inregistrat: 11-February 10
Postat 07 April 2015 - 09:21 AM
Din ce oras esti?
Ma intereseaza deoarece mai am nevoie repede de cate ceva si sa stiu cum e cu transportul.
Aceasta postare a fost editata de Jetsan: 07 April 2015 - 09:22 AM
#3 Useril este offline   ldanut
  • Postari: 32
Postat 07 April 2015 - 09:53 AM
Sunt din Iasi.
