Modelism - RHC Forum: Redcat Dunerunner 1/5 4x4 32cc fuelie - Modelism - RHC Forum
  • 25 Pagini +
Redcat Dunerunner 1/5 4x4 32cc fuelie Evaluare topic: -----
#181 Useril este offline   dan_mitea
  • Postari: 9329
Postat 31 March 2015 - 01:00 PM
Cred ca tot
http://www.ebay.com/...=item4adeff1d8f
este mai bun. Iti da exact valoarea tensiunii, este mai mic, mai ieftin, etc.
Masina arata bestial, felicitari.
#182 Useril este offline   Ice_2k
  • Postari: 639
  • Inregistrat: 19-January 15
Postat 31 March 2015 - 03:05 PM
Le-am vazut si p-alea cu cifre dar l-am preferat p-asta pt ca mai usor vad din mers un bec galben/rosu decat vad 5.9 schimbat in 5.8. In plus, daca vreau neaparat sa stiu tensiunea, a venit cu un tabel care zice ce inseamna fiecare led, de la 6.5V pana la 5.85V parca.
1/5 Redcat Rampage DuneRunner v3 32cc 4x4
#183 Useril este offline   Superman
  • Postari: 1274
  • Inregistrat: 16-January 11
  • Interests:Berea,femeile si masinile ;)
Postat 31 March 2015 - 03:59 PM
de unde ai luat garniturile alea pentru carburator?ca am si eu nevoie de alea 2 de sunt intre carburator si motor
#184 Useril este offline   Ice_2k
  • Postari: 639
Postat 31 March 2015 - 04:56 PM
Tot ce era in poza de mai sus e de la DDM.
#185 Useril este offline   Ice_2k
  • Postari: 639
Postat 01 April 2015 - 08:17 AM
Back in business :) Plus "burdufe planetara" pline cu vaselina.
https://www.dropbox.com/s/hju1ifgjtw8jb8e/photo%2001.04.2015%2C%2009%2012%2043.jpg?dl=1
https://www.dropbox.com/s/7fiij7mgyp95vrd/photo%2001.04.2015%2C%2009%2013%2012.jpg?dl=1
https://www.dropbox.com/s/gm9534o9fvp66uy/photo%2001.04.2015%2C%2009%2013%2035.jpg?dl=1
#186 Useril este offline   soarece
  • Postari: 2860
  • Inregistrat: 03-January 13
Postat 01 April 2015 - 10:27 PM
Vezi postareaIce_2k, la 01 April 2015 - 08:17 AM, a spus:
..."burdufe planetara" ....
CVD-uri chiar....is cele stock ?
alta culeasa din popor :
R: Pen`ca poate."
#187 Useril este offline   Sere4uall
  • Postari: 580
  • Inregistrat: 11-October 08
Postat 01 April 2015 - 11:15 PM
da ciocanul?? :D
Off-road: HPI Baja 5sc SS 1:5
Losi 8ight-T 2.0 - 4WD Truggy
Traxxas Summit
On-road: HPI Mirco RS4 -4WD 1:18
Mini-Z
Tamya MR-03 Alfa Romeo Giulieta -2WD 1:10
Spektrum DX-3E
Spektrum DX-3S
#188 Useril este offline   Ice_2k
  • Postari: 639
Postat 02 April 2015 - 10:36 AM
Vezi postareasoarece, la 01 April 2015 - 10:27 PM, a spus:
Da, planetarele sunt stock, sunt CVD-uri si pe fata si pe spate. Am adaugat doar burdufurile.
Vezi postareaSere4uall, la 01 April 2015 - 11:15 PM, a spus:
da ciocanul?? :D
N-a mai fost nevoie de el de data asta, au iesit toate de buna voie :p (sau de frica ca aduc ciocanul :rofl:)
P.S. Voltwatch-ul pe masina, se vede perfect chiar si in soare puternic:
https://www.dropbox.com/s/qs6x6kxup2x4vq9/IMG_6414.JPG?dl=1
Partea negativa e ca am impresia ca am probleme cu radio-ul. O sa mai incerc si-n alta zi, poate mai folosea cineva ceva in zona care-mi cauza glitch-urile, cert e ca mi s-a intrerupt complet comunicatia de 2 ori azi la distante f mici (max 20m), desi am rulat si la 200m fara probleme. Una din dati s-a intamplat cu acceleratia aproape blana si masina la viteza mare, daca nu aveam kill-switch-ul eram mancat pentru ca, pentru un motiv care-mi scapa, failsafe-ul nu s-a activat. Daca testez cu oprirea emitatorului, failsafe-ul functioneaza ok si aplica frana dar de data asta nu s-a intamplat, nu mi-e clara cauza. Convingerea mea ca un kill-switch e esential a crescut de 10 ori :pardon: Daca se mai repete problema, probabil ca se intrevede un upgrade la radio, poate iau ceva cu telemetrie cu ocazia asta.
De asemenea, improvizatia mea de a carpi cupla aia de la evacuare dupa ce-am rupt-o ca prostul a cam dat chix dupa o ora de rulare, a pleznit de tot. Sa vad daca mai ma complic sa caut sa cumpar una noua sau pun direct JetPro-ul si aia e.
Aceasta postare a fost editata de Ice_2k: 02 April 2015 - 10:41 AM
#189 Useril este offline   Ice_2k
  • Postari: 639
Postat 03 April 2015 - 09:52 AM
Am umblat putin ieri in cutia bateriei sa ma asigur ca n-am vreun conector care nu face contact ca lumea (ceea ce ar putea explica problema de ieri, mai ales ca am indesat foarte multe chestii in plus si stau toate cablurile pe-acolo f ingramadite) si am mai iesit azi vreo 40min, no glitch. Sper sa ramana asa...
In alta ordine de idei, azi am participat la problema gropilor din Bucuresti :)) In locatia unde ma dadeam se lucra la asfalt si, pe perioada cat am stat eu acolo, toate lucrarile s-au oprit :))) Toti muncitorii erau spectatori. Cel mai tare a fost soferul de pe betoniera care statea in masina, cu motorul pornit si cimentul invartindu-se, si se uita cum ma joc eu :))
Bateria de 5000mAh pare sa fi fost o investie super buna, dupa ~1h20min mi s-a dus doar o liniuta (din 7) pe voltwatch.
Aceasta postare a fost editata de Ice_2k: 03 April 2015 - 09:54 AM
#190 Useril este offline   soarece
  • Postari: 2860
Postat 03 April 2015 - 11:12 PM
cu o statie buna nu ai probleme si nici de kill-switch nu ai nevoie.....Azi am probat si eu pe gunoiul meu de HPI TF-40 ce s-ar intampla daca se deconecteaza acumulatorul sau daca scade brusc tensiunea.....am scos mufa de la baterie in timp ce acceleratia e trasa,ce crezi ca s-a intamplat ? pai servo-ul s-a tras automat pe pozitia de idle,cum naiba nu-mi explic.....si asta s-a intamplat pe tf-40,gandeste-te ca pe o statie buna se intampla acelasi lucru....plus ca ai si fail-safe cum am si eu pe a mea....deci ideea era ca s-ar ptea sa interfereze ceva pe acolo la tine,ori rahatu' :good: ala de kill ori ai vreun BEC ceva ? o statie medie de auto in 2.4 bate 50m fara probleme...
Aceasta postare a fost editata de soarece: 03 April 2015 - 11:12 PM
R: Pen`ca poate."
#191 Useril este offline   Ice_2k
  • Postari: 639
Postat 04 April 2015 - 07:59 AM
Cred ca a fost un contact aiurea undeva care a taiat curentul, cu o zi inainte umblasem la fire pe-acolo deci probabil ca nu era ceva ok. In cazul tau probabil arcul de la carburator o fi tras inapoi servo-ul, altceva nu are ce sa fie. Nu are ce legatura sa aiba cu statia daca ai lasat-o fara curent. Eu am facut testul asta si intr-adevar carburatorul trage putin de servo inapoi dar in niciun caz pana la idle.
#192 Useril este offline   Ice_2k
  • Postari: 639
Postat 06 April 2015 - 12:38 PM
Are cineva experienta cu radio-ul FlySky FS-IT4?
#193 Useril este offline   soarece
  • Postari: 2860
Postat 06 April 2015 - 04:36 PM
tot nu ai raspuns....BEC sau UBEC sau SBEC ai pe ea ? daca ai, sa stii ca de acolo ti se trage cu pierdutul de semnal !
R: Pen`ca poate."
#194 Useril este offline   Ice_2k
  • Postari: 639
Postat 06 April 2015 - 05:10 PM
nu stiu ce sunt alea. Referitor la radio, am mai folosit-o w/e-ul asta, all good. Nu d-aia ma uit dupa alt radio, ci pentru ca asta de care am intrebat are telemetrie, ceea ce vreau neaparat.
#195 Useril este offline   soarece
  • Postari: 2860
Postat 06 April 2015 - 09:04 PM
Vezi postareaIce_2k, la 06 April 2015 - 05:10 PM, a spus:
nu stiu ce sunt alea. ...
BEC= Battery Eliminator Circuit ...
telemetrie ? iti plac gadgeturile ? cu banii aia mai bine iti iei o pereche de bulkhead-uri de aluminiu :good: sau un slipper(daca merge pus pe masina aia).
Aceasta postare a fost editata de soarece: 06 April 2015 - 09:04 PM
R: Pen`ca poate."
#196 Useril este offline   Ice_2k
  • Postari: 639
Postat 06 April 2015 - 10:57 PM
In cazul asta, nu, n-am BEC. Si da, imi plac gadget-urile :) Plus ca mi se pare interesant sa vezi in timp real viteza masinii, temperatura motorului, rpm etc :)
#197 Useril este offline   Ice_2k
  • Postari: 639
Postat 07 April 2015 - 12:37 AM
http://youtu.be/E-zTva2UmNM ... interesant
#198 Useril este offline   Ice_2k
  • Postari: 639
Postat 09 April 2015 - 12:45 AM
Tocma' am terminat al 3lea rezervor, cred ca pot considera rodajul gata... de maine WOT :)
Ceva imagini de azi: http://youtu.be/P3ooQTswqms
Aceasta postare a fost editata de Ice_2k: 09 April 2015 - 12:46 AM
#199 Useril este offline   hassel
  • Postari: 2464
  • Inregistrat: 02-February 12
Postat 09 April 2015 - 07:21 AM
Se aude frumos. Ruleaza frumos si accelereaza liniar. Cred ca o sa te satisfaca la full throttle :)
BAJA
5SC 30cc gas
#200 Useril este offline   Ice_2k
  • Postari: 639
Postat 09 April 2015 - 08:19 AM
Da, sunt f incantat de cum a evoluat pe parcursul rodajului :) Zilele astea ies sa-i dau si WOT si cred ca fac si reglajele cum trebuie la carb
#201 Useril este offline   Ice_2k
  • Postari: 639
Postat 14 April 2015 - 07:59 PM
Am fost azi pe la pista din tineretului dar e mica rau pt 1/5, mai ales benzinar.... M-am dat in loc cu jucaria de rezerva, inca n-am gasit un loc ca lumea pt asta mare :(
https://www.dropbox.com/s/ra5au7dcgjzak1x/photo%2014.04.2015%2C%2020%2055%2038.jpg?dl=1
#202 Useril este offline   Superman
  • Postari: 1274
Postat 19 April 2015 - 10:59 PM
pai pista din tineretului se stie de cand ca e mica pentru 1/5 cel mai bine e pentru ele e un camp ceva
#203 Useril este offline   Ice_2k
  • Postari: 639
Postat 20 April 2015 - 10:00 AM
Vorba bancului, eu acum am aflat :))
Btw, aveti idee de unde pot gasi loctite rosu pe la noi la sticla mai mica de 50ml? Cel albastru se gaseste dar rosu nu prea... si rosu am nevoie doar pt 2 suruburi, la evacuare, deci n-are rost sa iau ditamai sticloiu'
#204 Useril este offline   Ice_2k
  • Postari: 639
Postat 22 April 2015 - 01:22 AM
Work in progress:
https://www.dropbox.com/s/ch50vhx3rh1rw1x/photo%2022.04.2015%2C%2001%2048%2034.jpg?dl=1
https://www.dropbox.com/s/6ebnl9egnucvfij/photo%2022.04.2015%2C%2001%2048%2047.jpg?dl=1
https://www.dropbox.com/s/g3z6y7xh76e5zvk/photo%2022.04.2015%2C%2001%2048%2057.jpg?dl=1
https://www.dropbox.com/s/sz7uk4vqnvpee4h/photo%2022.04.2015%2C%2001%2049%2008.jpg?dl=1
https://www.dropbox.com/s/uf14lwger7omm1k/photo%2022.04.2015%2C%2001%2049%2019.jpg?dl=1
https://www.dropbox.com/s/o8fl9nntr8yjqmy/photo%2022.04.2015%2C%2001%2049%2030.jpg?dl=1
https://www.dropbox.com/s/cdqsz57v3nwrlas/photo%2022.04.2015%2C%2001%2049%2045.jpg?dl=1
https://www.dropbox.com/s/phr67hjkmymr6ij/photo%2022.04.2015%2C%2001%2049%2056.jpg?dl=1
#205 Useril este offline   Ice_2k
  • Postari: 639
Postat 22 April 2015 - 11:57 PM
Am iesit azi la niste teste putin, sunt complet socat! Baietii aia care au facut dyno si au aratat crestere de 2cp cu evacuarea custom nu minteau! Este absolut ridicol cum se comporta masina acum fata de cum mergea inainte sa pun evacuarea. Pe cat e de galagioasa, pe-atat e de dementa! Daca n-as fi facut modificarea cu mana mea, n-as fi crezut nici in ruptul capului ca singura diferenta e o evacuare!
#206 Useril este offline   hassel
  • Postari: 2464
Postat 23 April 2015 - 05:27 AM
Si eu cand ziceam despre o evacuare ca face diferenta intre melc si turbo-melc? La motoarele in doi timpi e diferenta si mai mare ca la cele in patru timpi. Tare as vrea si eu o ddm pe a mea, chiar daca am tuned pipe, ddm face treaba mai buna.
BAJA
5SC 30cc gas
#207 Useril este offline   Ice_2k
  • Postari: 639
Postat 23 April 2015 - 08:02 AM
A mea e JetPro, nu DDM. Ma bate gandul sa iau de la ei si un silencer, nu face minuni dar reduce semnificativ dB si atat producatorul cat si cei care le-au folosit spun ca ofera si un mic plus de putere. La 40$ ar putea fi o idee buna.
Aceasta postare a fost editata de Ice_2k: 23 April 2015 - 08:03 AM
#208 Useril este offline   Ice_2k
  • Postari: 639
Postat 24 April 2015 - 01:34 AM
Vented clutch housing :)
https://www.dropbox.com/s/zgigfct8emmtwrk/photo%2024.04.2015%2C%2002%2027%2045.jpg?dl=1
https://www.dropbox.com/s/7ycav75be5ut36e/photo%2024.04.2015%2C%2002%2027%2057.jpg?dl=1
https://www.dropbox.com/s/s7hj8p9rnw0ea8p/photo%2024.04.2015%2C%2002%2028%2009.jpg?dl=1
#209 Useril este offline   Ice_2k
  • Postari: 639
Postat 28 April 2015 - 04:27 PM
Aveti idee unde gasesc o scula pt reglarea distantei bujiei? Am luat niste NGK CMR7H si ma asteptam sa fie reglate din fabrica dar aparent nu....
#210 Useril este offline   revolt
  • Postari: 590
  • Inregistrat: 25-February 15
Postat 28 April 2015 - 04:41 PM
Vezi postareaIce_2k, la 28 April 2015 - 04:27 PM, a spus:
scula se cheama LERA si cred ca o gasesti la piese auto..
Aceasta postare a fost editata de revolt: 28 April 2015 - 04:44 PM
Hpi Savage Flux XL 3 diffs
Hpi Savage Flux XL
Hpi Savage Flux
  • 25 Pagini +
27 useri citesc topicul
