Modelism - RHC Forum: Vand Regulator ESC prin racire cu apa S70A - Modelism - RHC Forum
#1 Useril este offline   abdesign
  • Postari: 79
  • Inregistrat: 02-January 06
Postat 11 January 2015 - 03:12 PM
PRET fix: 300 lei
Tel: 0740 410 036
Specifications
Input Voltage: 2-6LiPo Batteries
Continuous current output:70A
The maximum allowable instantaneous current(10S):90A
BECtype: OPTO
BEC output: 5.5V/4A
Shape and weight of ESC:
Dimensions (LengthXWidthXHeight):87X38X22mm (Including external capacitor and aqueduct)
Weight: 105G
G.W: 158.60g
Positive and negative power:wires:wire size 14# Material TongXin silica gel line Wire;Color:+ Red -Black;Length: 100 (mm)
UVW wire: wire size 14# Material:Copper Silicone Wire;Color:URed VBlueW Black;Length:80 (mm)
Signal wire:wire size 24# Length 280 (mm) Connector specification:3pin DuPont terminal
Types suitable for T head:
Rubber head Specification: 4.0X12
Thrum heat shrinkable catheter specification: 4.5X20 Color:Red,White,Black
Water cooling piece of specifications: 57X38X22 Color Black
Water cooling aqueduct: 5 X20(M5) Color: Golden
Parameter settings of ESC:
The battery types and quantities setting,The default for automatic Settings
Throttle control Settings setting,Have four options,The default for a low acceleration,Suitable for power battery performance not so ideal applications
The electrical work mode Settings,Have four options,The default setting for no brake
The dynamic characteristics of the set has four options,The default setting is positive spin,Soft low voltage protection(Commonly known as drop power)
Into set four options Angle,The default setting for 1°(2-4 very NaZhuan motor apply)
Frequency PWM work setting,There are two options (8KHz,16KHz),Default for:8KHz
Standard configuration:
Power line length 100(mm)UVW linelength 80(mm),no rubber head or T head BEC 5.5V/4A
Main features:
Optional programming card
#2 Useril este offline   abdesign
  • Postari: 79
Postat 13 January 2015 - 09:36 PM
PRET: 250 lei
