Modelism - RHC Forum: Motoare,servo,altele - Modelism - RHC Forum
Motoare,servo,altele Utilizate
#1 Useril este offline   danny_39
  • Postari: 2022
Postat 09 January 2015 - 08:40 PM
Motoare outrunner folosite incepand de la teste la zbor (date,caracteristici sant orientative):
1)Motor Turnigy model D3536/8– folosit :55 lei
-caracteristici:
-battery: 2~4 Cell /2-4 LiPo
-rpm: 1000kv
-max current: 30A
-max power: 430W
-weight: 102g (including connectors)
-diameter of shaft: 5mm
-dimensions: 35x36mm
-prop size: 7.4V/11x5 14.8V/10x6
-max thrust: 1160g
2)Motor EMP model C 4260/07 –folosit :95 lei
-caracteristici:
-battery: 3~4 LiPo
-rpm: 500kv
-max current: 45A
-max power: 800-1000W
-dimensions: 42x60mm
-prop size: 15x8;16x8;16x10
3)Motor EMP model C 5065 –folosit :120 lei
-caracteristici:
-battery: 3-8 LiPo
-rpm: 320 kv
-max current: 80A
-diameter of shaft :8mm
-dimensions:49x65mm
-prop size: 16x10;18x10;18.5x12
4)Motor Neo 15 model N3548 -folosit :105 lei
-caracteristici:
-battery:2-4 LiPo
-rpm: 900kv
-max current:55A
-max power: 815 W
-dimensions:35x48mm
5)Motor Neo 15 model N3548 –folosit : 105 lei
-caracteristici:
-battery:2-4 LiPo
-rpm: 790kv
-max current:41A
-max power: 715 W
-dimensions:35x48mm
6)Motor Neo 25 model N4240 –folosit :95 lei
-caracteristici:
-battery :3-4 LiPo
-rpm: 780 kv
-max current :40A
-max power: 780W
-weight: 153g
-diameter of shaft :5mm
-dimensions:40x42mm
-prop size: 9x5;10x4;11x4.7
-max thrust: 1140g
7)Motor Aeolian C 4250 –folosit :100 lei
-caracteristici:
-battery :3-6LiPo
-rpm: 850kv
-max current :50A
-max power: 1010W
-weight: 195g
-dimensions: 42x50mm
-prop size:12x8;13x6;14x5
8.)Motor C 3542 –folosit : 85 lei
-caracteristici:
-battery :2-4LiPo
-rpm: 1100kv
-max current :45A
-max power: 550W
-diameter of shaft :4mm
-dimensions: 34x42mm
-prop size:8x7;9x5;10x5
9)Servo Tower Pro MG90 –set 4 buc=80 lei
-caracteristici:
-operating Speed (4.8V no load)0.11sec / 60 degrees
-operating Speed (6.0V no load)0.10sec / 60 degrees
-stall torque (4.8V)2.2 kg/cm
-stall torque (6.0V)?2.5 kg/cm
-operation voltage4.8 - 6.0 Volts
- metal Gear
10)Servo Graupner C 261 -3 bucati /2 noi unul utilizat.-pret/3buc=90 lei
-caracteristici:
-modulatie :analog
-torque :4.8v /1.37 kg.
-speed :4.8v/0.15sec.
-dim :21.1x10.9x 21.1mm
-weight :7.9 g.
-gear type :plastic
11)TX Robbe;ST Model –Walkera +2 receptoare Lexors-100 lei
-setul contine :
-tx Robbe -3 canale ,functional
-tx ST Model 4 canale,functional
-tx Walkera-pt. piese
-rx Lexors functioneaza 4 canale la unul din ele ,la celalalt 6 canale
-pereche quartz Tx+Rx in 40.
12)Tren aterizare pneumatic ,luat de pe un aeromodel care nu a zburat, incomplect -50 lei
13) -cablu “Y” -5 lei/buc
14) battery monitor pt. 4S- 10 lei
15)-card programare la 30 lei
16)-papuci pt. roti tren aterizare -20 lei amandoua seturile
17)-set roti -30 lei ambele seturi
18)-figurina pilot -15 lei
19)-set roti dintate pt. heli -5 lei /set
20) batiuri pt. motoare termice -10 lei amandoua
21)motoare arse -2 bucati .
#2 Useril este offline   danny_39
  • Postari: 2022
Postat 09 January 2015 - 08:42 PM
Aceasta postare a fost editata de danny_39: 09 January 2015 - 08:42 PM
#3 Useril este offline   danny_39
  • Postari: 2022
Postat 09 January 2015 - 08:43 PM
Vezi postareadanny_39, la 09 January 2015 - 08:42 PM, a spus:
#4 Useril este offline   danny_39
  • Postari: 2022
Postat 09 January 2015 - 08:46 PM
Vezi postareadanny_39, la 09 January 2015 - 08:46 PM, a spus:
#5 Useril este offline   danny_39
  • Postari: 2022
Postat 09 January 2015 - 08:47 PM
#6 Useril este offline   danny_39
  • Postari: 2022
Postat 09 January 2015 - 08:52 PM
[quote name='danny_39' timestamp='1420829272' post='778407']
Aceasta postare a fost editata de danny_39: 09 January 2015 - 08:52 PM
#7 Useril este offline   danny_39
  • Postari: 2022
Postat 09 January 2015 - 08:53 PM
#8 Useril este offline   danny_39
  • Postari: 2022
Postat 09 January 2015 - 08:56 PM
[quote name='danny_39' timestamp='1420829633' post='778412']
Aceasta postare a fost editata de danny_39: 09 January 2015 - 08:57 PM
#9 Useril este offline   danny_39
  • Postari: 2022
Postat 09 January 2015 - 08:59 PM
Aceasta postare a fost editata de danny_39: 09 January 2015 - 09:00 PM
#10 Useril este offline   dj.nfix
  • Postari: 212
  • Inregistrat: 04-January 13
  • Interests:aeromodelism
Postat 12 January 2015 - 11:36 AM
mai este valabil ca il vreau eu
CONTACT: 0745032795
Y!M: dj.nfix
#11 Useril este offline   danny_39
  • Postari: 2022
Postat 19 January 2015 - 09:50 AM
Punctul 11 -vandut
Produsele de la:
-pct.1-12 transport gratuit Posta Romana cu plata in cont.
-pct.13-20 se discuta
-pct.21 -se da gratuit celui care achizitioneaza minim un articol.
#12 Useril este offline   Lord_Thor
  • Postari: 213
  • Inregistrat: 24-August 14
Postat 19 January 2015 - 06:45 PM
Salut care e pretul la quarturi?ms
Never say never...
#13 Useril este offline   danny_39
  • Postari: 2022
Postat 20 January 2015 - 10:41 AM
Vezi postareaLord_Thor, la 19 January 2015 - 06:45 PM, a spus:
Punctul 11 -vandut
Ti-am trimis ieri mesaj ca s-au vandut
Stima,Dan
Aceasta postare a fost editata de danny_39: 20 January 2015 - 10:42 AM
#14 Useril este offline   pufy
  • Postari: 461
  • Inregistrat: 04-February 11
  • Interests:auto-navo
Postat 20 January 2015 - 08:47 PM
Salut.
Ceva detalii despre motorul din stinga
#15 Useril este offline   danny_39
  • Postari: 2022
Postat 31 January 2015 - 11:37 AM
Produsele de la:
#16 Useril este offline   danny_39
  • Postari: 2022
Postat 08 February 2015 - 11:14 AM
Produsele de la:
-alte variante daca se doreste.
#17 Useril este offline   danny_39
  • Postari: 2022
Postat 15 February 2015 - 04:47 PM
Modificari de pret:
1)Motor Turnigy model D3536/8– folosit :55 lei --pret nou:50 lei
2)Motor EMP model C 4260/07 –folosit :95 lei--pret nou :80 lei
3)Motor EMP model C 5065 –folosit :120 lei--pret nou:100 lei
4)Motor Neo 15 model N3548 -folosit :105 lei--pret nou:90 lei
5)Motor Neo 15 model N3548 –folosit : 105 lei--pret nou:90 lei
6)Motor Neo 25 model N4240 –folosit :95 lei--pret nou:85 lei
7)Motor Aeolian C 4250 –folosit :100 lei--pret nou:95 lei
8.)Motor C 3542 –folosit : 85 lei--pret nou :75 lei
-pct.1-12 transport gratuit Posta Romana,plata in cont,sau variante.
-pct.13-20 se discuta.
Aceasta postare a fost editata de danny_39: 15 February 2015 - 04:48 PM
#18 Useril este offline   12vdr
  • Postari: 29
  • Inregistrat: 25-October 09
Postat 16 February 2015 - 03:54 PM
[b] Salut
-doresc sa cumpar daca mai este valabil
-am nevoie de nr.contului bancar
1)Motor Turnigy model D3536/8– folosit 50 ron si
-pct.21 motoare arse -2 bucati .
Produsele de la:
Multumesc
#19 Useril este offline   danny_39
  • Postari: 2022
Postat 02 March 2015 - 07:59 AM
Ramase la vanzare:
-pct.2-12 transport gratuit Posta Romana,plata in cont,sau variante.
-verificati in tabela de produse daca articolul solicitat mai este valabil.
#20 Useril este offline   danny_39
  • Postari: 2022
Postat 10 March 2015 - 02:51 PM
:rolleyes:
#21 Useril este offline   danny_39
  • Postari: 2022
Postat 20 March 2015 - 01:49 PM
:rolleyes:
#22 Useril este offline   rbon
  • Postari: 80
  • Inregistrat: 31-January 10
Postat 23 March 2015 - 12:20 AM
Sal.In ce stare sunt motoarele de la punctele..4,5 si 8 ? Care ar fi pretu lor la pachet? Cu stima
#23 Useril este offline   Vika
  • Postari: 63
  • Inregistrat: 01-February 11
Postat 20 April 2015 - 12:56 PM
Vezi postareadanny_39, la 19 January 2015 - 09:50 AM, a spus:
Punctul 11 -vandut
Produsele de la:
#24 Useril este offline   Vika
  • Postari: 63
Postat 20 April 2015 - 01:00 PM
salut ,as dori punctul 9 .tel; 0747 411 555 liviu
4 useri citesc topicul
