IMPORTANT!!!PENTRU TOATE COMPONENTELE PREZENTATE AICI SE ACCEPTA DOAR CU PLATA IN AVANS!!! TOATE PRETURILE INCLUD TRANPORT GRATUIT PRIN POSTA ROMANA!DACA SE DORESTE ALT TIP DE TRANSPORT SE PLATESTE CONTRAVALOARE LUI DE CATRE CUMPARATOR!
COMPONENTE ELECTRONICE
Driver A4988 8 euro
Driver Drv8825 11 euro
Ramps 1.4 24 euro
Arduino Mega 2560 28 euro
Lcd2004 cu sd socket 30 euro
Sursa 12v30A360W 170lei
Sursa 12v12,5A150w 110 IDEALA CAND SE PRINTEAZA CU PLA FARA PAT INCALZIT
Motor nema 17 0,5nm 70 lei
Motor nema17 0,4nm 60 lei
Cablu molex 4 fire 1,2m 8lei
Cablu molex 4 fire 1m 6 lei
Cablu molex 3 fire 1m 5 lei
Cablu molex 2 fire 1m 4lei
Releu protectie mosfet de pe Ramps 1.4 25 lei Se vinde cablat
End stop mecanic 6 lei
PCB endstop mecanic cu 500mm cablu conecatre 4 euro
Opto endstop cu 500mm cablu conectare 6 euro
EXTRUDER HOTEND
J Head set complet 0.35mm/0.5mm 1.75/3mm 44 euro
All metal hotend 0.4mm nozzle pentru 1.75mm filament 75 euro
Hotend Buda-style V2.0 0,35/0,4mm pentru 1,75mm filamnet 90 euro
Ansamblu hotend extruder tip Makerbot 0,4mm pentru 1,75mm 115 euro
Hobbed Bolt M8 7euro
Extruder Wade doar partile printate 12 euro
Extruder Wade complet ansamblat include hobbed bolt si rulmentii 150 lei
Heater cartridge 12V 40W 5 euro
Heater cartridge 24V 40W 5 euro
Thermistor cu 1m cablu 4 euro
Thermistor fara cablu 1,5 euro
Pat incalzit
MK2B Heatbed alimentare la 12 sau 24 v 16 euro
MK3 ALU-Heatbed 12/24v 26 euro
Heater pad din silicon 200mx200mm 12v 150w cu thermistor si fire 200mm lungime 40 euro
Heater pad din silicon 300mmx300m 12v 300w cu thermistor si fire 200mm lungime 55 euro
FILAMENT
ABS/PLA diverse culori 125 lei rola de 1kg material , repet este pretul cu livrarea gratuita prin Posta romana
Kapton tape 30m lungime rola diverse latimi
10mm 5 euro
20mm 9 euro
50mm 15 euro
1oomm 22 euro
20mm 40 euro
Profile de aluminiu
20x20mm 30 lei/ml
40x20mm 62 lei/ml
30x30mm 65 lei/ml
60x30mm 130 lei/ml
PENTRU ALTE REPERE CONTACTATI-MA!!!
Aceasta postare a fost editata de donpedro: 25 October 2014 - 05:39 PM
