Giant Low Wing Stick 50cc Marele Tarus construit pe malurile Dambovitei
Postat 23 June 2014 - 04:07 PM
Postat 23 June 2014 - 04:24 PM
Doar componentele de carbon au fost cumparat de afara sau reciclate de pe la alte modele (teava L = 70cm ร 30 si tren de aterizare). Bechia din fibra de sticla este produsa local.
Postat 23 June 2014 - 05:11 PM
Aceasta postare a fost editata de Mihai_supy: 23 June 2014 - 05:11 PM
Postat 23 June 2014 - 11:16 PM
Modele FPV
Piper-Wot4
Modelare 3D
Modele pt.simulator - RealFlight :
LazyBee;SpeedyBee;Aurora Scimitar;Sbach 342;BV 141;Heptad
Postat 24 June 2014 - 08:44 AM
Postat 24 June 2014 - 10:46 AM
Postat 24 June 2014 - 08:36 PM
Felicitari si, te rog mult, sa ne inunzi cu fotografii si descrieri.
Multa, multa bafta, mestere cu maini de aur.
PS. Copilul are niste nasi de cea mai buna spita. Rezultatul, sunt convins, va fi unul de exceptie.
Aceasta postare a fost editata de dan_mitea: 24 June 2014 - 08:38 PM
Postat 25 June 2014 - 09:15 AM
Toata structura a fost taiata laser de LaserCut.
Postat 26 June 2014 - 11:11 AM
Postat 26 June 2014 - 11:16 AM
#11
Postat 30 June 2014 - 10:05 AM
#13
Postat 01 July 2014 - 10:21 PM
La al meu, modeltech de 1,7m, diedrul aripii l-am facut 0 si cu directia care era pana la baza fuselajului caracteristica de zbor s-a largit bine de tot in gama de acrobatie clasica.
si numai bine
#14
Postat 02 July 2014 - 08:35 AM
#15
Postat 02 July 2014 - 08:37 AM
#16
Postat 02 July 2014 - 01:16 PM
#17
Postat 02 July 2014 - 01:33 PM
sunchaser, la 02 July 2014 - 01:16 PM, a spus:
Acele bucsi trebuiei montate cu suprafata mare de asezare catre lemn . Invers vor actiona ca preducele si vor intra in lemn strivind cauciucul amortizorului de vibratii si deci ..... anuland intr-un fel rolul lui.
Numai bine
#18
Postat 02 July 2014 - 01:36 PM
#19
Postat 02 July 2014 - 01:39 PM
+1 la parerea ta despre bucsele de alama de la servo-uri.
Horja, la 01 July 2014 - 10:21 PM, a spus:
si numai bine
#20
Postat 02 July 2014 - 06:29 PM
renatoa, la 02 July 2014 - 01:36 PM, a spus:
Hai sa ma bag in seama...daca nu-i cu banat. Bucsa se pune cu gulerul in jos. Surubul pentru servo are capul special, adica latit. Sunt unele, pe care le iubesc nespus: http://www3.towerhob...?&I=LXFRM2&P=ML , care au o saiba. Astfel, intre capul surubului si guler ai un spatiu fix si cauciucul nu se striveste. Daca pui gulerul sus, inspre surub, cand strangi surubul, tubul de alama se infige in lemn si striveste cauciucul.
Aceasta postare a fost editata de dan_mitea: 02 July 2014 - 06:30 PM
#21
Postat 02 July 2014 - 06:58 PM
Daca tubul de cauciuc se pune cu gulerul pe lemn, in functie de grosimea lemnului va intra in cauciuc numai partial sau deloc, si atnci si-ar pierde menirea, si anume de a asigura alinierea cauciucului si comprimarea lui uniform axiala, altfel, daca nu ar fi tubul si ai baga un surub direct in gaura de cauciuc, la strangere caiciucul ar avea tendinta de a se deforma intr-o parte, nu de a se comprima uniform, faceti un experiment puannd o greutate pe un tub de cauciuc, sa vedeti daca se comprima uniform, nu, o va lua intr-o parte, facand un S.
Temerea ca tubul va actiona ca o preducea este neintemeiata, si de fapt chiar asa face, dar este by design... intra in lemn un pic, fractiuni de mm, pana cand cauciucul comprimandu-se va echilibra forta de strangerea a surubului. Nu va ajunge niciodata sa strapunga lemnul, pentru ca ar insemna ca si cauciucul sa intre in lemn, fiind de aceasi lungime cu tubul, ceeace nu e cazul.
#22
Postat 02 July 2014 - 07:12 PM
#23
Postat 02 July 2014 - 10:38 PM
renatoa, la 02 July 2014 - 07:12 PM, a spus:
Unii dupa carte, altii dupa ureche.....
#24
Postat 02 July 2014 - 11:10 PM
#25
Postat 02 July 2014 - 11:17 PM
Poate sa ma piliti putin in tubul de alama, fara compresia cauciucului nu se realizeaza o prindere fara joc.
#26
Postat 02 July 2014 - 11:36 PM
renatoa, la 02 July 2014 - 11:17 PM, a spus:
Am patit-o si eu cu servo de 3 lei sa aibe joc dar cu cele de calitate nu.
#27
Postat 03 July 2014 - 04:58 AM
PS. Sper sa ne ierte autorul bijuteriei pentru divagatiile noastre.
#28
Postat 03 July 2014 - 07:28 AM
dan_mitea, la 03 July 2014 - 04:58 AM, a spus:
Un HiModel standard 38g-3,5kg. Am scos din ambalaj doua Hitec, un 311 si un 485, le-am asamblat si apoi fixat pe placaj. Nu au joc!
#29
Postat 03 July 2014 - 08:29 AM
#30
Postat 03 July 2014 - 09:46 AM
(intre timp Vulturul Barbos a revenit la aspectul care l-a consacrat :rolleyes:)
Aceasta postare a fost editata de sunchaser: 03 July 2014 - 09:49 AM
