Modelism - RHC Forum: Vand sistem profesional filmari aeriene (Mikrokopter Octo2) - Modelism - RHC Forum
Vand sistem profesional filmari aeriene (Mikrokopter Octo2) Pachet RTF cu multiple upgradeuri (atentie lipsesc packurile)
#1 Useril este offline   vvrest
  • Postari: 907
  • Inregistrat: 29-September 09
Postat 29 May 2014 - 11:56 AM
Descriere tehnica Mikrokopter Octo2 (octocopter)
Componenta kit de baza:
• 1 Preassembled FlightCtrl ME V2.1 (incl. altitude sensor V2)
• 8 Preassembled BL-Ctrl V2.0
• 1 Okto Power Distribution PCB
• 1 Okto2 Frame Set with anodized (coloured) riggers
• 4 HiLander-26 (landing gear)
• 1 LiPo Holder
• Motor angle adapter
• 8 Roxxy 2827-35 - black Brushless Motors upgradate cu rulmenti ceramici (motoarele suporta o greutate de 820gr/motor)
• 1 Protection cap for the electronic components
• 1 Connection cable for receiver
• 1 Extensive set of cables
• 4 Vibration dampers M3x15
• Heat shrink tubing for other solder joints
• 2 Pieces of Velcro stripes to fasten the Lipo
• 4 Pieces Flex LED Tape for lighting
• 100 Cable ties (black)
Sistem radio cu telemetrie dedicata Mikrokopter care arata pe displayul telecomenzii in timp real toate informatiile referitoare la zbor (voltaj acumulator, curent consumat, numar sateliti, mesaje de eroare, altitudine de zbor, temperatura variatoare turatie, timp de zbor) si care poate comunica totodata toate datele enumerate si vocal:
• 1 MX-20 HoTT radio-control
• 1 Transmitter NiMH 2000 mAh battery
• 1 Receiver Graupner HoTT GR-24
Componente upgrade instalate pentru GPS, position hold si navigare plus optiunile adiacente precum (punct de interes, navigare la puncte predefinite sau follow me):
• 1 MKGPS 2.1 board (SMD-preassembled)
• 1 Passive GPS antenna soldered
• 4 PCB parts to construct the sides of a cap (GPS shield)
• 1 Cable with Molex connector (5pin)
• 1 NaviCtrl v2.0 (SMD-preassembled) cu upgrade de accelerometru
• 2 Ribbon cable with connectors
• 8 Plastic bolts M3x15
Scurta descriere a caracteristicilor de zbor:
-Punct de interes (zburatoare mentine in mod automat in cadrul unei misiuni cu puncte de navigare planificate pe GPS camera orientata in permanenta pe un subiect ales ca si coordonata GPS indiferent de altitudinea la care se zboara sau se afla in acele puncte de navigare).
-GPS positin hold (zburatoarea mentine coordonata GPS si altitudinea in care este activata functia fara a mai fi nevoie de interventia operatorului).
-Waypoint navigation (zburatoare executa automat o misiune pe un traseu cu mai multe puncte prestabilite pe coordonate GPSin raza a 250m inclusi in pachetul standard).
-Follow me ( zburatoare urmareste automat un emitator GPS ce trebuie achizitionat separat indiferent de traseul pe care il descrie acesta la o altitudine prestabilita).
-Return to home ( zburatoarea revine automat la coordonata GPS de unde a fost lansata la comanda manuala a pilotului sau in mod automat cand iese din raza de actiune a telecomenzii, 4 km).
Upgradeuri generale:
• 1 Ventilated universal dome (permite ventilarea corespunzatoare a componentelor electronice)
• 8 Vibration dampers M3x15 ( asigura izolarea vibratiilor ce pot fi transmise catre controller si sistemul de stabilizare al camerei)
• 10 Aluminium spacers for Lipo holder (rigidizeaza suportul de baterie pentru a permite zburarea cu doua packuri in paralel)
• 1 External speacker (permite redarea vocala a datelor de telemetrie receptionate pe telecomanda din controller in timp real)
Sistem stabilizare camera :
• Camera mount MK HiSight SLR1(assembled) incl. 2 servos MKDS18 for Nick & Roll
• 1 Aluminum tripod screw to mount a camera
• 10 Nuts M3 black (plastic)
• Max. Width of the camera: 140mm
• Max. Height of the camera: 120mm
• Two MKDS18 Servos with extremely high resolution (>5000 Steps)
• Weight (with the 2x Servo included): about 245 grams only!
Toate produsele de mai sus au fost achizitionate din Germania de la firma Mikrokopter.
Sistem FPV (transmisie receptie video la sol in timp real):
• One Remzibi OSD (permite afisarea datelor referitoare la consum si voltaj in timp real pe monitorul de FPV)
• OSD Connection cables
• OSD curent/voltage senzor
• 1 FPV 5.8Ghz transmitter (emite in timp real imaginea video captata de aparatul de inregistrare)
• 1 FPV 5.8Ghz receiver (receptioneaza in timp real imaginea video captata de aparatul de inregistrare)
• 1 FPV 5.8Ghz clever leaf transmitter antenna (imbunatateste semnalul transmitatorului video ca raza si claritate)
• 1 FPV 5.8Ghz clever leaf receiver antenna (imbunatateste semnalul receptorului video ca raza si claritate)
• Cables and connectors
• 1 FPV TFT 7' Monitor for ground station (permite vizualizarea in timp real a imaginilor captate de aparatul de inregistrare)
• 1 servieta rama aluminiu (compactarea sistemului de emisie receptie)
Pret vanzare pentru tot pachetul de mai sus = 2300 euro
ATENTIE, pentru a fi gata de zbor lipsesc packurile, pe care nu le-am inclus, oferind astfel clientului oportunitatea de a alege ce i se potriveste conform necesitatilor.
Contact:
Razvan
Tel: 0721846149
Email: sierra_gsm@yahoo.com
#2 Useril este offline   vvrest
  • Postari: 907
Postat 29 May 2014 - 11:57 AM
#3 Useril este offline   vvrest
  • Postari: 907
Postat 16 June 2014 - 12:33 PM
Up
#4 Useril este offline   vvrest
  • Postari: 907
Postat 03 July 2014 - 01:39 PM
Usor discutabil.
#5 Useril este offline   vvrest
  • Postari: 907
Postat 25 August 2014 - 02:15 PM
UP
#6 Useril este offline   vvrest
  • Postari: 907
Postat 16 September 2014 - 10:32 AM
UP
#7 Useril este offline   vvrest
  • Postari: 907
Postat 26 September 2014 - 02:39 PM
Un sistem foarte stabil!
Discutabil!
#8 Useril este offline   Mihai Oprescu
  • Postari: 666
  • Inregistrat: 03-October 08
  • Interests:Aero
Postat 26 September 2014 - 07:56 PM
Vezi postareavvrest, la 26 September 2014 - 02:39 PM, a spus:
Discutabil!
Autonomie cu 3-400 grame payload ?
#9 Useril este offline   vvrest
  • Postari: 907
Postat 27 September 2014 - 07:42 AM
Cu un 4S 5000mAh zbori cca 14min la greutatea aia.
Eu zburam cu un CX730 care are cam 720gr cu acumulator 4S 6600mAh in jur de 15min, evident in functie si de ce manevre presupunea acel zbor.
Cu respect.
#10 Useril este offline   vvrest
  • Postari: 907
Postat 08 October 2014 - 11:24 AM
UP
#11 Useril este offline   vvrest
  • Postari: 907
Postat 29 October 2014 - 08:52 AM
2150 Euro pentru tot sistemul de mai sus
Aceasta postare a fost editata de vvrest: 29 October 2014 - 08:52 AM
#12 Useril este offline   vvrest
  • Postari: 907
Postat 07 November 2014 - 11:20 AM
2149 Euro
#13 Useril este offline   vvrest
  • Postari: 907
Postat 19 November 2014 - 03:28 PM
1999 Euro
Aceasta postare a fost editata de vvrest: 19 November 2014 - 03:28 PM
#14 Useril este offline   vvrest
  • Postari: 907
Postat 04 December 2014 - 03:34 PM
Deschis la oferte!
#15 Useril este offline   vvrest
  • Postari: 907
Postat 22 December 2014 - 11:48 AM
Up
#16 Useril este offline   vvrest
  • Postari: 907
Postat 16 February 2015 - 11:27 AM
1700 E
#17 Useril este offline   vvrest
  • Postari: 907
Postat 19 March 2015 - 08:29 AM
Up
#18 Useril este offline   vvrest
  • Postari: 907
Postat 01 April 2015 - 02:12 PM
1500 E
Numai sistemul radio face peste 400E !
#19 Useril este offline   vvrest
  • Postari: 907
Postat 07 May 2015 - 08:53 AM
Sistemul are sub 500 min de zbor (regim amator) !
1500 E
6 useri citesc topicul
