Modelism - RHC Forum: Nevoie de ajutor pentru piese si CNC pt automodel de la zero. - Modelism - RHC Forum
Nevoie de ajutor pentru piese si CNC pt automodel de la zero. Constructie automodel 1/10
#1 Useril este offline   Mariannu
  • Postari: 6
  • Inregistrat: 07-September 13
Postat 21 February 2014 - 08:10 PM
Salut.
Vreau sa fac un automodel 1/10 de la zero si am nevoie de urmatoarele piese daca ma puteti ajuta sa le gasesc la un pret acceptabil as fi recunoscator.
Toate piesele sunt verificate dar din pacate nu le-am gasit in Romania sau la un pret accesibil.
Caut:
CNC aluminiu
Debitare Fibra carbon
(detin model CAD pentru toate piesele)
Piese: BUC
Button Head Allen Bolt 2x6mm 11
Button Head Allen Bolt 3x6mm 1
Button Head Allen Bolt 3x8mm 18
Button Head Allen Bolt 3x10mm 8
Button Head Allen Bolt 3x16mm 2
Button Head Allen Bolt 3x20mm 4
Button Head Allen Bolt 3x25mm 4
Countersunk Socket Allen Bolt 3x8mm 14
Countersunk Socket Allen Bolt 3x10mm 16
Countersunk Socket Allen Bolt 3x12mm 1
Allen Bolt Socket Cap Screw M1.6x6 4
Allen Bolt Socket Cap Screw M2.5x25 2
Cup Point Grub Screws M2x2 17
Cup Point Grub Screws M2x4 4
Cup Point Grub Screws M2x8 4
Hex Full Nuts M3 13
Nyloc Lock Nuts M2.5 2
Nyloc Lock Nuts M3 8
Nyloc Lock Nuts Flanged M4 4
Ball Stud D4.8x6 26
Ball Stud D4.8x10 2
Stabilizer balls 6.8 4
Ball Cup D4.8 16
Rulment 10x15x4 8
Rulment 5x10x4 6
Rulment 3x6x2.5 8
Rulment 5x8x2.5 4
Axial Ball Thrust 2.5x6x3 4
O-ring silicon 8x1.5 mm 4
O-ring silicon 5x1.5 mm 4
O-ring silicon 3x2 mm 12
Turnbuckle 30mm 5
Turnbuckle 40mm 2
Pinion Spur 106T (64DP) 1
Pinion Spur 110T (64DP) 1
Pinion Spur 116T (64DP) 1
Pinion 25T (64DP) 1
Pinion 29T (64DP) 1
Pinion 31T (64DP) 1
Servo saver/arm 1
Ceramic Diff Ball 3mm 20
Springs set d14x25mm 4
Diff Spring 2.5-3x6.5-7mm 1
Carbon Fiber Pante 200x300x2.5mm 1 minim 2 placi de 100x300x2.5mm
Curele S3M cu urmatoarele specificatii
latime curea= 4mm sai mai mult, am inteles ca se pot taia la dimensiunea dorita
Dinti Lungime Buc
62 186 1
96 286 1
115 344 2
134 401 1
167 501 1
Belt Pulley for S3M 4.5mm latimea canalului curelei din aluminiu care vor urma a fi prelucrate la cnc pt. a se ajunge la specificatiile dorite, cu:
19 dinti 1
20 dinti 1
39 dinti 2
Asta-i tot :yahoo:
#2 Useril este offline   odin
  • Postari: 426
  • Inregistrat: 19-June 08
  • Interests:aero, navo, auto
Postat 04 March 2014 - 12:51 PM
Asa, la prima vedere: curele S3M? astea sunt pt precizie mare, nu cred ca ai nevoie. T3 nu-s bune?
Cauta sa adaptezi din alte domenii hobby. De ex la heli sunt multe ball-linkuri.
Daca ai un plan de pe net, nu e musai sa folosesti lista de materiale de acolo- te adaptezi la ce ai.
Succes!
PS: un link pt CAD planuri exista?
Aceasta postare a fost editata de odin: 04 March 2014 - 12:55 PM
#3 Useril este offline   HGV
  • Postari: 79
  • Inregistrat: 28-March 11
  • Interests:motociclism, modelism
Postat 04 March 2014 - 05:46 PM
Pentru suruburi iti recomand http://rc-schrauben.de/
Au o gama foarte variata. Succes!
#4 Useril este offline   Mariannu
  • Postari: 6
Postat 04 March 2014 - 09:15 PM
Vezi postareaodin, la 04 March 2014 - 12:51 PM, a spus:
Succes!
Din pacate nu pot face public modelul 3d al automodelului dar o sa-l vezi cand voi reusi sa-l fac.
Mersi pentru pentru sfatul cu curelele, o sa ma documentez si poate reuses so o scot la capat :)
iar de pe cartea de heli am scos niste rulmenti axiali pt diff.
Mersi.
Vezi postareaHGV, la 04 March 2014 - 05:46 PM, a spus:
O sa ma uit pe site si sa vad ce mi se potriveste.
Mersi.
#5 Useril este offline   Mariannu
  • Postari: 6
Postat 04 March 2014 - 09:57 PM
Asta este cam tot ce pot arata momentan.
  • Imagine atasata: MASINUTA.jpg
5 useri citesc topicul
