AEORC MultiWii Mini Flight Controller v0.1 with FTDI
Postat 22 February 2013 - 09:15 PM
Tx: Turnigy 9X
Postat 22 February 2013 - 10:55 PM
ar trebui sa te ajute asta.
Teoretic trebuie sa selectezi procesorul care trebuie din lista si port-ul
VISTA = Virus Inside Switch to Apple
Postat 22 February 2013 - 10:58 PM
GST 7.7, la 22 February 2013 - 10:55 PM, a spus:
tutorialu asta il stiu si l-am citit din scoarta in scoarta, dar tot nu reusesc, multiwii gui merge se conecteaza si imi returneaza ceva valori si multiwii config la fel, dar cand incerc sa incarc firmware nou, epic fail.....
Tx: Turnigy 9X
Postat 22 February 2013 - 11:03 PM
bun sfatul:) am inceput sa testez fiecare placa in parte din lista si am gasit si a mers, mersi mult de tot.
Tx: Turnigy 9X
Postat 01 March 2013 - 11:06 PM
Tx: Turnigy 9X
Postat 01 March 2013 - 11:39 PM
Cand mai prinzi experienta, cauti si tu un MOTOR_STOP prin config.h-ul ala si inveti sa te zgaiesti la leduri.
Postat 02 March 2013 - 12:09 AM
Para, la 01 March 2013 - 11:39 PM, a spus:
deci e cam normal sa fie asa?
Tx: Turnigy 9X
Postat 02 March 2013 - 03:31 PM
Postat 02 March 2013 - 08:31 PM
GST 7.7, la 02 March 2013 - 03:31 PM, a spus:
am activat motor_stop, eu oricum am setat pe statie th cut care e in reflex cum aterizez sa tai motoru, dupa ce am avut 2 degete sfartecate de o elicie:)
Tx: Turnigy 9X
Postat 04 March 2013 - 11:16 PM
Tx: Turnigy 9X
Postat 04 March 2013 - 11:26 PM
Aceasta postare a fost editata de renatoa: 04 March 2013 - 11:28 PM
Postat 05 March 2013 - 09:04 AM
Daca nu ai pretentii la super-barometru, vii c-o bere la CET w/e viitor si-ti aduc o placuta cu BMP085, HMC5843, LLC si sursa de 3V3.
Postat 05 March 2013 - 09:07 AM
Postat 05 March 2013 - 07:39 PM
renatoa, la 05 March 2013 - 09:07 AM, a spus:
eu eram cel care v-a contactat:)
Tx: Turnigy 9X
Postat 06 March 2013 - 09:59 PM
Tx: Turnigy 9X
Postat 06 March 2013 - 11:15 PM
Postat 07 March 2013 - 12:10 AM
Para, la 06 March 2013 - 11:15 PM, a spus:
aha, mersi mult.
Tx: Turnigy 9X
Postat 07 March 2013 - 10:58 PM
Tx: Turnigy 9X
#19
Postat 08 March 2013 - 07:09 AM
#20
Postat 08 March 2013 - 11:32 AM
Para, la 08 March 2013 - 07:09 AM, a spus:
mai da quadu meu e dacie obosita??
Tx: Turnigy 9X
#21
Postat 10 March 2013 - 10:38 AM
Tx: Turnigy 9X
#23
Postat 10 March 2013 - 12:10 PM
Para, la 10 March 2013 - 11:50 AM, a spus:
asta am gasit-o dar sub tri, am incercat si degeaba, am mai incercat si cu #define_force si degeaba, am verificat motoarele sunt ok conectate, sensurile sunt bune
Tx: Turnigy 9X
#24
Postat 10 March 2013 - 08:51 PM
Aceasta postare a fost editata de R3dD3vil: 10 March 2013 - 08:52 PM
Tx: Turnigy 9X
#25
Postat 10 March 2013 - 09:57 PM
R3dD3vil, la 10 March 2013 - 08:51 PM, a spus:
gata am rezolvat-o, era simplu, am inversat in receptor canalele 1 cu 2 si in FC D9 cu D11 si acum merge ok totul:) cu vibratiile mai am de rezolvat si cu motoarele care merg in zvacuri, dupa cum mi-a arata colegul para, caruia ii multumesc, am de lucrat la echilibrarea eliciile si posibil intarirea frameului, daca nu confectionarea altuia nou mai rigid.
Tx: Turnigy 9X
#26
Postat 10 March 2013 - 10:33 PM
R3dD3vil, la 10 March 2013 - 09:57 PM, a spus:
ha, am rezolvat si mersul in zvacuri al motoarelor:) cum era de asteptat am scos eliciile si motoarele merg ca unse in jur de 1800, desi tot mai sunt mici vibratii in frame. multiwii conf.jpg (187.28K)
Tx: Turnigy 9X
#28
Postat 11 March 2013 - 07:18 PM
Ciprian Dughir, la 11 March 2013 - 04:43 PM, a spus:
Arduino Duemilanove or Diecimila
Tx: Turnigy 9X
#30
Postat 11 March 2013 - 11:03 PM
Tx: Turnigy 9X
