Modelism - RHC Forum: elici XOAR 3D - Modelism - RHC Forum
elici XOAR 3D
#1 Useril este offline   ANDUNG
  • Postari: 493
  • Inregistrat: 11-June 10
Postat 20 December 2013 - 03:05 PM
A aparut o alternativa la renumitele VESS, care din pacate nu prea se gasesc prin Europa, dar dupa care sunt innebuniti americanii.
Problema ca deocamdata nu fac la 23 inchi, ceea ce insemna ca la gama 55cc, trebuie sa alegi probabil intre 22B si 24A
Detalii de pe site-ul lor.
Xoar PJE 3D Prop is designed for optimizing 3D flying performance for R/C Model Airplane. In 3D flying, the aircraft needs to perform aerobatics at various speeds (from low speed to suspension 0 speed). By employing accurate transition of declining pitch parameter from hub to tip, PJE prop provides the aircraft with maximum maneuverability. Xoar PJE’s blades are uniquely shaped to provide absolute balance between thrust and speed and variable pitch for absolute accuracy for the most complicated maneuvers.
A average at 8 pitch; B average at 10; C average at 12
Aceasta postare a fost editata de ANDUNG: 20 December 2013 - 03:06 PM
  • Postari: 19171
Postat 20 December 2013 - 04:30 PM
In multicoptere XOAR de lemn sunt crema, este bine stiut.
Daca cercetezi putin netu o sa ajungi la chinezii care le fac, imi scapa acum numele, ceva cu J. Doar ca ce vand sub nume propriu nu au aceasi calitate ca ce dau la XOAR.
#3 Useril este offline   ANDUNG
  • Postari: 493
Postat 20 December 2013 - 05:09 PM
Vezi postarearenatoa, la 20 December 2013 - 04:30 PM, a spus:
JXF parca, nu? Low cost-ul aceluiasi producator.
  • Postari: 5155
Postat 15 May 2014 - 09:13 PM
au am luat din XOAR PJA19X8 pentru un 30cc. Sa vad ce o sa-i pun dupa...
Aceasta postare a fost editata de Mihai_supy: 15 May 2014 - 09:13 PM
