Modelism - RHC Forum: Tarot hexa - Modelism - RHC Forum
Tarot hexa ...am luat-o si eu cu capu`
#91 Useril este offline   EBA
  • Postari: 956
  • Inregistrat: 09-April 09
  • Interests:AEROMODELISM
Postat 31 January 2014 - 06:01 PM
Daca mai ai intrebari,Baga. iti spun tot.Ai reglaje pe care poti sa le faci in timpul zborului privitor la stabilitate pitch.roll etc,Pe 2 canale ale statiei.
SUNTEM FUDULI
#92 Useril este offline   shogi
  • Postari: 2753
  • Inregistrat: 08-March 06
  • Interests:pussy
Postat 31 January 2014 - 06:03 PM
Stiu, despre ce am vorbit sambata , insa deocamdata vreau doar sa ma asigur ca se ridica,la interior, si nu la peste 60% din turatie. am un 4s 5000 45c ...vedem cum se comporta si apoi revin.
#93 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 31 January 2014 - 06:53 PM
pe att e altceva , sta si el acolo unde tre , doar compesat un pic din manse.ideea e ca nu vrea sub nici o forma sa-mi decoleze sub 50% din stickul de throttle si asta nu-mi place .nu cred ca este din FC pentru ca nu am umblat la nici o setare pe laptop si nici n-am vazut ceva de genul in assistant.
edit : "Many people will increase the power for take-off very slowly, this can cause the concerns with the sides of the copter lifting and looking as if it will flip on take-off. The correct way to lift off is to arm the motors, bring the throttle to 50% in one smooth motion and then continue to about 75% throttle to get clear of the ground. When the copter leaves the ground return the throttle to about 50% or just over and you are now up and flying! "
...thank` god for google.problem solved :))
Aceasta postare a fost editata de shogi: 31 January 2014 - 06:58 PM
#94 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 09 February 2014 - 05:27 PM
azi primu` zbor, 15 minute , cu packul scos la 14,7V , cu 4s nano-tech 6000, a iesit la 2700g complet.
Aceasta postare a fost editata de shogi: 09 February 2014 - 05:55 PM
#95 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 11 February 2014 - 07:17 PM
configuratie noua , mutat gimbal spre bot , mutat packuri dedesubt un pic spre spate.
#96 Useril este offline   adioperator
  • Postari: 1356
  • Inregistrat: 12-November 09
  • Interests:aeromodelism
Postat 12 February 2014 - 11:18 PM
Si concluzia? :)
#97 Useril este offline   shogi
  • Postari: 2753
  • Interests:pussy
Postat 13 February 2014 - 10:22 AM
concluzia ? e piiiiiiiiiiiiiiiiiiiiiiiiii*da ! :))))))
#98 Useril este offline   Mihai Oprescu
  • Postari: 666
  • Inregistrat: 03-October 08
  • Interests:Aero
Postat 16 February 2014 - 12:13 PM
Vezi postareashogi, la 13 February 2014 - 10:22 AM, a spus:
:good: :clapping:
#99 Useril este offline   adioperator
  • Postari: 1356
Postat 18 March 2014 - 07:10 PM
Colegii, aveti careva un suport de motor in plus pentru fy690s ?
16 useri citesc topicul
