Modelism - RHC Forum: Vand router CNC din aluminiu, nou! - Modelism - RHC Forum
#1 Useril este offline   Gauss
  • Postari: 4
  • Inregistrat: 10-August 11
Postat 17 September 2013 - 07:24 AM
Vand router CNC din aluminiu. Poate prelucra lemn, pcb, aluminiu, alama, cupru etc. Este nou nout, cu accesorii. Nu ma pricep la cnc-uri, dar astea sunt specificatiile:
Effective working travel 200(X)mm*300(Y)mm*500(Z)mm
Shape dimension 550x400*350mm
Max.workpiece dimension 200mm*300mm<65mm
Work table dimension 200mm*300mm*15mm
Frame materials aluminum alloy 6063 and 6061
Driving units
X axis 1204 trapezoidal screws
Y axis 1204 trapezoidal screws
Z axis 1204 trapezoidal screws
Sliding units
X axis Dia.13mm chrome plate shafts
Y axis Dia.16mm chrome plate shafts
Z axis Dia.12mm chrome plate shafts
Stepping motor type 57 two-phase 1.45A-2A
Spindle motor 200w dc motor
Principal axis collet ER11/3.175 mm
Spindle speed 300 ~ 8000rpm/min (PWM stepless speed regulation)
Repeat accuracy 0.05mm
Empty line speed 0-2500mm/min (16 subdivided driving down)
Spindle precision radial beat acuities 0.03 mm
Control unit triaxial one-piece drive + ring variable power + PWM speed
Carving Instructions G code/TAB files/nc file/NCC files
Communication interface through parallel connection with computer
Software environment Windows 2000 / xp
Carving speed 0-2000mm/min (different materials differ)
Machine weight 24KG
Pret: 3000 RON (negociabil)
  • Imagine atasata: CNC.jpg
#2 Useril este offline   virus2:0
  • Postari: 51
  • Inregistrat: 23-April 12
Postat 14 October 2013 - 09:54 AM
Sal , mai este valabil anuntul.
3 useri citesc topicul
