Modelism - RHC Forum: HPI BAJA si CLONELE - Modelism - RHC Forum
  • 77 Pagini +
  • 40
  • 41
  • 42
  • 43
  • 44
HPI BAJA si CLONELE tot ce tine de BAJA 5B/5T Evaluare topic: -----
#1231 Useril este offline   hassel
  • Postari: 2464
  • Inregistrat: 02-February 12
Postat 21 May 2015 - 07:23 AM
Ar fi fost bine sa iei undertray de baja 5t. daca studiezi aspectul ai sa vezi ca ai avantaje fata de cel de 5b.
BAJA
5SC 30cc gas
#1232 Useril este offline   soarece
  • Postari: 2860
  • Inregistrat: 03-January 13
Postat 21 May 2015 - 12:13 PM
mai cade ok coaja de 5b p el ?
alta culeasa din popor :
R: Pen`ca poate."
#1233 Useril este offline   revolt
  • Postari: 590
  • Inregistrat: 25-February 15
Postat 21 May 2015 - 05:34 PM
Vezi postareasoarece, la 20 May 2015 - 11:02 PM, a spus:
o baja 5sc HPI :crazy: in lucru.....
Ce e aia ??
Hpi Savage Flux XL 3 diffs
Hpi Savage Flux XL
Hpi Savage Flux
#1234 Useril este offline   revolt
  • Postari: 590
Postat 21 May 2015 - 05:54 PM
Vezi postarearevolt, la 21 May 2015 - 05:34 PM, a spus:
Ce e aia ??
E dual slipper?
Hpi Savage Flux XL
Hpi Savage Flux
#1235 Useril este offline   Kitty
  • RC Addict
  • Postari: 4563
  • Inregistrat: 11-July 08
  • Interests:RC,Cars.....
Postat 21 May 2015 - 09:43 PM
Vezi postareahassel, la 21 May 2015 - 07:23 AM, a spus:
Ma uitasem,e altcumva facuta,nu cred ca da bine pe 5b
Axial SCX10.3
Absima Sherpa
Axial Base Camp
#1236 Useril este offline   soarece
  • Postari: 2860
Postat 21 May 2015 - 10:03 PM
Vezi postarearevolt, la 21 May 2015 - 05:54 PM, a spus:
E dual slipper?
se numeste HPI POWER CONTROL SLIPPER CLUTCH SET sau mai simplu PCSC ,e ajustabil si te scapa de uzura in planetare sau socurile nedorite suportate de toata transmisia :good: ,e vreo 600 ron unul dar merita din plin !
Aceasta postare a fost editata de soarece: 21 May 2015 - 10:06 PM
R: Pen`ca poate."
#1237 Useril este offline   Kitty
  • RC Addict
  • Postari: 4563
Postat 21 May 2015 - 11:07 PM
Daca zici ca merita trantesc si eu unul,ca arata prea bine LOOOOL
Abia astept sa fie peolalta.Dati-mi indicii despre gumele fata.Ce sa iau?
Axial SCX10.3
Absima Sherpa
Axial Base Camp
#1238 Useril este offline   soarece
  • Postari: 2860
Postat 21 May 2015 - 11:20 PM
Vezi postareaKitty, la 21 May 2015 - 11:07 PM, a spus:
Merita man.
Proline trencher si fata si spate !
R: Pen`ca poate."
#1239 Useril este offline   soarece
  • Postari: 2860
Postat 22 May 2015 - 09:24 AM
tip ,daca tot umbli la transmisie: atentie ca la rovan/km diferentialul pare identic dar nu e ,carcasa exterioara e mai lunga cu vreo 3mm din rulment in rulment fata de cea de la hpi asa ca cutia de plastic OEM nu "inghite" un diff non-oem si invers ! posibil ca si internele is diferite....
Aceasta postare a fost editata de soarece: 22 May 2015 - 09:24 AM
R: Pen`ca poate."
#1240 Useril este offline   revolt
  • Postari: 590
Postat 22 May 2015 - 01:55 PM
Vezi postareasoarece, la 21 May 2015 - 10:03 PM, a spus:
PCSC
ia uite :
Hpi Savage Flux XL
Hpi Savage Flux
#1241 Useril este offline   soarece
  • Postari: 2860
Postat 22 May 2015 - 04:44 PM
filmul il stiu dar nu inteleg ce rost are acel mod ? ca sa am spur de plastic in loc de cel metalic sau ca sa pun un spur cu alti dinti si sa ma joc la gearing ratio ? oricum odata ce pun acel spur tensiunea in arc e alta,adica trebuie sa-l reglez dupa probe/teste ,nu mai merge faza cu strans la maxim si o tura inapoi !
R: Pen`ca poate."
#1242 Useril este offline   revolt
  • Postari: 590
Postat 22 May 2015 - 06:50 PM
Daca il urmaresti cap coada, omu explica care sunt beneficiile acelor saibe.
Si iti si explica cat si cum trebuie strans.
Hpi Savage Flux XL
Hpi Savage Flux
#1243 Useril este offline   revolt
  • Postari: 590
Postat 22 May 2015 - 06:52 PM
Ce nu pricep eu..
Cum modifici gearing-ul? Ca le vad fixe, atat spurul cat si pinionul.
Hpi Savage Flux XL
Hpi Savage Flux
#1244 Useril este offline   Kitty
  • RC Addict
  • Postari: 4563
Postat 22 May 2015 - 09:47 PM
Ce kill switch sa aleg?Am vazut ca sunt o gramada de producatori....
Axial SCX10.3
Absima Sherpa
Axial Base Camp
#1245 Useril este offline   Ice_2k
  • Postari: 639
  • Inregistrat: 19-January 15
Postat 22 May 2015 - 10:26 PM
In functie de ce statie ai, te pot ajuta eu cu un ramtech-rc.
1/5 Redcat Rampage DuneRunner v3 32cc 4x4
#1246 Useril este offline   hassel
  • Postari: 2464
Postat 22 May 2015 - 10:57 PM
Vezi postarearevolt, la 22 May 2015 - 06:52 PM, a spus:
Ce nu pricep eu..
Fixe, dar se schimba si una si alta, pinion mai mare, spur mai mic si tot asa.
BAJA
5SC 30cc gas
#1247 Useril este offline   soarece
  • Postari: 2860
Postat 22 May 2015 - 11:00 PM
Ce nu pricep eu..
stai putin ca am vazut gresit,parca am confundat,eu vazusem alt tutorial in care puneau un spur de plastic in loc de ala metalic si atunci poti sa te joci cu rapoartele ca daca spurul e mai mic pui un pinion mai mare(le iei pereche)......acuma am vazut ce face el acolo si constat ca am facut si eu oarecum chestia asta fara sa vad de nicaieri...il aveam desfacut pe masa si gasii slabe si eu suruburile care tin rulmentul si am mai adaugat si eu o saiba pe undeva ....am dat inapoi 1.25 ture apoi !
Vezi postareaKitty, la 22 May 2015 - 09:47 PM, a spus:
asta o sa fie ultima ta grija,trust me ! :good: dai de cap intai cu ce mai ai pe la ea,pune 2 servouri bune,"de baza" si dai jar....
Aceasta postare a fost editata de soarece: 22 May 2015 - 11:02 PM
R: Pen`ca poate."
#1248 Useril este offline   Kitty
  • RC Addict
  • Postari: 4563
Postat 22 May 2015 - 11:06 PM
Vezi postareaIce_2k, la 22 May 2015 - 10:26 PM, a spus:
E spektrum.Da ce legatura are statia?
Axial SCX10.3
Absima Sherpa
Axial Base Camp
#1249 Useril este offline   Kitty
  • RC Addict
  • Postari: 4563
Postat 22 May 2015 - 11:07 PM
Vezi postareasoarece, la 22 May 2015 - 11:00 PM, a spus:
Pe directie e un Turnigy nou nout,asa am luat masina si pe acceleratie e ceva noname.Da ma intai sa o vad functionala.Singurul lucru ce mna impiedica sunt acele doua suruburi ca nu vreau sa o pun peolalta asa jegoasa
Axial SCX10.3
Absima Sherpa
Axial Base Camp
#1250 Useril este offline   Ice_2k
  • Postari: 639
Postat 22 May 2015 - 11:28 PM
Vezi postareaKitty, la 22 May 2015 - 11:06 PM, a spus:
Killswitch-ul se integreaza in receiver ca sa poata detecta glitch-uri sau semnal slab. Pt spektrum functioneaza ok dar nu se poate pune pe canalul 3. Mai concret, iti va opri motorul in caz de glitch sau pierdere de semnal dar daca vrei sa-l opresti la comanda, trebuie sa inchizi statia, nu merge pe un canal separat (adica asa: http://youtu.be/JEMhBy5P4Ws)
Aceasta postare a fost editata de Ice_2k: 22 May 2015 - 11:33 PM
#1251 Useril este offline   soarece
  • Postari: 2860
Postat 22 May 2015 - 11:44 PM
Vezi postareaKitty, la 22 May 2015 - 11:07 PM, a spus:
....si pe acceleratie e ceva noname....
uite de aia ai nevoie de kill ca servourile astea no-name(unele) is pacatoase rau si daca-ti ramane accelerat sau nu mai ai frana ai necazuri....sau pune-i un servo bun-bun si da-i bice !
R: Pen`ca poate."
#1252 Useril este offline   Kitty
  • RC Addict
  • Postari: 4563
Postat 23 May 2015 - 08:52 PM
Vezi postareaIce_2k, la 22 May 2015 - 11:28 PM, a spus:
Mi-ar trebui un kill switch sa il pun pe canalu 3.Vreo sugestie?
Axial SCX10.3
Absima Sherpa
Axial Base Camp
#1253 Useril este offline   Ice_2k
  • Postari: 639
Postat 23 May 2015 - 11:02 PM
Un killer rc super bee dar e la alti bani (60$ in us)
#1254 Useril este offline   Kitty
  • RC Addict
  • Postari: 4563
Postat 23 May 2015 - 11:28 PM
Ala e singurul care face treaba asta?
Axial SCX10.3
Absima Sherpa
Axial Base Camp
#1255 Useril este offline   Ice_2k
  • Postari: 639
Postat 24 May 2015 - 09:24 AM
Pentru spektrum, din cate stiu eu da.
#1256 Useril este offline   revolt
  • Postari: 590
Postat 24 May 2015 - 01:44 PM
de azi :
Hpi Savage Flux XL
Hpi Savage Flux
#1257 Useril este offline   revolt
  • Postari: 590
Postat 24 May 2015 - 01:49 PM
Hpi Savage Flux XL
Hpi Savage Flux
#1258 Useril este offline   Ice_2k
  • Postari: 639
Postat 24 May 2015 - 04:13 PM
Nice! :) De unde ai luat body-ul?
#1259 Useril este offline   revolt
  • Postari: 590
Postat 24 May 2015 - 04:17 PM
de la mine.
am avut un super 5sc ce l-am convertit in Hpi savage FLUX XL tocmai din cauza spatiului mare de depozitare pe care il ocupa :D
Hpi Savage Flux XL
Hpi Savage Flux
#1260 Useril este offline   Ice_2k
  • Postari: 639
Postat 24 May 2015 - 04:24 PM
Ah, ok :) Caut si eu un body de genul asta pt buggy-ul meu ca sa pot intra pe pista de la frumusani...
  • 77 Pagini +
  • 40
  • 41
  • 42
  • 43
  • 44
11 useri citesc topicul
