Modelism - RHC Forum: revolutia gimbal-urilor - Modelism - RHC Forum
  • 13 Pagini +
#241 Useril este offline   Nanok@
  • Postari: 382
Postat 17 June 2013 - 04:56 PM
Basic requirements for the mechanical design of gimbal frame:
The possibility of precise balancing on three axes. The better the balance, the lower the current need for stabilization.
Mechanical rigidity of bearing elements to prevent resonances from working propellers in flight
Minimizing friction in the joints. The better the gimbal axis are unleashed from UAV camera platform, the less effort is required from the engine to stabilize
Elimination of vibrations from the main UAV frame. The vibrations have a negative impact on the quality of the video. But another negative effect in this system is that vibration will lead to self-excitation of the closed-loop controller.
Imi trebuie o schita de baza :) .. sunt un puturos nemernic .. am o bucla in procesul cognitiv .. si nu ma pot apuca de desenat :) ... e vorba de niste dimensiuni acolo .. :)
sunt 3 platband de alu , indoite in forma de |__| :)
http://img.readitlater.com/i/forums.openpilot.org/uploads/monthly_05_2013/blogentry-3518-0-92705000-1369365715_thumb/RS/w680.jpg
dar imi trebuiesc dimensiunile ..
cine vrea sa faca cu mine proiectul asta ?
#242 Useril este offline   renatoa
Postat 17 June 2013 - 05:28 PM
Cine a zis despre CAD si CNC ca... blegeste :)... nu stiu daca a zis-o cineva, dar cred ca e valabila :)
Pune bre, mana pe pila !
#243 Useril este offline   Nanok@
  • Postari: 382
Postat 18 June 2013 - 09:37 AM
Vezi postarearenatoa, la 17 June 2013 - 05:28 PM, a spus:
Ca blegeste .. asta nu pot spune , dar oricum , lumea fara proiectare ar fi doar o lume de "Doreli"care ar trage la pila .. fara sa gandeasca prea mult ...
E plin de astfel de erori de ..conceptie .. care de fapt sunt rezultatul unor "proiecte pe genunchi"
http://scienceblogs.com/worldsfair/wp-content/blogs.dir/389/files/2012/04/i-f417149ee4ee8be964f594340788b54f-Pic7.jpghttps://lh4.googleusercontent.com/-23lPAd2gw9s/UYgr3S_qJLI/AAAAAAACuXw/tacCFzVmlDY/w506-h350-o/60898_vos-enfants-vous-fatiguent-la-solution.jpg
Aceasta postare a fost editata de Nanok@: 18 June 2013 - 09:38 AM
#244 Useril este offline   Nanok@
  • Postari: 382
Postat 20 June 2013 - 09:17 AM
A aparut versiunea de zenmuse pentru GoPro H3-D2...
http://www.dji-innovations.com/wp-content/themes/dji/store/products/gallery/zen_h32d/_MG_4674.jpg
Si cel mai recent promo al celor de la DJI :
Ma bucur ca printre cei ale caror filme au fost alese pentru prezentare , se numara si un român , Eduard Shneider
min 9:00 ;)
binenteles ca toate filmele au fost facute ... fara noul ghimbal :) caci doar astazi a fost lansat !
#245 Useril este offline   worms
  • Postari: 1345
  • Inregistrat: 20-November 06
Postat 20 June 2013 - 09:28 AM
Vezi postareaNanok@, la 20 June 2013 - 09:17 AM, a spus:
atentie mare pentru cei ce vor cumpara acest gimbal. el nu merge fara naza sau wookong , giroscoapele folosite sunt cele din contolere, zenmuse nu are decat partea de drivere si video , el nu functioneaza cu Alex-mos sau Martinez.
Aceasta postare a fost editata de worms: 20 June 2013 - 09:29 AM
#246 Useril este offline   renatoa
Postat 20 June 2013 - 09:34 AM
Pai motoarele din el nu sunt tot BL rebobinate ? :unsure:
La cat costa... le urez clonare grabnica, mai ales ca m-au indispus cu citarea din Ansel Adams de la inceput...
#247 Useril este offline   Nanok@
  • Postari: 382
Postat 24 June 2013 - 12:06 PM
2x ALEXMOS Controler ==> Yaw Axis - Follow Me - 3 Axis Brushless Gimbal 380gr ... :)
#248 Useril este offline   Laur73
  • fotograf aerian
  • Postari: 1855
Postat 25 June 2013 - 04:11 PM
teste Lumix GH3 Brushless Gimbal
Fotografie Aeriana
#249 Useril este offline   jetix
  • Postari: 540
  • Inregistrat: 26-July 10
  • Interests:radioamatorismul
Postat 27 June 2013 - 03:51 PM
Nanok@, ai folosit stabilizatorul pentru gimbal de la GLB sau de la RcTimer? Ce parere ai, merita?
Si de ce ai folosit motoare asa mari pentru o camera cum e GoPro, doar pentru ca erau cele mai ieftine?
Aceasta postare a fost editata de jetix: 27 June 2013 - 03:52 PM
#250 Useril este offline   renatoa
Postat 27 June 2013 - 03:55 PM
mari ? alea sunt cele mai mici !
puterea vine din rotatie, ca gimbal ele lucreaza mai mult ca acul unui aparat de masura, puterea este infima.
#251 Useril este offline   jetix
  • Postari: 540
Postat 27 June 2013 - 08:30 PM
Mici? Atunci la un DSLR ce ar fi de pus?
Apropo, curele cu roti dintate de genul asta in tara unde s-ar putea gasi? Fara trimiteri la imprimante, copiatoare...
Aceasta postare a fost editata de jetix: 27 June 2013 - 08:34 PM
#252 Useril este offline   renatoa
Postat 27 June 2013 - 08:34 PM
Laur are la GH3 motoare 4008.
DSLR mai mare nu consider ca are rost sa fie aeropurtat.
Pentru dintzoase trimiteri in China se poate ?
Aceasta postare a fost editata de renatoa: 27 June 2013 - 08:36 PM
#253 Useril este offline   jetix
  • Postari: 540
Postat 27 June 2013 - 08:52 PM
Da ce, fratele popor chinez nu trebuie sa traiasca si el?
Cu motoare se ingreuneaza situatia gimbalului astfel ca ma uit in acelasi timp si la sero-uri. Daca folosesc o demultiplicare de 1:2 sau 1:4 logica ma duce ca acel servo trebuie sa depaseasca 360 de grade in rotatie, exista asemenea servo-uri?
Ma refeream la un DSLR normal, nu mai mare decat un GH3.
#254 Useril este offline   dan_mitea
Postat 28 June 2013 - 02:29 AM
As zice ca ei sunt taticii:
http://www.servocity.com/
PS. Tot acolo vei vedea ca la servo-urile Hitec ai optiunea pentru 90, 180 si 360 de grade. Sunt si servo-uri cu miscare continua.
#255 Useril este offline   jetix
  • Postari: 540
Postat 28 June 2013 - 07:34 AM
Multumesc pentru link.
Tot acolo am gasit si servo liniare de care eram interesat dar preturile m-au cam descurajat.
#256 Useril este offline   Nanok@
  • Postari: 382
Postat 28 June 2013 - 07:58 PM
Vezi postareajetix, la 27 June 2013 - 03:51 PM, a spus:
eu am luat de la renato gimbalul de la glb si motoarele de la rctimer (cele mici )
dar din pacate nu m-am apucat inca de el ... nu am nici o traagere de inima ...
am solidworks-ul in geanta de o saptamana dar nu am catadixist sa fac loc pe hardisc sa il instalez ... poate in weekend-ul asta ... sa fac simulare ..ca de taiat il tai la LASER frate din ALU de 2 mm sau de 3mm si il indoi la 90°
Mai astept si niste mici rulmenti sa imi vina din china dar decand cu prigoana impotriva rcmodelconstructorilor ... sta de pe 16.06 in posta pelgiana ...
#257 Useril este offline   worms
  • Postari: 1345
Postat 29 June 2013 - 11:44 AM
lucrurile incep sa se miste ametitor si deja a aparut si concurentul lui zenmuse pentru gopro si anume gimbalul de la Tarot care vine cu un concept nou de electronica de control cu procesor pe 32biti,pret imbatabil de 156$ gimbal complet(electronica,motoare si mecanica) cu urmatoarele specificatii:
Specifications
1. Support GOPRO Hero3 video output.
2. Support reverse power supply protection and power voltage compensation.
3. Support motor connector short circuit protection.
4. Support tilt initial angle setting.
5. Support adjustable gains and 3D attitude display on PC software.
6. Support stick rate mode and position mode.
7. Supported receiver type: conventional/S-BUS/DSM2/DSMJ/DSMX receiver.
8. Supported RC: PPM/PCM/2.4G.
9. Operating supply: DC 7.4V~14.8V (Li-Po 3S is recommended)
10. Operating current: 200mA-500mA (Depending on power supply voltage and motor power)
11. Operating temperature: -15ºC~65ºC.
12. CPU: Double 32bit ARM
13. Sensor technology: 3-axis MEMS gyro and accelerometer.
14. Max angular rate: 2000 º /sec.
15. Max acceleration: 16g.
16. Control frequency:2000Hz
17. Motor driver frequency: 20KHz (quiet and smooth)
18. Control accuracy: 0.1°
19. Control range: -45º~45º(roll), -135 º~90 º(tilt).
20. Attitude arithmetic: BLDC gimbal dedicated brushless motor decoupled EKF algorithm.
21. Aerial photography equipment: GOPRO Hero3.
http://www.foxtechfp...der-p-1096.html
  • Imagine atasata: 2.jpg
  • Imagine atasata: ss.jpg
Aceasta postare a fost editata de worms: 29 June 2013 - 11:45 AM
#258 Useril este offline   renatoa
Postat 29 June 2013 - 12:07 PM
Devii ametitor cu anti predictiile astea, exista controler cu stm32 cu un an inaintea lui alexmos, doar ca lituanianul e modest si nu are raspandaci.
#259 Useril este offline   worms
  • Postari: 1345
Postat 29 June 2013 - 12:16 PM
Vezi postarearenatoa, la 29 June 2013 - 12:07 PM, a spus:
corecta observatia dar omiteti esentialul : a fost de vanzare cumva? daca da atunci are cea mai proasta promovare din lume :) ca asa cica exista antigravitatie demult dar cine are sa o "descopere" acum si are sa o bage la vanzare ,ala culege toti laurii :D asa e si cu gimbalurile astea, sesizabile sunt doar cele de la vanzare si pe care le poate testa cine vrea ,restul nu exista.
Aceasta postare a fost editata de worms: 29 June 2013 - 12:17 PM
#260 Useril este offline   Darius_tm
  • Postari: 105
  • Inregistrat: 26-September 11
Postat 30 June 2013 - 07:59 AM
Intr-adevar asta pare cel mai bun gimbal la raport Calitate/pret, sper sa se faca si pt Hero2 dupa ce o sa demareze vanzarile si o sa vada ca se cauta.
#261 Useril este offline   renatoa
Postat 30 June 2013 - 08:17 AM
Vezi postareaDarius_tm, la 30 June 2013 - 07:59 AM, a spus:
Atunci alea putin peste 100$ de pe GLB cum sunt, daca asta este cel mai... ? :unsure:
Aceasta postare a fost editata de renatoa: 30 June 2013 - 08:18 AM
#262 Useril este offline   Darius_tm
  • Postari: 105
Postat 30 June 2013 - 09:19 AM
Nu stiu, asta l-am gasit pe youtube pus la treaba, si chiar imi parea ok la raportul calitate-pret, fata de zenmuse h3 2d, care e de vreo 5 ori mai scump. Celelalte de care spuneti au review-uri sa vedem cum lucreaza? Imi cer scuze, sunt doar amator-pasionat, nu veteran in domeniu :) Si ma bate gandul sa iau un Phantom si un gimbal din asta de la Tarot.
ar fi recomandari mai bune decat atat? As vrea o platforma aeriana stabila, cu gps si rth, fiabila pentru GoPro Hero2, pentru ca dupa cum spuneam mai sus, nu sunt foarte priceput la setari, si sa fac de la 0 totul. Eventual daca va puteti face niste timp, sa ma "luminati" si pe mine pe PM, ca sa nu fiu off-topic aici. Multumesc.
O zi bună!
#263 Useril este offline   renatoa
Postat 30 June 2013 - 09:34 AM
Vedeti, de asta nu razbat decat aia care au raspandaci, ca lumea nu se osteneste sa caute putin... vrea link.
Ca si cum pe youtube am gasi review-uri proaste... tot ce e acolo e de lauda.
Pai e unul la 109$ complet, care dupa nume am fi tentati sa credem ca ar fi dji original, dar la pretul asta...
http://www.goodluckb...hotography.html
Si cadre simple doar cu motoare, la 73$, pentru cei care vor sa isi puna propriul controller 3 axe cu STM32, care mai costa 45$, total 118$.
De dat sfaturi despre DJI nu sunt chiar cea mai indicata persoana...
Aceasta postare a fost editata de renatoa: 30 June 2013 - 09:35 AM
#264 Useril este offline   worms
  • Postari: 1345
Postat 30 June 2013 - 09:57 AM
Vezi postarearenatoa, la 30 June 2013 - 09:34 AM, a spus:
slabe rau gimbalurile alea desi ca si aspect sunt beton, daca va uitati cu atentie nu are nici un fel de reglaj de greutate pe cele 3 axe si atunci se pune intrebarea : cu se centreaza CG-ul? se poate ca din cauza ca sunt super usoare camerele gopro sa nu fie atat de important acest lucru pentru ca motoarele compenseaza lipsa cg prin forta lor dar nu sunt convins ca e asa ca nu m-am jucat cu niciuna sa vad cum e.cine are o montura de asta ne poate lumina de importanta acestui amanunt.oricum filmarea nu are sa iasa in veci ca la una cu centrul respectat in intersectia axelor ci are sa iasa ceva mai bun ca la o montura cu servo-uri.
#265 Useril este offline   renatoa
Postat 30 June 2013 - 11:03 AM
Si la ala Tarot unde sunt reglajele ? nu vad nimic sa sugereze asa ceva... :unsure:
Nu crezi ca, find dedicate gopro, sunt facute la mm ca sa bata CG din start unde trebuie ?
As carcoti tocmai de dedicarea asta, nu toti zboara cu gopro si multi ar fi interesati de ceva mai versatil, sa intre si o compacta...
Dar, vorba amicului Nanok, singura modalitate de a oprii invazia este aceea de a interzice filmările din multicoptere :)
Cand ai intr-un site de vanzari o sub-categorie numai gimbaluri de peste 100 de pozitii, ceva nu e in regula... sincer nu am simtit nevoia asta a pietei inainte de Alexmos... :unsure:
Aceasta postare a fost editata de renatoa: 30 June 2013 - 11:06 AM
#266 Useril este offline   Wheelflyer
  • Members
  • Postari: 172
  • Inregistrat: 16-July 10
Postat 05 July 2013 - 02:14 PM
Buna ziua,
Pana la urma, ce gimbal zboara lumea ?
S-a mai testat ceva ?
De doua zile , ma tot bate gadul sa pun cardul pe gimbal-ul din Dk.
Treaba e ca momentan folosesc primul model Gopro si ma gandesc la un upgrade, dar inca nu m-am decis la o camera anume.
Daca e sa achizitionez gimbal pentru primele 2 serii de Gopro, ,ar trebui sa-mi caut macar un GoPro 2 uzat, ca sa iasa cat de cat o filmare acceptabila.
In cazul in care ulterior as decide sa iau un Gpro 3, ma intreb daca pot adapta acel gimbal..ori sunt nevoit sa iau altul ?
Gimbal-ul de la Rctimer , am vazut ca nu e tocmai perfect si in anumite cazuri...a mai trebuit bibilit.
Restul... nu-mi mai bat capul, la cate sunt pe piata.
Cel din Dk pare singurul (din cele vizate de mine) despre care se vorbeste numai de bine.
#267 Useril este offline   Wheelflyer
  • Members
  • Postari: 172
Postat 05 July 2013 - 03:09 PM
Am omis sa adaug link catre un gimbal :
http://www.omgfly.co...roducts_id=1119
#268 Useril este offline   renatoa
Postat 05 July 2013 - 03:14 PM
De ce ii zici din Dk, site-ul este chinezesc... :unsure:
Asta e gimbal de camera mare, de nex, un gopro se pierde pe el... sunt cam derutat daca in cele doua mesaje vorbesti de acelasi lucru...
#269 Useril este offline   Wheelflyer
  • Members
  • Postari: 172
Postat 05 July 2013 - 05:16 PM
Vezi postarearenatoa, la 05 July 2013 - 03:14 PM, a spus:
E vina mea, ca am ganduri imprastiate si nu am fost prea coerent.
La inceput era vorba de cele doua modele de gimbal aproape identice, ambele pentru GoPro :
Cel de la Viacopter , din Danemarka : https://viacopter.eu/
Si copia mai ieftina de la Rctimer.
Acel gimbal mare ar fi fost o alternativa la un pret bun, in cazul in care achizitionez un reflex.
Un lucru e cert : mai evreme sau mai tarziu, trebuie sa fac upgrade la camera, insa pana atunci...vreau neaparat un gimbal sa il folosesc cu ce am la indemana.
Ca sa nu cheltui prea mult in aceasta perioada (mai sunt si alte prioritati) , ca si orima alegere ar fi modelul din Danemarka + achizitionarea unui GoPro 2 la mana a 2-a, in stare buna.
Sunt constient ca pierd, in momentul in care oricum voi achizitiona un reflex sau Gopro 3, insa deocamdata imi fac treaba fara cheltuieli majore, reusind astfel sa distribui banii si spre celelalte prioritati de moment.
Am zis ca deocamdata, cel mai important e sa merg inainte..sa nu raman blocat si cu stresul in gat.
Daca plec la drum cu hexa in regula, dotat cu gimbal + un multirotor de rezerva , as fi multumit deocamdata.
#270 Useril este offline   renatoa
Postat 05 July 2013 - 05:37 PM
Deja daca ai ajuns la ridicat dslr-uri pe mine m-ai pierdut... succesuri !
  • 13 Pagini +
13 useri citesc topicul
