tren aterizare de pe katana, pe delta
Postat 14 October 2012 - 07:27 PM
Jamba de fata o voi modifica daca va fi necesar (in poza prinderea ar fi pe verticala, deci perpendiculara pe planul placii/batiu motor.
Postat 14 October 2012 - 07:31 PM
Aceasta postare a fost editata de AG-74-HESS: 14 October 2012 - 07:33 PM
Postat 14 October 2012 - 07:42 PM
Aceasta postare a fost editata de AG-74-HESS: 14 October 2012 - 07:44 PM
Postat 14 October 2012 - 08:06 PM
Dar cred ca ar trebui tras mai in spate decat il ai pe desen, adica mai spre CG.
Aceasta postare a fost editata de AG-74-HESS: 14 October 2012 - 08:08 PM
Postat 14 October 2012 - 08:17 PM
Te las sa analizezi.
Aceasta postare a fost editata de AG-74-HESS: 14 October 2012 - 08:22 PM
Postat 14 October 2012 - 09:58 PM
AG-74-HESS, la 14 October 2012 - 08:17 PM, a spus:
am facut modificarile...dezvoltam proiectul impreuna si oricine are o sugestie buna..e invitat sa participe ..
ARIPA DELTA TERMIC.jpg (447.83K)
Postat 14 October 2012 - 10:03 PM
ARIPA DELTA TERMIC.jpg (485.02K)
Postat 15 October 2012 - 12:02 PM
grig, la 14 October 2012 - 10:03 PM, a spus:
poate un rezervor un pic mai mic ar fi mai indicat
http://phoenixmodels...ive-p-1352.html
ramane sa discutam problema..si sa gasim varianta optima
Postat 15 October 2012 - 12:08 PM
Postat 15 October 2012 - 07:25 PM
grig, la 15 October 2012 - 12:02 PM, a spus:
Chiar daca ar iesi urat in afara, nu pot pune mai mic; daca voi monta si rezonator mai zboara 5 minute. Nu am de gand sa-l zbor permanent in regim de racheta... Pe Katana, dupa vre-o 5 minute era jumate, si nu forjam prea tare la el. E cam sugativa motoru` asta, d`apai cu rezonator?! Sunt dispus sa-i fac o mascare, ceva, dar nu as vea mai mic... Plizzzz?!
``A fuel tank of approximately
350cc capacity for 75AX.This allows around 10 minutes flying time...``
Bogdane, daca postam la aero imi dadeau cei cu jeturile peste bot, iar daca postam in ``alta parte`` veneau prea multe sfatuti teoretice si ma incurcam printre sacerdoti. :rofl: Glumeam din cauza de iarba fumata; deocamdata e doar ping-pong.Practic daca se infiripa ceva, il mutam la aero, poate reinvie mania delta.Evident, daca ai mirosit ceva in neregula pana aici, lumineaza-ne, ca sa nu propagam gresala adanc in eroare. Mai bine remediat cu creonu pe cartie decat pe stofa clientului. :clapping:
#11
Postat 15 October 2012 - 07:32 PM
Am analizat bine dispunerea pe ultimul desen. Aranjament e de nota 10!
Bineee, uite, ultima strigare:
http://phoenixmodels...ive-p-1354.html
NU MAI LAS NIMIC! :clapping:
Aceasta postare a fost editata de AG-74-HESS: 15 October 2012 - 07:35 PM
#12
Postat 15 October 2012 - 07:38 PM
Aceasta postare a fost editata de AG-74-HESS: 15 October 2012 - 07:38 PM
#13
Postat 15 October 2012 - 08:00 PM
AG-74-HESS, la 15 October 2012 - 07:25 PM, a spus:
Omule -daca-mi dai voie sa spun asa-, mai bine decat pe mana grig-o-rescului, nu puteai ajunge. O si meriti! :clapping:
#14
Postat 15 October 2012 - 08:13 PM
AG-74-HESS, la 15 October 2012 - 07:32 PM, a spus:
ok...am facut modificarea
ARIPA DELTA TERMIC.jpg (477.33K)
#15
Postat 16 October 2012 - 01:26 PM
1-rezervor 1 buc(http://phoenixmodels...ive-p-1352.html)
2-fibra de sticla140gr 1 buc(http://phoenixmodels...0gmp-p-806.html)
3-fibra de sticla 110gr 1 buc(http://phoenixmodels...0gmp-p-699.html)
4- fibra de carbon 3 ml (http://phoenixmodels...nal-p-3484.html)
5-magneti neodymium 8 buc.pt winglet (http://www.euromagne...eB-disc-5x2-N48)optional
tre sa faci o comanda si sa le trimiti direct la mine...cand te decizi iti dau adresa de livrare
#16
Postat 16 October 2012 - 01:59 PM
grig, la 16 October 2012 - 01:26 PM, a spus:
si modificarea la modificare
ARIPA DELTA TERMIC.jpg (485.83K)
#17
Postat 16 October 2012 - 06:03 PM
Rezervorul de 284ml (112*64*46) e deja pe drum spre mine.
#19
Postat 16 October 2012 - 10:18 PM
ARIPA DELTA TERMIC.jpg (460.26K)
#20
Postat 16 October 2012 - 10:23 PM
AG-74-HESS, la 16 October 2012 - 06:03 PM, a spus:
din cate am citit in specificatia magnetilor 5x2 neodymium N48 au o forta de atractie de 700 de grame x 2 =1400gr..la 4 buc pe winglet revine 2,8 kg forta de retinere...sa nu se rupa winglet-ul la detasare...nu ca zic..doar spun...
#21
Postat 16 October 2012 - 10:31 PM
#22
Postat 16 October 2012 - 10:44 PM
ARIPA DELTA TERMIC.jpg (474.47K)
#23
Postat 16 October 2012 - 11:13 PM
#24
Postat 16 October 2012 - 11:28 PM
AG-74-HESS, la 16 October 2012 - 11:13 PM, a spus:
demontabila zici..hmmm,,e cam riscant la deriva centrala s-o facem detasabila caci se afla fix in turbulenta eliciei si motorul e destul de vanos...din cat estimez eu tre sa atinga macar un 200 ..si mi-e sa nu o lase pe drum printr-un picaj...dar ne gandim ...propune si tu o varianta cum vezi schema... ma gandeam dupa ce ai spus referitor la winglet-uri ca se pot desprinde la viteze mari ..sa fie macar deriva centrala fixa ...sa ramana ceva de stabilizare...dar asta cu siguranta o sa vedem dupa primul zbor...cu mult nitro..
#25
Postat 17 October 2012 - 07:12 AM
Ocupa bancheta fara probleme ,lasa deriva fixa,e mai sigur.
Ingerii zboara pentru ca o iau usor .....
#26
Postat 17 October 2012 - 09:51 AM
ARIPA DELTA TERMIC.jpg (495.85K)
#28
Postat 17 October 2012 - 09:30 PM
Rottyrc, la 17 October 2012 - 07:12 AM, a spus:
Nu. Prefer si 100 grame in plus reprezentand o placa suport + 4 suruburi si ce intarituri or mai trebui in aripa pt prindere.
La suprafata ei, nu ma sperie greutatea....(stim noi :good:). Asta si la 4kile jumate daca ar iesi o zbor fara pampers. :D (evident va avea muuuult mai putin, deci no-problem!)
PS. Legat de pampers, zice unu dupa maiden: daca imi bagai o tzeava`n cur o fac saibe. :drinks:
Aceasta postare a fost editata de AG-74-HESS: 17 October 2012 - 09:30 PM
#29
Postat 19 October 2012 - 07:53 PM
#30
Postat 20 October 2012 - 08:01 AM
AG-74-HESS, la 19 October 2012 - 07:53 PM, a spus:
Super treaba
am facut comanda pt materiale..pe marti saptamana viitoare tre sa ajunga...si incalzim rindeaua...
placj pt batiu si suruburi de plastic pt winglet mi-a adus Rotty...
imprumuta de la adrian camera aia mica si monteazo pe aripa undeva in zona wingletului sa prinda in imagine si motorul..sa vedem si noi de sus cum se misca "bestia".. :clapping:
Aceasta postare a fost editata de grig: 20 October 2012 - 08:05 AM
