Modelism - RHC Forum: ESC Graupner - Modelism - RHC Forum
ESC Graupner
#1 Useril este offline   iozsi39
  • Postari: 82
  • Inregistrat: 06-September 09
Postat 13 August 2012 - 08:52 PM
Buna seara tuturor.Am primit un ESC Graupner de 35A second-hand.Dupa ce l-am pus pe model si am incercat motorul am observat ca porneste doar de la jumatatea cursei(mansei) in sus.Nu ma pricep la programari,dar cred ca este activata frana.Elicea se opreste brusc de la jumatatea cursei in jos.Ce e de facut?Eu cred ca este ceva de la programare.Mentionez ca am resetat canalul respectiv din statie.Se poate reseta cumva ESC-ul fara card?
  • Imagine atasata: ESC.jpg
#2 Useril este offline   GST 7.7
  • Sky isn't the limit
  • Postari: 1074
  • Inregistrat: 13-August 07
  • Interests:Programare, IT, Modelism
Postat 13 August 2012 - 08:57 PM
Calibreazal cu statia. Porneste statia cu mansa de gaz sus alimentezi esc o sa faca beep apoi dai mansa jos o sa beepaie de 2 ori si gata
The GST 7.7 is over 30% larger than a Revo 3.3. Park the GST 7.7 next to a Savage, and the Savage doesn't look so tough anymore.
VISTA = Virus Inside Switch to Apple
#3 Useril este offline   iozsi39
  • Postari: 82
Postat 14 August 2012 - 06:43 AM
Am incercat varianta asta,dar cred ca nu a beep-it cand eram cu mansa sus.Poate nu am stat suficient de mult!?
#4 Useril este offline   DanB
  • Postari: 1551
  • Inregistrat: 22-July 11
Postat 14 August 2012 - 07:08 AM
Mie imi apare asa de mica poza ca nu disting modelul.
In momentul asta site-ul graupner.de nu merge asa ca nu ajung la documentatie. Poate te ajuta asta:
The Graupner ESC has a mini toggle make/break switch containing two LED (Red & Green).
When you connect the flight pack the motor beeps quote 'Do,Re-Do,Re,Me' the Red and Grn LEDS are illuminated. As you advance thottle to full power the red only shows. To program you await the beep, press the toggle swith wait for further beeps then proceed as per most ESC with a succession of full/closed throttle moves in quick succession.
The instructions if you are curious are on the Graupner site as a pdf file:
https://shop.graupne...et/AI?ARTN=7233
USER BANNED BY ADMIN
#5 Useril este offline   iozsi39
  • Postari: 82
Postat 14 August 2012 - 01:49 PM
Cred ca am descoperit ceva la ESC.Nu-mi dadeam seama despre ce buton de programare este vorba.Uitandu-ma la ESC cu lupa am descoperit o mufa mica pe langa cablul BEC.Cred ca acolo venea cablul negru din desen,si pe el cred ca e atasat butonul pentru programare si posibil ceva leduri.Mufa de pe ESC este prevazuta cu 4 contacte.Stie careva care sunt cele doua contacte(sau mai multe?!)cu care pot programa ESC-ul?Poate ma ajuta cei care repara ESC-uri!?As putea sa realizez o mufa mica si sa o introduc in acel locas,dar mie frica sa fac legatura intre ele sa nu deteriorez ESC.Numai bine.
#6 Useril este offline   DanB
  • Postari: 1551
Postat 14 August 2012 - 03:37 PM
Nu faci tu niste poze mai mari cu esc-ul, sa vedem ce model e?
#7 Useril este offline   iozsi39
  • Postari: 82
Postat 14 August 2012 - 08:29 PM
Am facut ceva poze.Se vede si mufa despre care am vorbit.
  • Imagine atasata: Fotogr.0154.jpg
  • Imagine atasata: Fotogr.0155.jpg
#8 Useril este offline   DanB
  • Postari: 1551
Postat 14 August 2012 - 09:41 PM
Nu-mi dau seama din poze, in manual zice ceva de un buton de set, si de procedura de calibrare:
If you press and hold the Setup switch on the Switch box for over 1 second, the Green LED should flash.
At this time, if your hand is released from the Setup switch. The motor should beep like So, So, La, La, So, So and the Green LED should flash one time.
7. Move the throttle sticker to the full position and press and release the switch, the Green LED should flash twice to indicate that the full position has been set.
8. Move again the throttle stick to the neutral position ( if 3 position was set ) or minimum position ( if 2 position was set ) and press and release the switch, the Green LED should flash triple time to indicate that the neutral position for 3 position or minimum position for 2 position has been set,
#9 Useril este offline   iozsi39
  • Postari: 82
Postat 15 August 2012 - 07:45 AM
Da am citit si eu instructiunile.Dar nu gaseam butonul,si nici LED-le.Asa ca am comparat poza originala cu ESC-ul meu.Si am observat lipsa cablului subtire si negru de langa borna negativa.Asa ca m-am uitat pe langa borna si am observat acea mica mufa alba.Seamana cu mufa de egalizare de pe unele incarcatoare.Pe poza originala,la capatul firului negru subtire este un buton.Asa ca banuiesc ca acela este cel de programare.Dar de ce LED-uri se vorbeste?!Unde sunt?!Ca pe ESC nu se aprinde nimic.Poate doar cand se programeaza?!Mufa pe interior are 4 borne minuscule.Poate au si altii ESC-ul asta si nu si=au dat seama ca dupa programare se poate scoate cablul cu butonul din mufa!?
#10 Useril este offline   iozsi39
  • Postari: 82
Postat 18 August 2012 - 07:12 AM
Buna dimineata.Chiar nu are nimeni ESC Graupner sa ne lamureasca?! :rolleyes:
#11 Useril este offline   ViorelX
  • Postari: 537
  • Inregistrat: 06-October 09
  • Interests:modelism, electronica, mecanica
Postat 18 September 2012 - 05:51 PM
Am si eu un ESC din seria asta, cumparat nou. Are intr-adevar un buton si 2 LED-uri intr-o carcasa externa minuscula legata de ESC printr-un cablu delicat cu 4 firisoare. La tine e rupt.
ESC-ul este universal, pt aero-, navo- si auto-, pozitia neutra a acceleratiei se poate seta la mijloc pt a permite 2 sensuri de rotatie a motorului (pt masini).
Fara acel buton extern nu poti programa ESC-ul, asa ca nu-ti ramane decat sa-l refaci. Iei 4 firisoare, un microintrerupator si 2 LED-uri SMD, unul rosu si altul verde si faci un mic montaj ca in schema de mai jos, pe care tocmai am relevat-o de la ESC-ul meu.
Cu R V G N am notat firele rosu, verde, gri, negru care trebuie sa iasa din mufa aceea mica care ti-a mai ramas pe placa.
  • Imagine atasata: esc graupner.jpg
