Modelism - RHC Forum: Rise of the machines :D - Modelism - RHC Forum
  • 35 Pagini +
Rise of the machines :D ... astora incepe sa le fie frica...
#1 Useril este offline   renatoa
Postat 04 September 2012 - 03:39 PM
... DE NOI ! :drinks:
http://www.abc.net.a...12/s3582815.htm
sau, e doar jurnalism de vara, nu au si ei o lovitura de stat sa comenteze :p
#2 Useril este offline   Para
  • Postari: 462
  • Inregistrat: 20-December 11
Postat 05 September 2012 - 07:03 PM
Bluetooth, xbee-uri, o sa aiba SkyNet-ul cum sa faca takeover la dronele noastre :yahoo:
#3 Useril este offline   Zen
  • Postari: 1185
  • Inregistrat: 14-January 09
Postat 05 September 2012 - 07:20 PM
Parca nu inspira frica, dar este prima formatie pe care o vad afara, nu intr-o camera impanzita de leduri IR :yahoo:
http://www.youtube.c...&v=ShGl5rQK3ew#
Aceasta postare a fost editata de Zen: 05 September 2012 - 07:25 PM
#4 Useril este offline   GST 7.7
  • Sky isn't the limit
  • Postari: 1074
  • Inregistrat: 13-August 07
  • Interests:Programare, IT, Modelism
Postat 05 September 2012 - 07:24 PM
Deja Skynet are si arme
The GST 7.7 is over 30% larger than a Revo 3.3. Park the GST 7.7 next to a Savage, and the Savage doesn't look so tough anymore.
VISTA = Virus Inside Switch to Apple
#5 Useril este offline   Nanok@
  • Postari: 382
  • Inregistrat: 29-September 10
Postat 08 September 2012 - 10:52 AM
mda "este inca ilegal ca dronele sa fie folosite in scopuri comerciale" ..e evident ca se duce campanie in state pentru a le baga sub o forma de impozitare si , de ce nu, controla ... totul e business :drinks:
uite aici "Rise of the Machines" ;)
LE @Zen sorry ! nu am vazut postul tau ... este acelasi film ...
Aceasta postare a fost editata de Nanok@: 08 September 2012 - 10:53 AM
The quieter you become, the more you can hear
-- Stay Hungry, Stay Foolish! --
#6 Useril este offline   jetix
  • Postari: 540
  • Inregistrat: 26-July 10
  • Interests:radioamatorismul
Postat 08 September 2012 - 08:48 PM
Am un comentariu la filmuletul postat de GST7.7 in sensul ca ce au vrut sa demonstreze rusii (am dedus din engleza tipica vorbita de ei si dupa un nume rostit) cu acel quad inarmat nu prea este viabil. Cei care au avut ocazia in viata sa traga cu diferite tipuri de arme cred ca-mi vor da dreptate. Arma zburatoare, ca sa o numesc asa, are doua neajunsuri care o fac vulnerabila. Primul ar fi distanta mica de la care se vizeaza si neutralizeaza tinta iar al doilea e timpul destul de mare de la vizare pana la neutralizarea acesteia, ceea ce da posibilitatea inamicului sa o doboare. Cu o rafala de AK47 ai terminat-o. Apoi, ce naiba, ca doar teroristii, contrabandistii adica cei numiti generic "baietii rai" :) nu stau si joaca toata ziua carti asteptand impasibili sa vina copterul sa-i casapeasca. Singura functie care ar fi viabila ar fi cea de kamikaze, asa cum fost la sfarsitul filmuletului. Ridicat la o inaltime suficient de mare ca sa nu fie auzit/detectat si coborat deasupra tintei in viteza pana la impactul cu aceasta.
Evident ca acest filmulet este o actiune de marketing cu scopul de a atrage atentia asupra unei posibile utilizari. Eu nu as vedea un copter cu rol combatant ci mai degraba unul logistic. "Inarmat" cu o camera buna si inaltat pe la 200-300m poate furniza informatii utile privinda pozitionarea/miscarea inamicului. E ceva asemanator cu supravegherea traficului rutier din aer, asa cum am inteles ca in unele tari se face deja.
Dar noi nu avem treba cu aceste aplicatii, nu? :) Ne vedem de fotografiile/filmarile noastre pasnice... :D
Postat 08 September 2012 - 09:04 PM
De la 2-300m as folosi un avion fara sa ma gandesc o clipa la un multicopter, la asemenea inaltime statul la punct fix isi pierde orice avantaj, poti face cercuri de 50-100m tinind sub observatie o zona fixa folosind o camera cu tracking si consumand mult mai putin.
#8 Useril este offline   Zen
  • Postari: 1185
Postat 08 September 2012 - 09:07 PM
Oricum acel quad nu este real, este un CGI lucrat destul de bine, dar nu suficient incat sa nu se observe miscaril irealiste.
#9 Useril este offline   Zen
  • Postari: 1185
Postat 08 September 2012 - 09:14 PM
PS. trebuie sa fii imbecil sa pui arme pe ceva atat de unreliable, cu posibilitatea sa traga chiar in tine din nu stiu ce eroare. Cel mai probabil e si ilegal, nu cunosc totusi regimul armelor si munitiilor. Ma rog, in mother russia merge :)
#10 Useril este offline   Nanok@
  • Postari: 382
Postat 09 September 2012 - 02:34 AM
eu mai degraba as plati un 'raketz' rus decat sa pun arma pe copter :blush: copterele ..aceste zburatoare ..pure :)
pan una alta ... cea mai de "interzis" aplicatie a copterelor este filmarea proprietatilor private , fara acordul proprietarilor paparazzo daca vrei ..Cred ca din cauza asta o sa le interzica in oras ..din cauza asta si binenteles din cauza banilor pe care ii pot produce :)
#11 Useril este offline   Para
  • Postari: 462
Postat 09 September 2012 - 12:45 PM
Nu cred ca le pot interzice... ganditi-va ca trebuiesc formulate cumva regulile...
Vreau sa-i vad cum scriu ei o lege care interzice Parrot-ul :)
#12 Useril este offline   Nanok@
  • Postari: 382
Postat 09 September 2012 - 01:46 PM
pot spune ca dispozitivele zburatoare mai grele de xx gr.vor putea fi radiocomandate in afara terenurilor de zbor (aeroclub) doar cu o autorizatie speciala si gata ... te-a prins ..ti-l confisca ...sa pui bariere nu este greu ...
#13 Useril este offline   Para
  • Postari: 462
Postat 10 September 2012 - 03:29 AM
Ba e greu... e ca si cum ai vrea sa interzici vanzarea obiectivelor tele pentru aparatele foto pe motiv ca pot fi folosite de papparazzi...
N-ai cum sa interzici zborul unei jucarii telecomandate. Poti eventual sa-i creezi un cadru legal, sa stabilesti niste reguli si standarde, astfel incat sa nu vina politia dupa pustiul de 10 ani caruia i-a luat tati un coaxial din Cora si l-a scapat peste gard la vecini.
#14 Useril este offline   Zen
  • Postari: 1185
Postat 26 September 2012 - 08:46 AM
Multicopteristul smooth video viseaza :unsure:
http://vimeo.com/49484105
Aceasta postare a fost editata de Zen: 26 September 2012 - 08:47 AM
#15 Useril este offline   vvrest
  • Postari: 907
  • Inregistrat: 29-September 09
Postat 26 September 2012 - 12:52 PM
Cred ca totul se poate reduce la ...."Feel like a kid !" si libertate totala.
Superb clipul..
Postat 25 October 2012 - 08:34 AM
De Halloween :pardon:
#17 Useril este offline   Nanok@
  • Postari: 382
Postat 31 October 2012 - 11:14 PM
:D am incercat si eu sa sperii copiii vecinelor :good:
  • Postari: 8333
Postat 14 November 2012 - 09:15 AM
Incredible UFOs Land and Launch Over Denver 2012 HQ
DJI Quad with FPV - nu am gasit alt loc mai bun sa o pun dar ati prins ideea.
Postat 03 December 2012 - 10:27 AM
Pentru cine vrea o meserie cinstita, hi-tech, dar la aer curat... adunatul vacilor cu copterul
#20 Useril este offline   Para
  • Postari: 462
Postat 03 December 2012 - 12:01 PM
M-am distrat odata c-o turma de oi. Fluierau ciobanii, latrau cainii, dar in 3 minute le-am strans compact si le-am mutat intr-un colt al campului. Dupa care am strans jucaria si am sters-o englezeste, caci nu cred ca erau foarte fericiti si n-aveam chef de vreo bâta pe cârca. :)
#21 Useril este offline   adioperator
  • Postari: 1356
  • Inregistrat: 12-November 09
  • Interests:aeromodelism
Postat 03 December 2012 - 03:11 PM
Ieri mergeam la parinti la tara si pe campurile cu grau proaspat rasarit au aparut gastele salbatice, bine inteles ca acestea fac numai stricaciuni pentru cultura. Imi trecea prin cap sa zbor aeromodelul dupa ele dar nu-l aveam la mine :D
#22 Useril este offline   jetix
  • Postari: 540
Postat 03 December 2012 - 06:03 PM
Asa invie aviatia utilitara... la joasa inaltime :lol:
Postat 30 December 2012 - 10:43 PM
Narozenia anului in domeniu !
Postat 31 December 2012 - 06:44 PM
Un smecher nou in parcare...
http://www.ai-rider....en/product.html
#25 Useril este offline   Nanok@
  • Postari: 382
Postat 21 January 2013 - 08:23 PM
Attack of the Drones - USA...
si
Rise of the Machines - USA
la mine aici , "policia" a dotat deja echipe cu "drone" ...
https://vimeo.com/41493737
Postat 28 January 2013 - 08:03 PM
Parca maine il vedem pe Laur facand teste cu ea... :)
http://www.imaging-r...rlds-highest-de
#27 Useril este offline   Nanok@
  • Postari: 382
Postat 02 February 2013 - 04:08 PM
#28 Useril este offline   Nanok@
  • Postari: 382
Postat 05 February 2013 - 09:19 AM
A inceput .... : (
Oregon Senate Bill 71 Bans FPV Flying and Other "Drones"
Aceasta postare a fost editata de Nanok@: 05 February 2013 - 09:20 AM
Postat 05 February 2013 - 09:27 AM
Ce aiurea suna "sky ownership"... deci, sa fie clar, cerul nu e al vostru, nici al urmasilor vostri...
Pentru cine e amator de citit limbaj de lemn politician:
http://www.fas.org/s...tsec/R42940.pdf
Postat 06 February 2013 - 09:36 AM
Urmeaza Texas, si apoi Oklahoma cu legi anti drone...
http://www.legis.sta...=83R&Bill=HB912
"Noroc" pe americani ca la ei se adopta la nivel de stat... or mai ramane niste state deschise pentru zburat liber.
  • 35 Pagini +
8 useri citesc topicul
