Sbach_342_"scandurica " balsa_polistiren_depron
Postat 17 July 2012 - 07:20 PM
Modele FPV
Piper-Wot4
Modelare 3D
Modele pt.simulator - RealFlight :
LazyBee;SpeedyBee;Aurora Scimitar;Sbach 342;BV 141;Heptad
Postat 17 July 2012 - 07:22 PM
si
Sbach_342.part1.rar.txt (488.28K)
Number of downloads: 330 -
Sbach_342.part2.rar.txt (488.28K)
Number of downloads: 277 -
Sbach_342.part3.rar.txt (100.96K)
Modele FPV
Piper-Wot4
Modelare 3D
Postat 18 July 2012 - 01:52 AM
Postat 18 July 2012 - 02:48 AM
Multa, multa bafta, mestere.
Postat 18 July 2012 - 08:24 AM
GALLY, la 18 July 2012 - 01:52 AM, a spus:
Toate cele 3 parti ale arhivei rar a pdf-ului 3D trebuiesc download-ate - si binenteles redenumite rar. Am fost nevoit sa impart arhiva din cauza limitei de 500 kb impusa . Planuri voi posta dupa ce avansez cu modelul . Ca sursa constructiva de inspiratie am avut Tribute 36. Caracteristici :
Avergura: 120 cm
Lungime : 110 cm
Greutate : ~800 gr.
Motor: Turnigy_Park480_Brushless_Outrunner_1020kv
Elice : 10x6 tripala
Esc: TURNIGY_Plush_40amp_Speed_Controller
Lipo: ZIPPY_Flightmax_2200mAh_3S1P_30C
Servo: MG90S - angrenaje metalice ( 13.2 gr.)
- Fuselajul va fi construit din polistiren A100 de 2 cm grosime placat cu balsa de 1.5 mm
- Aripile : taiate cu fir cald din polistiren A 70 si placate cu balsa la BA ; BF si capete de planuri pentru a o putea infolia ulterior
- Ampenajele : balsa - baghete de 6 mm infoliate cu coverfilm
Aceasta postare a fost editata de pccdtk: 18 July 2012 - 08:28 AM
Modele FPV
Piper-Wot4
Modelare 3D
Postat 18 July 2012 - 08:40 AM
Modele FPV
Piper-Wot4
Modelare 3D
Postat 19 July 2012 - 08:18 PM
Mai e, de muuuuuult, neste folie termoformare .
Vezi la terenuri de zbor cand ne putem vedea la CET
:yahoo:
Postat 19 July 2012 - 08:36 PM
Postat 19 July 2012 - 10:51 PM
Modele FPV
Piper-Wot4
Modelare 3D
#11
Postat 20 July 2012 - 03:11 PM
Modele FPV
Piper-Wot4
Modelare 3D
#12
Postat 23 July 2012 - 08:14 PM
Modele FPV
Piper-Wot4
Modelare 3D
#13
Postat 23 July 2012 - 10:04 PM
#14
Postat 23 July 2012 - 10:16 PM
#15
Postat 27 July 2012 - 06:57 PM
ALLEN, la 23 July 2012 - 10:16 PM, a spus:
Voi incerca . Aripa gata de infoliere si batiu motor electric refacut cu silence-uri din furtun siliconic cu saibe de cauciuc :
Modele FPV
Piper-Wot4
Modelare 3D
#16
Postat 27 July 2012 - 07:45 PM
#17
Postat 27 July 2012 - 11:25 PM
catamures, la 27 July 2012 - 07:45 PM, a spus:
Multumesc !!! Sper sa si zboare corespunzator . Cat despre motor, NU se misca !!! Acelasi tip de motor si acelasi tip de batiu folosesc deja pe un Heptad de 180 cm anvergura. Spre surpriza mea nu mai vibreaza deloc si nu se mai aude decat sunetul pe care-l face elicea invartindu-se . Sper ca silence-urile batiului de mai sus sa fie si mai bune pt.ca am folosit cauciuc siliconic in locul cauciucului obisnuit .
Modele FPV
Piper-Wot4
Modelare 3D
#18
Postat 28 July 2012 - 05:22 AM
scuze oftopic :drinks:
#19
Postat 28 July 2012 - 06:25 AM
Modele FPV
Piper-Wot4
Modelare 3D
#20
Postat 28 July 2012 - 02:11 PM
Daca-mi permiti o sugestie. Exista astfel de silence-uri in cd-romurile decedate. Au capacitate de amortizare excelenta.
#21
Postat 28 July 2012 - 07:58 PM
Modele FPV
Piper-Wot4
Modelare 3D
#22
Postat 29 July 2012 - 07:30 AM
#23
Postat 31 July 2012 - 09:13 AM
Modele FPV
Piper-Wot4
Modelare 3D
#24
Postat 31 July 2012 - 10:00 AM
Ai gasit undeva pe un forum de modelism mai multe detalii? Poti te rog sa imi dai mai multe detalii? Poate mai multe poze cu aripa ta?
Merci,
#25
spor la munca!
Aceasta postare a fost editata de typer: 31 July 2012 - 10:04 AM
"I have always said i'd rather crash a pretty plane than fly an ugly one..." Dave F.
#26
Postat 31 July 2012 - 01:05 PM
blue, la 31 July 2012 - 10:00 AM, a spus:
2.Ai gasit undeva pe un forum de modelism mai multe detalii? Poti te rog sa imi dai mai multe detalii? Poate mai multe poze cu aripa ta?
Merci,
1.Uite cum arata o aripa pe care am facut-o in acelasi stil ( pt.PWot ) :
2.N-as putea sa-ti dau un link catre ceva similar ( ideea a aparut in urma dicutiilor dintr-un alt topic ) insa dupa mine e destul de simplu :
- se taie cu fir cald semiplanurile si se lipesc intre ele
- se taie un sant tot cu fir cald ( merge si cu ansa profilata corespunzator a ciocanului de lipit ) si se ingroapa lonjeroane cam in linia cg si la 2/3 din CA
- se lipesc fasii de balsa la BA si BF. Ca fasia din BA sa se muleze se uda pe exterior si se autoformeaza
- se lipesc fasii transversale din balsa de 1-1.5 mm - si cam asta este tot.
Aceasta postare a fost editata de pccdtk: 31 July 2012 - 01:10 PM
Modele FPV
Piper-Wot4
Modelare 3D
#27
Postat 31 July 2012 - 01:12 PM
Modele FPV
Piper-Wot4
Modelare 3D
#28
Postat 31 July 2012 - 01:16 PM
typer, la 31 July 2012 - 10:00 AM, a spus:
spor la munca!
Aripa se prinde de fuselaj in 4 bucati de cornier de plastic ( se vad in poza cu trenul de aterizare ) . Am ingropat doua "talpi" din placaj in aripa si de asemenea am dublat zonele pe fuselaj unde elementele de prindere se vor sprijini. Aripa sper sa nu iasa cu totul mai grea de 250 - 270 gr iar tot modelul mai greu de 900 - 950 gr.
Modele FPV
Piper-Wot4
Modelare 3D
#29
Postat 31 July 2012 - 03:32 PM
Se potriveste perfect la ce vreau si eu sa fac.
Succes.
#30
Postat 16 August 2012 - 04:52 PM
- am fost nevoit sa-l echilibrez cu 40 gr. greutate imediat dupa panoul de foc - asa incat intentionez sa-i refac profundorul - poate mai scutesc ceva greutate .
- este submotorizat ceea ce va duce la schimbarea motorului cu un BL FC3542-6T, Kv 920 ( diferenta de greutate 135 - 95 gr. ma scuteste si de "saibe" ca lest )
- spre surpiza mea vine la aterizare destul de usor .
Deocamdat cateva imagini ( voi reveni ulterior si cu film - numai sa-l remotorizez ) :...
Aceasta postare a fost editata de pccdtk: 16 August 2012 - 04:53 PM
Modele FPV
Piper-Wot4
Modelare 3D
