  • 74 Pagini +
#241 Useril este offline   renatoa
Postat 07 January 2014 - 07:57 PM
Nope, ala e firav, scrie si in fisa lui ca maxim 1.7m.
Pt. Bot-ic as vedea asta, cu o elice de 12-13"
http://aircraft-worl...exd.asp?id=5536
#242 Useril este offline   dan_mitea
Postat 08 January 2014 - 04:10 AM
Multumesc frumos. Il iau, sau imi dai si alta optiune (incapsulat)?
#243 Useril este offline   renatoa
Postat 08 January 2014 - 08:00 AM
Da, GliderDrive SK3 4.6 840kv de la HK.
#244 Useril este offline   dan_mitea
Postat 08 January 2014 - 02:14 PM
Sa traiesti o mie de ani. Acum, te rog sa ma scuzi ca sunt ca o soacra, dar, nu-i cam greut? M-am uitat la HK si am vazut si unul mai usurel:
http://www.hobbyking..._3_5_960kv.html
Sa nu uitam ca am ramas la varianta de nas lungit.
Ce zici?
Si, daca tot te necajesc, imi dai si o idee de ESC?
#245 Useril este offline   renatoa
Postat 08 January 2014 - 02:32 PM
Merge si ala, dar totusi... avand in vedere ca matale respecti planurile si nu pui la indoiala ce au gandit "proiectantii", cred ca inca nu esti convins ca vei lupta cu o coada mai grea decat esti obisnuit de obicei... poate citatele de mai jos te pun pe ganduri:
"True story: How I became a scratch builder.
I worked in a hobby shop when the first Bird of Time kits were produced. We waited with baited breath for the first kit to arrive. When I opened the kit, the hardest, heaviest piece of wood was the rudder. It was literally more dense than the nose block. (I bet it took 20 oz of ballast to balance that kit)
so.......... I used the pieces in the kit as templates to reproduce all the parts with better wood..."
http://www.rcgroups....55&postcount=22
Si asta inca este o relatare recenta, surprinzator cum se apuca asta de construit un BoT asa simultan cu dumneata.
Dar forumurile sunt pline de aceleasi "complimente" adunate de-a lungul anilor la adresa acestui fuselaj cam neispirat pentru aripa aceea.
De ESC... ceva fara pretentii, eu am asta:
http://www.hobbyking...ontroller_.html
Aceasta postare a fost editata de renatoa: 08 January 2014 - 02:33 PM
#246 Useril este offline   dan_mitea
Postat 08 January 2014 - 07:22 PM
In timp ce, inca, ma mosmondesc la partea centrala a aripii, tot cuget. Azi, as zice cam asa: lungim nasucul si as incerca sa fac ampenajele cat mai usoare. Chiar ma tenteaza ideea sa le fac laminate cala Lazy Bee si sa le acopar cu folie subtire. Am renuntat la ideea de a pune servo in spate.
Pentru receptie folosesti o alta baterie? Sau folosesti BEC-ul din ESC?
#247 Useril este offline   renatoa
Postat 08 January 2014 - 07:55 PM
BEC-ul, nu prea are de munca cu doar doua servo...
#248 Useril este offline   stiganas
  • Postari: 8326
Postat 11 January 2014 - 11:17 PM
Se zboara iarna planoare foarte foarte bine.
Practic nu am avut iesire fara termica. Azi in mod special a fost o zi calda cu soare, din 4 zboruri in unul am facut timpul de 10 minute si planorul a urcat la 240m.
Radianul lansat cu limitator la 150m. Ar fi urcat si mai sus dar batea ceva vant si il ducea prea departe pentru ochii mei.
Limitatorul e fenomenal, nu trebuie sa faci nimic, pur si simplu la fiecare zbor taie motorul la inaltimea stabilita (150m). Am cuplat LCD-ul doar pentru ca am vrut sa vad inaltimea maxima atinsa.
Chiar si in zilele cu ceata si nori am prins cate ceva.
#249 Useril este offline   edisultan
  • Postari: 2077
  • Inregistrat: 16-March 08
Postat 12 January 2014 - 12:01 AM
Da, orice firicel de căldură urcă suficient de repede. Azi la Constanţa vântul a bătut dinspre autostradă aşa că am avut parte de câteva ore de zbor cu planorul ("capetele" căminului de termică au fost destul de puternice). Vremea a ţinut cu noi şi cel puţin eu am avut timp să experimentez modurile de zbor încărcate în staţie.
Sultan Eduard
#250 Useril este offline   F2B
  • Postari: 921
  • Inregistrat: 30-November 11
Postat 13 January 2014 - 06:53 PM
Am prins o zi buna aici si am luat avantaj de ea. Mi se parea ca faceam ceva rau dar conditiile la altitudine mica sub 15M erau turbulente mari. Eram aruncat a o hirtie in vint peste tot. Numai cind erai peste 100M zburai in aer curat si sa ajungi acolo a trabuit sa m aasez la munca.
Am avut citeva zboruri asa de departe ca deabea vedeam modelul si am fost fortat sa ma intorc.
A fost o zi interesanta, buna practica.
#251 Useril este offline   renatoa
Postat 28 January 2014 - 10:05 AM
4m, depron intarit cu bete de undita, 500 grame ! prins cu banda, i-a luat 3 ore sa il faca... si indoor, de sezon
cine se mai plange ca nu e fun sub 1kg ? :)
#252 Useril este offline   renatoa
Postat 27 February 2014 - 10:12 AM
Dupa niste zvonuri, Nan Models sta sa inchida... iar cu evenimentele din UKR, Vladimir Models, care sunt in harkov, in partea rusa, nu se stie ce o sa devina... nu m-as mira sa asistam la un cutremur al pietei de planoare...
Poate asta o fi sutul in cur necesar sa ma hotaresc sa comand un Pulsar :)
Aceasta postare a fost editata de renatoa: 27 February 2014 - 10:13 AM
#253 Useril este offline   MADA
  • Postari: 987
  • Inregistrat: 09-August 04
Postat 27 February 2014 - 11:12 AM
Vezi postarearenatoa, la 27 February 2014 - 10:12 AM, a spus:
Hyperflight tocmai aduce variantele Pro de 3.6 si 4 m electrice, are transportul pe drum B)
#254 Useril este offline   renatoa
Postat 27 February 2014 - 11:29 AM
E prea scump la HF, in Germania pretul are cam aceleasi cifre, doar ca in Euro versus GBP, cam 22% diferenta, cu care mai bine finantez partial echiparea electrica.
Eu nu tintesc variantele mari, ci cea de 2.5m, care Neil refuza sa explice de ce nu mai aduce la HF. Ca sa fie sub un kg, pentru cine intreaba :p
Aceasta postare a fost editata de renatoa: 27 February 2014 - 11:30 AM
#255 Useril este offline   MADA
  • Postari: 987
Postat 27 February 2014 - 11:55 AM
Corect, e mai scump in GBP dar la HF au mai mereu modele pe stoc. Eu am incercat anul trecut sa cumpar un Ava de la dealeri din Germania si Franta dar nicaieri nu aveau nimic pe stoc si dura cam 2 luni sa aduca la comanda.
Sper ca Vladimir nu va inchide (tocmai a scos si la Maxa gama Pro) desi nimic nu e sigur mai ales in contextul actual...exemplul Iugoslaviei exista, din pacate.
Dar ca motivatie e ok pentru o comanda :D
#256 Useril este offline   F2B
  • Postari: 921
Postat 06 March 2014 - 06:29 PM
Pentru incepatori care vor sa intre in planorism cu buget mic.
http://shop.flitetes...peed-build-kit/
Si aceiasi tehnica se poate aplica sa faci si cu eleroane. Binenteles multe se pot adauga sau pot fi inlocuite ca de exemplu o tija de carbon pentru lonjeron etc.
Aceasta postare a fost editata de F2B: 06 March 2014 - 06:32 PM
#257 Useril este offline   F2B
  • Postari: 921
Postat 06 March 2014 - 06:43 PM
Si ceva pentru zburat la panta. Binenteles minus motor si poti adauga baterii si electronice in bot.
#258 Useril este offline   renatoa
Postat 26 March 2014 - 01:51 PM
A luat cineva noile servo-uri DS245 de la HK, KST rebranduite, si are unul de imprumut pana imi ajunge al meu ?
Sau alt servo pun de pus in coada, adica metal sau karbonit, subtire 9mm, usor 11 grame, si 1.5-2kg. Stiu ca nu sunt multe sa satisfaca asemenea conditii, tocmai de asta DS245 sunt teribile, doar ca vin parca pe jos de acolo...
#259 Useril este offline   renatoa
Postat 27 March 2014 - 03:14 PM
Azi mi-a venit boom-ul cel nou si pot sa zic ca avem un castigator !
De fapt mai multi, orice modelist roman care va avea de acum incolo nevoie poate sa stie ca se pot face in tara, la un pret absolut rezonabil, sub al celor aduse din afara, si calitate - asa cum o percep eu - mai buna, cel putin la proba testarii manuale.
Ca parametrii: 800mm lungime, 23mm interior la capatul gros, 13.7mm exterior la capatul subtire, grosime perete aprox 0.5mm, 39 grame. 4 straturi: sticla, kevlar si carbon. Se poate face mai gros, pana la 30mm la un metru lungime, dar nu mai subtire, atat are calapodul.
Nu are rigiditatea celui de undita, dar si greutatea este la jumatate.
Oricum, cele de undita nu au conicitatea necesara unul boom de planor de tip Ava/Pulsar.
Il puteti vedea partial in imaginile atasate, boom-ul se termina exact in interiorul monturii profundorului, si continua cu o teava cilindrica de 11x12, care va fi suportul directiei.
Profundorul este copie Ava, work in progress.
#260 Useril este offline   renatoa
Postat 06 April 2014 - 07:32 PM
Ce sa mai comentez... ca iar ma fac unii misogin :)
E de dupa amiaza asta, pe alte meleaguri, unde suta de euro pe an cotizatia nu se simte la ce rup unii.
#261 Useril este offline   stiganas
  • Postari: 8326
Postat 18 April 2014 - 01:55 PM
A reaparut la 220 EUR cu transport moca:
MSS Freedom Glider 2590 mm ARTF mit BL-Motor, Turbospinner und Klappluftschraube
http://www.der-schwe...m_campaign=1415
Vine cu partile esetiale: motorul si conul cu pale (daca e sa le cumperi iti ies peri albi pana le potrivesti) restul de dotare e banal.
Asadar la 1000 lei un planor adevarat. Eu l-am vazut la RR si la Brasov dar nu am vazut ce poate ca planor.
Ca marime e ideal pentru transport. Profundorul e pendular se scoate cu totul si contactele la servo se pot pune pe mufa MPX. Il duci in rucsac si il montezi in 30s.
#262 Useril este offline   stiganas
  • Postari: 8326
Postat 18 April 2014 - 01:59 PM
Bai frate unde i-ai gasit pe astia ? ca au doar 23 vizualizari. Par prosti gramada la pilotat.
De fapt nici nu inteleg cum au reusit sa-l buseasca. Sau poate au ramas fara comenzi.
Vezi postarearenatoa, la 06 April 2014 - 07:32 PM, a spus:
Aceasta postare a fost editata de stiganas: 18 April 2014 - 02:02 PM
#263 Useril este offline   renatoa
Postat 18 April 2014 - 02:29 PM
Pai unul din cei 28, din clubul lor, este pe rhc :)
#264 Useril este offline   renatoa
Postat 19 April 2014 - 10:09 AM
Steve Neu ne pune la curent cu modificarile aduse regulamentelui FAI la clasele F5.
http://www.rcgroups....d.php?t=2149313
Aceasta postare a fost editata de renatoa: 19 April 2014 - 10:09 AM
#265 Useril este offline   renatoa
Postat 25 April 2014 - 03:57 PM
Fericiti cei care pot cumpara la fata locului... cred ca e primul BD la vanzare ARF care il vad, sunt curios la cat ajunge... sufar... rau de tot :)
http://www.ebay.co.u...r-/251511178706
#266 Useril este offline   stiganas
  • Postari: 8326
Postat 01 May 2014 - 01:13 PM
S-a vandut la 160 GBP, adica vreo 880 lei. Eu as fi dat banii astia daca era de vanzare in RO.
Vezi postarearenatoa, la 25 April 2014 - 03:57 PM, a spus:
#267 Useril este offline   renatoa
Postat 01 May 2014 - 08:03 PM
Sa socotim... kit-ul de aripa 43$, cu adusul cam 75$... fuselaj si boom 90$, de la CLM-Pro, ramane electronica la 85$ si manopera zero... pomana :(
#268 Useril este offline   SORIN CAIUS
  • Postari: 2103
  • Inregistrat: 02-November 05
Postat 01 May 2014 - 08:22 PM
Renatoa,
am fost convins ca l-ai cumparat tu.De aia nu am licitat.
Dar la 250 $ sau 160 de lire e o diferenta de vreo 60 de Roni, adica atata ar fi manopera dar ca sa-l faci timpul alocat costa mai mult de 60 Roni asculta-ma.
Ciao Sorin
#269 Useril este offline   renatoa
Postat 01 May 2014 - 08:53 PM
Puteam sa il iau, dar mai greu cu adusul acasa.
250$ i-am calculat la repezeala, nu stiu cursul usd/gbp pe de rost.
Iar manopera 60 lei e o gluma, nu ti-l face nimeni la atat, si chiar si timpul personal valoreaza mai mult, dar cand il faci tu pentru tine are aplicam alta scala de valori.
#270 Useril este offline   SORIN CAIUS
  • Postari: 2103
Postat 01 May 2014 - 08:58 PM
Pai da cam asa timpul personal alocat constructiei valoreaza mult mai mult.
Ciao Sorin
  • 74 Pagini +
20 useri citesc topicul
