Modelism - RHC Forum: Blade 130X - Modelism - RHC Forum
  • 13 Pagini +
Blade 130X Hello Blade, by by Walkera
#181 Useril este offline   XanderX
  • Grup: Guests
  • Postari: 110
  • Inregistrat: 05-June 11
Postat 12 August 2013 - 08:33 PM
"Note that 130X mainboard uses PPM signal (servo signal) not PWM signal (brushed motor) so there are a few differences, mainly BLHeli needs to know the endpoints of the signal. You can set it from TX by entering TX program mode. This gets tricky with the 130X mainboard. You need to set normal mode throttle curve to run from 0% to 100% (don't care what midpoint values are). If you have the version 7 and up BLHeli with auto-arm feature, on flight battery plug-in listen to the 3 beeps signifying initialization and then 2 beeps signifying auto-arm and you have to throw throttle stick from zero to non-zero right between the 2 beeps to trigger TX program mode. This is assuming 130X mainboard initializes properly with solid blue light. Retry if you get blinking blue light on 130X mainboard. With throttle stick at non-zero position, wait a good few seconds to signify TX program mode. At this point, follow the TX programming manual to set throttle low and high endpoints for the ESC before you can proceed to changing parameters"
unde naiba aud astia 2 beepuri dupa cele 3 ....sunt 3 beep uri la initializare si dupa aia inca 3,
#182 Useril este offline   Primus
  • Postari: 3026
  • Inregistrat: 14-June 07
Postat 13 August 2013 - 09:35 AM
Xander, daca te pot ajuta cu ceva cand te hotarasti sa cumperi alta placa, eu o pot avea la 58 eur livrata. Mai ramane transportul pana la tine.
Pe posta ar trebuie sa fie cativa euroi.
Bafta cu reparatia.
#183 Useril este offline   Primus
  • Postari: 3026
Postat 13 August 2013 - 03:37 PM
A aparut si postasul meu azi, eu il asteptam pentru weekend.
Am facut repede programul, sper sa nu fi uitat ceva. La prima proba totul pare in regula.
Intrebare pentru posesori, motorul se incinge tare, are ceva oare daca lipo atinge ?
Ies sa dau cateva packuri cat dorm copiii :-)
http://img14.imageshack.us/img14/4250/cnwc.jpg
#184 Useril este offline   Primus
  • Postari: 3026
Postat 13 August 2013 - 04:39 PM
Si l-am testat. Am dat repede un pack in garaj si trei afara.
http://imageshack.us/a/img850/8145/bee5.jpg
http://imageshack.us/a/img27/6336/h667.jpg
Impresii:
E altceva fata de MCPX BL. Zboara exact, foarte ascultator. Coada e din alta poveste, ma incanta.
Flip, rol strans si nu larg ca la MPCX. In spatiul destul de mic am dat cateva flipuri, roll si ceva ture inverted.
Abia astept sa ii rezerv niste timp.
Semn de intrebare:
Am ceva care ma linisteste insa.
Incepand cu al doilea pack, aud un carait, parca ar fi un gearing incorect, sau ceva care freaca, sau un rulment stricat, in flight mode normal se mai intrerupe, in Idle up e continuu, si e chiar suparator, se aude mai tare decat motorul. Am aruncat o privire peste gears, pare totul ok, sa dau cu ceva unsoare pe ele?
Torque tube are doar o jumatate de mm joc pe axa lui.
Nici un joc in head, nimic nu pare sa atinga partile in miscare.
Idei inainte de a ma apuca sa desfac ceva, sau ii dau inainte :-) ?
#185 Useril este offline   Primus
  • Postari: 3026
Postat 13 August 2013 - 05:05 PM
Am gasit pe youtube un filmulet cu unul care face la fel.
Cica ar freca tubul pe interiorul cozii, sunt destule care fac asa.
A mai intampinat cineva aceeasi problema? Ii dau cu ulei pe interior sau il trimit la schimb?
Aceasta postare a fost editata de Primus: 13 August 2013 - 05:07 PM
#186 Useril este offline   Primus
  • Postari: 3026
Postat 13 August 2013 - 05:19 PM
Nu stiu cum sa pun embed video, poate ma ajuta Stefan, da' asta e linkul
http://www.youtube.c...d&v=v4gLMnplWzc
Aceasta postare a fost editata de stiganas: 13 August 2013 - 05:33 PM
#187 Useril este offline   stiganas
  • Postari: 8331
Postat 13 August 2013 - 05:36 PM
Face urat. Cate am vazut eu nu fac asa. Vibreaza putin la turatie mica dupa care nu se mai aude nimic. Daca freaca asa o sa rontaie tubul (patratul) pe interior si o sa faca rulmentii praf.
Aceasta postare a fost editata de stiganas: 13 August 2013 - 05:36 PM
#188 Useril este offline   Primus
  • Postari: 3026
Postat 13 August 2013 - 05:48 PM
Am trimis un mail la magazin, e tarziu sa mai sun acum. http://www.rhcforum.ro/public/style_emoticons/default/huh.gif
Bine ca am pastrat ambalajul.
PS: OFF zi cum ai facut cu link-ul ala; l-am copiat direct si n-a mers
Aceasta postare a fost editata de Primus: 13 August 2013 - 05:51 PM
#189 Useril este offline   stiganas
  • Postari: 8331
Postat 13 August 2013 - 06:44 PM
Clipul trebuie sa fie in formatul scurt:
www.youtube.com/watch?v=a3K-gQtKGOY
cand il bagi cu Insert Media; asta e tot.
Vezi postareaPrimus, la 13 August 2013 - 05:48 PM, a spus:
#190 Useril este offline   Ice9
  • Postari: 1361
  • Inregistrat: 06-April 10
  • Interests:RC Helicopters
Postat 13 August 2013 - 08:11 PM
Seria "ora de nesimtire" continua. Nu m-am lasat convins de primul raspuns din Germania, si am insitat:
"Hello again,
Thanks for the answer, but I believe that you've didn't read quite through the whole email. I've stated that he tried even on an original Spektrum DX6i transmiter, programmed already for another 130X, with the same results. Heli stops his motor at quarter throtle stick.
Thanks again,
Alex"
...si ce au raspuns:
"Hello Alex,
we don´t have any manuals to reset the programming of the 130X.
Please contact your local dealer for support? Maybe you can bind it with another radio to check this issue.
mit freundlichen Grüßen / best regards
Horizon Hobby GmbH
Thomas Bundt
Technischer Service"
Si mai tare...eh? :clapping:
#191 Useril este offline   XanderX
  • Grup: Guests
  • Postari: 110
Postat 13 August 2013 - 09:32 PM
:))Alex ms mult de suport, e timpul sa lasam cretinii in pace, ca ne dau robotic tot
am mai sapat si am reusit asta:
cand pui bateria face 3 beep-uri ce trebuie sa faci este sa ridici throttle pana la mijloc +-5% max, chiar imediat dupa primul beep
intre 45% si 55% altfel nu se initializeaza meniul esc. se aude un cantecel altfel decat la initializarea cu statia.
cursa throttle are trei pozitii in care esc iti da raspuns de fiecare data cu alta melodioara 100% 50% 0%, dupa care iese din programare
In rest nimic si dupa vreo 2 ore de miscat stikurile in toate pozitile posibile si imposibile chiar, nu am gasit vreo alta setare....... iar simptomele sunt la fel motorul moare dupa 1 sec.
Ms Primus, intr-adevar este cel mai mic pret la 3 in 1 , dar prefer sa o iau din tara ca sa am o garantie si o inlocuire rapida daca vor mai fi probleme.
Aceasta postare a fost editata de XanderX: 13 August 2013 - 09:33 PM
#192 Useril este offline   DanB
  • Postari: 1551
  • Inregistrat: 22-July 11
Postat 13 August 2013 - 10:56 PM
Da' cum exact s-a intimplat cind a luat-o razna? Mie imi suna ca intra in protectie/avarie esc-ul.
USER BANNED BY ADMIN
#193 Useril este offline   Primus
  • Postari: 3026
Postat 14 August 2013 - 10:46 AM
N-ai de ce, sper sa poti avea placa cea noua cat mai curand.
Revin la zgomotul de "rasnita" de la al meu. Dupa un schimb de mailuri cu magazinul online, inainte de a-l returna la ei, m-au rugat sa incerc sa refac gearing-ul si sa pun un pic de vaselina siliconica pe torque tube. Mi-a luat 10 minute cu totul aseara.
Am dat de dimineata un hover in IU2 in garaj, pare ca s-a dus http://www.rhcforum.ro/public/style_emoticons/default/rolleyes.gif
Dupa masa fac un test complet afara sa vad daca am scapat asa de usor. http://www.rhcforum.ro/public/style_emoticons/default/pardon.gif
#194 Useril este offline   Primus
  • Postari: 3026
Postat 14 August 2013 - 05:09 PM
Ma intorc de afara cu vesti bune.
Un pic de vaselina siliconica pe torque si o remontare cu atentie a pinioanelor din coada, a facut minuni.
Am dat vreo 6 packuri in dupa masa asta si merge ca "uns". http://www.rhcforum.ro/public/style_emoticons/default/rolleyes.gif
M-am uitat pe HK la packurile alea de 450. As fi preferat unele cu conectori "clasici" de echilibrare separati sa nu bricolez.
Astia de 300Mah dau 4 minute bune, dar se inmoaie imediat dupa.
O poza inaite de testul de azi.
http://img818.imageshack.us/img818/1272/vr3g.jpg
Aceasta postare a fost editata de Primus: 14 August 2013 - 05:10 PM
#195 Useril este offline   XanderX
  • Grup: Guests
  • Postari: 110
Postat 14 August 2013 - 08:15 PM
[quote name='Primus' timestamp='1376492962' post='675471']
BRAVO Primus, intradevar incredibil vaselina siliconica pe torq , incredibil, poolup ca si pe trex 450 , fara nici o vibratie sesizabila,inainte facea urat la o anumita turatie si un sunet ciudat , acuma lin de tot MS
#196 Useril este offline   XanderX
  • Grup: Guests
  • Postari: 110
Postat 14 August 2013 - 08:33 PM
Vezi postareaDanB, la 13 August 2013 - 10:56 PM, a spus:
nu am nici cea mai vaga idee, pe birou era heli fara pale , multiple teste pe telecomanda de cacao turnigy, setari de noob, o poveste lunga si trista :),
cu alte cuvinte pe canalul 6 se pune pitch, se pune doar throttle-ul, iar eu puneam toate trei ail ele thr crezand ca asa trebuie , dupa care incercam sa mixez pe canalul 2 si 3 iara toate ca sa compensez erorile de pe canalul 6, da stiu suna incredibil de cretin, dar pe 450 merge , ca zboara infect da, acuma stiu am sa setez si 450 asa ca la carte, pffff nu am cuvinte , tot ce am invatat la setari a fost pe pielea mea si pe buzunarul meu.
Mai tin minte nu demult ies mandru pe camp cu 450 cu setarile aferente :) pe telecomanda , si rog pe Seba NEN77 sa faca reglajele fine , si poc heli pica in coada, saracu Seba sa simtit vinovat, dar problema era cu starile mele cretine :) toate mixurile mele pretioase nu s-au inteles cu ale lui Seba:))
Am sa fac un filmulet inainte sa le sterg pt cine vrea sa zboare heli extrem de instabil 8)
#197 Useril este offline   Primus
  • Postari: 3026
Postat 28 August 2013 - 08:21 PM
Si azi a zburat iar 130X.
Fantastic, am dat 5 packuri la sfarsitul zile. Zburat inverted si backwards in toate directiile, foarte bun de exersat, chiar pe un vantisor in rafale.
A luat trei crashuri, e teapan micutul nici un damage. Secretul e sa-l zbori peste iarba un pic mai inalta, care te fereste de socuri dure.
Tre' sa mai iau niste packuri, dupa 5 abia ma incalzesc, si sunt lenes sa mai reincarc, in ultima vreme nu mai car chargerul dupa mine.
Cele doua heli Blade de azi sunt accesorii de masina, stau in portbagaj tot timpul, de cate ori am un ragaz ma presc si dau un zbor http://www.rhcforum.ro/public/style_emoticons/default/biggrin.gif.
#198 Useril este offline   Primus
  • Postari: 3026
Postat 16 September 2013 - 07:05 PM
Nu mai zboara nimeni 130X ? http://www.rhcforum.ro/public/style_emoticons/default/cool.gif
Al meu a iesit un pic la soare azi, pe drum spre casa am dat 6 pacuri repede.
A luat o data contact cu iarba zdravan si totusi fara daune.
Cred ca e al saselea crash pe iarba daca nu ma insel, fara sa aiba ceva. Il gasesc mai rezistent ca MCPX-ul pe care l-a si depasit la numar de zboruri.
Fiindca s-a comportat exemplar, a primit niste packuri noi noute:
http://img849.imageshack.us/img849/8453/uz4t.jpg
#199 Useril este offline   mihado_logo
  • mihado_logo
  • Postari: 1439
  • Inregistrat: 07-July 11
  • Interests:hely
Postat 16 September 2013 - 08:56 PM
mai zbor si eu .dar inca nu a venit comanda cu pakurile din Olanda .Momentan am doar unul- pe cel original .
Primus ,as vrea sa te intreb de ce in timpul unui circuit de ex,..are momente cand se "scutura" cu toate ca sunt in idle up ,iar curba de throtel este 100-100-100..?!
Aceasta postare a fost editata de florin_953: 16 September 2013 - 08:56 PM
#200 Useril este offline   Primus
  • Postari: 3026
Postat 17 September 2013 - 01:30 AM
Ale mele au venit din HK , comanda plasata pe 4, primita azi.
Cand spui ca se scutura, trepideaza frame-ul sau ai doar wag pe coada?
In caz de tremurici de frame arunca-ti o privire pe pinioane sa nu fie deja vreun dinte dus, sau palele sa nu fie prea stranse.
Al meu dupa atatea trante, vad ca nu are nici un frison http://www.rhcforum.ro/public/style_emoticons/default/rolleyes.gif
Spor la zbor !
#201 Useril este offline   mihado_logo
  • mihado_logo
  • Postari: 1439
  • Interests:hely
Postat 17 September 2013 - 03:42 PM
trepideaza frame-ul ,tot elicopterul !! Pinioanele sunt intregi..Da este si un wag pe coada !
Aceasta postare a fost editata de florin_953: 17 September 2013 - 03:44 PM
#202 Useril este offline   Primus
  • Postari: 3026
Postat 17 September 2013 - 04:04 PM
In acest caz poti verifica ca nu cumva Gear A (cea care este pe main shaft) sa nu calce deasupra gear-ului B.
E destul de intalnit fenomenul, cand boom-ul este impins la maxim in frame, acesta forteaza in gear B si il impinge prea mult "sub" gear A. Acest lucru poate genera vibratii urate.
Al meu a mai luat o tranta zdravana azi, din low inverted in IU2 dar am fost rapid cu TH. Fara daune http://www.rhcforum.ro/public/style_emoticons/default/pardon.gif
La pranz am incercat noile packuri, se simt la turatie, e mai nervos, iar la patru minute nu e bleg cand il aduci jos.
Aceasta postare a fost editata de Primus: 17 September 2013 - 04:09 PM
#203 Useril este offline   mihado_logo
  • mihado_logo
  • Postari: 1439
  • Interests:hely
Postat 17 September 2013 - 07:00 PM
Am discutat intre timp si cu Stefan ,care mi-a sugerat sa schimb inelele de cauciuc de pe gripurile principale ,cu altele mai groase. Mai exact cu acelea care se monteaza pe canopy .
Am facut acest lucru si cu toate ca modelul nu mai este asa de responsiv pe pitch !(swashplate-ul urca mai greu deoarece este frecarea mai mare) ,am scapat de vibratii si alte miscari anormale !
Dar inexplicabil si fara sa-l cresuiesc ,dupa doua pakuri sau barbirit dinti la tail gear. Pur si simplu scapa. si nu mai angreneaza torq-ul
Am scapat de una si am dat de alta .. !
Voi face primul upgrade - voi cumpara piesa compromisa din metal.
Aceasta postare a fost editata de florin_953: 17 September 2013 - 07:02 PM
#204 Useril este offline   ave
  • Postari: 1010
  • Inregistrat: 13-December 07
Postat 22 September 2013 - 11:36 PM
Hop și io... Ieri l-am dat pe sus pe un vânticel destul de... țapăn. Vreo 4 crashuri a rezistat, la la 4-lea s-au bărbierit și la mine dinții de pe main tail gear, cum păți și Florin săptămâna trecută. În plus la mine s-a dus și aripioara de pe coadă. :(
Transportul de la horizonhobby US în .ro e dement de scump, încercăm și la UK poate avem mai mult noroc...Mda, noroc pe dracu', trebuie să văd de cine mă lipesc să-mi facă o comandă când se duce în State.
Aceasta postare a fost editata de ave: 22 September 2013 - 11:39 PM
Ave
#205 Useril este offline   stiganas
  • Postari: 8331
Postat 23 September 2013 - 06:38 AM
Nu numai ca e scump dar nu trimit in RO.
Transport ieftin (moca) in ro au amainhobby. Altfel fast-lad.uk, midland helicopters.uk si heliguy uk.
#206 Useril este offline   ave
  • Postari: 1010
Postat 23 September 2013 - 07:10 AM
Dafuq m8... 59 de CENȚI shipping-ul către .ro?!?!? Săru'mâna!!!
Ave
#207 Useril este offline   takeoff
  • Postari: 1029
  • Inregistrat: 25-July 08
Postat 23 September 2013 - 09:32 AM
Cred ca vei gasi piese si la noi in tara.Ai cautat?
#208 Useril este offline   mihado_logo
  • mihado_logo
  • Postari: 1439
  • Interests:hely
Postat 23 September 2013 - 10:47 AM
intra pe GLIDERS DISTRIBUTION ,in Anglia. Au piesa separat (nu la set )!!!!
Costa 2 lire ,iar transportul.. mai putin .
Eu cu 36 de ron am cumparat doua ,cu tot cu transport
Aceasta postare a fost editata de florin_953: 23 September 2013 - 10:48 AM
#209 Useril este offline   ave
  • Postari: 1010
Postat 23 September 2013 - 03:17 PM
Am luat mai multe (mi-am luat și set full de pinioane, și set pinioane de coadă, și bevel gear metalic, și tail fin). Să vedem când ajung.
Apropo, a văzut cineva tot angrenajul anterior din metal? Că eu n-am găsit decât bevel-ul plus perechea de pinioane de pe coadă...
Ave
#210 Useril este offline   mihado_logo
  • mihado_logo
  • Postari: 1439
  • Interests:hely
Postat 23 September 2013 - 04:55 PM
daca ai facut comanda pe saitul mentionat ,o sa-ti ajunga in 4 zile in plic - paravion. ,Iar piesa din metal o gasesti peste tot ,si pe ebay ,si in tara pe undeva prin Ploiesti !! Pentru mai multe detali 0762140811..asta ca sa nu fiu nevoit sa le fac reclama
Aceasta postare a fost editata de florin_953: 23 September 2013 - 04:57 PM
  • 13 Pagini +
44 useri citesc topicul
0 membri, 44 vizitatori, 0 utilizatori anonimi
