Vand Piper Cub 1200 mm
Postat 03 March 2012 - 12:39 AM
- Anvergura - 1200 mm
- Lungime - 735 mm
- S. portanta - 22,3 dmp
- Greutate - aprox 800 gr
Pretul include:
- Motor OS Max 15LA - 2,5cc (NOU...nepornit)
- Toba Esapament (NOUA)
- Elice APC Sport 8x6
- Rezervor combustibil
- BEC extern
- Servo-uri 9 gr
Pret Fix: 500 RON
Il vand pt. ca vreau sa demarez alt proiect.
Tel: 0745/049.052 Imagine075.jpg (265.74K)
Magister-MULTIPLEX - 1630mm
Ryan NY-P - 1600mm
Piper Cub J3- 2310 mm - 28cc benzina
Diamond 1800mm
P40-Warhawk mini (645mm)
W-Fly-Flaspeed 2,4 GHz
Postat 19 March 2012 - 01:58 AM
Ryan NY-P - 1600mm
Diamond 1800mm
Postat 30 March 2012 - 05:21 PM
Number of downloads: 219 -
Ryan NY-P - 1600mm
Diamond 1800mm
Postat 30 March 2012 - 05:27 PM
Number of downloads: 187 -
Ryan NY-P - 1600mm
Diamond 1800mm
Postat 28 April 2012 - 03:21 AM
Ryan NY-P - 1600mm
Diamond 1800mm
Postat 28 April 2012 - 10:15 PM
0746/322.021 este nr. actual...Multumesc pt. intelegere!
Ryan NY-P - 1600mm
Diamond 1800mm
Postat 05 June 2012 - 04:41 AM
Ryan NY-P - 1600mm
Diamond 1800mm
Postat 08 July 2012 - 01:30 PM
Ryan NY-P - 1600mm
Diamond 1800mm
Postat 26 August 2012 - 03:39 PM
Number of downloads: 207 -
Number of downloads: 200 -
Number of downloads: 234 -
Ryan NY-P - 1600mm
Diamond 1800mm
Postat 26 August 2012 - 03:43 PM
Aripa a iesit perfect...si este aliniata la milimetru fata de fuselaj.
Nu am apucat sa-l zbor, dar tare cred ca o s-o fac daca nu se vinde... :drinks:
Ryan NY-P - 1600mm
Diamond 1800mm
#11
Postat 01 September 2012 - 12:44 AM
Ryan NY-P - 1600mm
Diamond 1800mm
#12
Postat 07 September 2012 - 02:39 PM
Ryan NY-P - 1600mm
Diamond 1800mm
#13
Postat 16 September 2012 - 11:24 PM
Ryan NY-P - 1600mm
Diamond 1800mm
#14
Postat 24 September 2012 - 03:09 AM
Ryan NY-P - 1600mm
Diamond 1800mm
#16
Postat 28 September 2012 - 03:24 AM
Dar intre timp a capatat hobane pt. aripi...Hobanele se pliaza pe dosul aripii, pe timpul transportului, pt. a evita demontarea lor. Imagine064.jpg (168.09K)
Number of downloads: 120 Imagine068.jpg (182.61K)
...Daca mai lucrez mult la el, o sa-i creasca pretul... ;)
Ryan NY-P - 1600mm
Diamond 1800mm
#17
Postat 22 October 2012 - 06:19 PM
Ryan NY-P - 1600mm
Diamond 1800mm
#18
Postat 26 October 2012 - 05:45 PM
Ryan NY-P - 1600mm
Diamond 1800mm
#19
Postat 02 November 2012 - 03:23 PM
DJI Mini 4 PRO
Hornet Tunel Hull Sprint F1
Fly Low. Go Fast. Turn Left.
Do. Or do not. There is no try.
#20
Postat 03 November 2012 - 10:34 PM
Tealk, la 02 November 2012 - 03:23 PM, a spus:
Pretul nu este negociabil...Este 500 RON...Motorul este OS-Max nou-nepornit...Nu miroase a metanol...Numai motorul nou costa pe Sierra aprox. 530 RON...Daca mai punem la socoteala si servouri...U-BEC...elice...bujie...+alte maruntisuri de care e nevoie ca sa zbori un model, sare cu mult fatza de cat am cerut eu...De aceea nu vreau sa mai cobor pretul...
Ryan NY-P - 1600mm
Diamond 1800mm
#21
Postat 03 November 2012 - 10:37 PM
Ryan NY-P - 1600mm
Diamond 1800mm
#22
Postat 19 November 2012 - 05:49 PM
Number of downloads: 49 -
Ryan NY-P - 1600mm
Diamond 1800mm
#24
Postat 19 November 2012 - 09:16 PM
...Piper-ul meu inca nu a fost zburat, pt. ca am tot mesterit la el...Am vrut sa-l fac sa arate cum trebuie...
...Sant toate sansele sa zboare la fel de bine ca acela din filmare, pt. ca este perfect centrat!!!...Nu exista diferentza de 1 mm intre varfurile aripilor si coada...Nu are abateri de paralelism intre aripa si profundor...si s-a echilibrat perfect cu motorul de 2,5cc...Eleroanele sant suficient de mari pt. a avea control suficient...Iar aripile au un pic de diedru (0,5...1 grd) exact cum trebuie...
...Cred ca va fi interesant de zburat, mai ales ca este destul de bine motorizat...La aprox. 800 gr. are un motor care da cam 1.100...1.200 gr. tractiune... Totul pe o sarcina alara (37,9 gr/dmp) rezonabila pt. dimensiunea asta de aeromodel...:good:
...Un plus in favoarea Piper-ului meu...Motorizarea termica, cu un motor OS Max " Made in Japan" nou nout (nepornit...nerodat...). :good:
Ryan NY-P - 1600mm
Diamond 1800mm
#25
Postat 19 November 2012 - 11:00 PM
dan1972, la 19 November 2012 - 09:16 PM, a spus:
pai ada-l sa- facem maidanul ca poate creste cota .. :good:
#26
Postat 19 November 2012 - 11:11 PM
Intentionez sa il vand si n-as vrea sa-i fac semne pe el...mai ales ca nu am zburat termice pana acum :pardon: ...Cine vrea sa cumpere, il vrea intact...
In plus motorul este nou/nepornit/nerodat...Faptul ca nu miroase a metanol, este garantia ca nu a fost folosit cine stie cum...si ca este nou noutz... :good:
Daca nu se va vinde in timpul cel mai scurt, probabil ca n-o sa ma pot abtine si o sa-l zbor eu...Cred ca e numai bun pt. debutul in zborul termic...
Multumesc inca o data!!!
Ryan NY-P - 1600mm
Diamond 1800mm
#27
Postat 06 December 2012 - 09:11 PM
Ryan NY-P - 1600mm
Diamond 1800mm
