Modelism - RHC Forum: Elice Ivoprop 100 HP MEDIUM - Modelism - RHC Forum
#1 Useril este offline   vic
  • Postari: 1470
  • Inregistrat: 28-May 02
Postat 14 February 2012 - 02:48 PM
Se vinde Elice Ivoprop 100 HP MEDIUM + GUVERNOR. NOUA, NEFOLOSITA,!!! Pentru motor ROTAX 912 S 100 HP!!! De asemenea contine tot kitul de montaj si in varianta cu comanda pasului variabil manual si automat din cabina! Contine si adaptoare pentru folosirea in varianta doua pale.
The In-Flight Adjustable Pitch Ivoprop allows the pilot to change the propeller pitch in flight through a toggle switch mounted in the cockpit. Pressing the toggle switch one way sends an electric current through the graphite brushes to the slip rings and finally to an electric motor. Torque from the electric motor is channeled to a planetary gear drive which turns the lead screw. Torsional rods transmit movement from the center of the prop to the outside section of the blades, causing the blade to twist therefore changing pitch. Total time for the full range of adjustment is about 5 seconds. Mounts directly to any Rotax gear box (B or C0 and can be adapted to VW, Subaru, Hirth, Arrow and smaller Lycoming and Continental engines. Older model Ivoprop ground adjustable props can be converted to the In Flight System with the Retrofit Kit. In Flight adjustable hub comes assembled with complete instructions. Weight of 3 blade 72" In Flight Adjustable Prop including all required parts (furnished) is 9 lbs. Specify aircraft and engine make and model, and propeller diameter (48" to 76").
Medium Ivoprop is for engines around 100HP (52"-74" prop dia.).
Pret: 1700 EURO!
CONTACT: vic 0744558028
  • Imagine atasata: DSC03077 (Custom).JPG
  • Imagine atasata: DSC03076 (Custom).JPG
#2 Useril este offline   vic
  • Postari: 1470
Postat 31 March 2012 - 08:22 PM
up
#3 Useril este offline   vic
  • Postari: 1470
Postat 21 August 2012 - 04:16 PM
1500 euro
#4 Useril este offline   vic
  • Postari: 1470
Postat 22 October 2012 - 07:53 PM
up
#5 Useril este offline   vic
  • Postari: 1470
Postat 09 November 2012 - 07:50 PM
Pret NOU 1300 Euro.
#6 Useril este offline   vic
  • Postari: 1470
Postat 04 December 2012 - 07:20 PM
up
#7 Useril este offline   vic
  • Postari: 1470
Postat 06 January 2013 - 07:13 PM
up
5 useri citesc topicul
