Modelism - RHC Forum: Motorizare carp renge - Modelism - RHC Forum
#1 Useril este offline   cricri_pescar68
  • Postari: 401
  • Inregistrat: 16-November 09
Postat 03 December 2011 - 09:29 AM
ce motor pot pune pe o coca carp renge de la nid1975?
#2 Useril este offline   cricri_pescar68
  • Postari: 401
Postat 21 February 2012 - 06:55 PM
carp renge2
#3 Useril este offline   sorin6969
  • Postari: 91
  • Inregistrat: 26-January 11
Postat 21 February 2012 - 07:05 PM
daca nu vrei viteza poti pune un 755/40
#4 Useril este offline   sorin6969
  • Postari: 91
Postat 21 February 2012 - 07:08 PM
#5 Useril este offline   Roko1
  • Postari: 172
  • Inregistrat: 26-October 11
  • Interests:pescuit,offroad
Postat 21 February 2012 - 09:34 PM
Vezi postareasorin6969, la 21 February 2012 - 07:08 PM, a spus:
ce elice ai montat...???
#6 Useril este offline   DINODINO
  • Postari: 57
  • Inregistrat: 16-October 11
Postat 21 February 2012 - 09:56 PM
Salut .
Pe barcazul ala sint doua motoare ,racire daca nu ma insel si elicii de 60 dinamic dupa puterea exercitata .
Aceasta postare a fost editata de DINODINO: 21 February 2012 - 09:59 PM
#7 Useril este offline   cricri_pescar68
  • Postari: 401
Postat 23 February 2012 - 04:08 PM
Salut am montat un motor de aeroterma de dacie si o elice de 60 dinamic dreapta
#8 Useril este offline   cricri_pescar68
  • Postari: 401
Postat 23 February 2012 - 06:17 PM
motor
#9 Useril este offline   Roko1
  • Postari: 172
Postat 23 February 2012 - 06:46 PM
Vezi postareacricri_pescar68, la 23 February 2012 - 06:17 PM, a spus:
motor
intaradevar cuplu adevarat ...pacat ca nu se mai gasesc motoare de aeroterma
#10 Useril este offline   cricri_pescar68
  • Postari: 401
Postat 24 February 2012 - 06:08 PM
da asa este se gasesc foarte greu
#11 Useril este offline   cricri_pescar68
  • Postari: 401
Postat 24 February 2012 - 06:17 PM
carma este de 90\40
#12 Useril este offline   Adistul
  • Postari: 1490
Postat 27 February 2012 - 01:22 AM
Vezi postareacricri_pescar68, la 24 February 2012 - 06:17 PM, a spus:
carma este de 90\40
Nu se vede foarte bine in poza... dar carma cred ca trebuia pusa putin mai jos... cu aprox 1 cm.
De regula "se centreaza" fata de elice.
Poza e neclara...
Decat o poza proasta... mai bine lipsa.
Aceasta postare a fost editata de Adistul: 27 February 2012 - 01:23 AM
La fel e si cand esti prost.
tel: 0771 088 207
adistul@yahoo.com
#13 Useril este offline   DINODINO
  • Postari: 57
Postat 27 February 2012 - 06:13 PM
Vezi postareacricri_pescar68, la 23 February 2012 - 04:08 PM, a spus:
Salut
Filmul de care se vorbea are urmatoarea prezentare :
Încărcat de razvanpower în data de 24.10.2010
This is a test with my boat with 2 755/40 electric engine's and 14 ni-mh cells of 3300 mah, that was pulling me on 2 person air matress
Aceasta postare a fost editata de DINODINO: 27 February 2012 - 06:13 PM
#14 Useril este offline   nid1975
  • Postari: 403
  • Inregistrat: 13-August 11
  • Interests:navomodelism,pescuit
Postat 27 February 2012 - 11:23 PM
mi-a spus cineva a masurat motorul de aeroterma dacia si ca are 2800rot/min in sensul invers acelor de ceasornic si 3600 in sensul acelor de ceasornic
ar fi o diferenta de 800 rot deci implicit o viteza mai mare
in cazul asta ar trebui o elice pe stanga
mai stie cineva de chestia asta ca mi se pare ciudat,este oare posibil?:wacko:
motor
Tel 0728777780
#15 Useril este offline   Adistul
  • Postari: 1490
Postat 28 February 2012 - 03:04 AM
Vezi postareanid1975, la 27 February 2012 - 11:23 PM, a spus:
Da.
Si sunt 2 modele... aparent identice: dar doar aparent... caci sunt diferente si de cuplu... si de turatie si de consum.
Iti dau mai multe detalii cand ne vedem... am testat ambele modele: si "cu urechi"... si fara!
Aceasta postare a fost editata de Adistul: 28 February 2012 - 03:08 AM
tel: 0771 088 207
adistul@yahoo.com
#16 Useril este offline   costelino
  • Postari: 71
  • Inregistrat: 13-June 09
Postat 28 February 2012 - 09:14 AM
Eu am masurat turatia motorului de aeroterma (din ala fara urechi de prindere) si este asa cum spune NID.
Din pacate cele cu urechi de prindere nu se mai gasesc. Poate la dezmembrari.
#17 Useril este offline   cricri_pescar68
  • Postari: 401
Postat 29 February 2012 - 10:34 AM
cum arata acel motor cu urechi de prindere ?
#18 Useril este offline   Adistul
  • Postari: 1490
Postat 29 February 2012 - 03:50 PM
E la fel cu al tau ca "infatisare" doar ca are si "urechi"... adica un colier deja prins de carcasa motorului... similar cu cel pus de tine.
tel: 0771 088 207
adistul@yahoo.com
#19 Useril este offline   ipsihi
Postat 29 February 2012 - 08:46 PM
Vezi postareaAdistul, la 29 February 2012 - 03:50 PM, a spus:
...are urechile sudate de carcasa, nici un colier !!!
Fisier atasat  100_4647.jpg (136.14K)
#20 Useril este offline   Adistul
  • Postari: 1490
Postat 01 March 2012 - 02:43 AM
Vezi postareaipsihi, la 29 February 2012 - 08:46 PM, a spus:
tot aia... ziceam si eu... poate nu atat de exact ca tine:
Number of downloads: 160Fisier atasat  Fotografii-0001.jpg (42.29K)
Aceasta postare a fost editata de Adistul: 01 March 2012 - 02:48 AM
tel: 0771 088 207
adistul@yahoo.com
#21 Useril este offline   sorin6969
  • Postari: 91
Postat 01 March 2012 - 07:51 AM
Stan si Bran erau la fel ca si"infatisare",numai ca unul era gras si unul slab...asa e si cu"infatisarea" la motoarele astea.
#22 Useril este offline   cricri_pescar68
  • Postari: 401
Postat 01 March 2012 - 11:06 AM
care dintre cele doua motoare consuma mai putin ?
#23 Useril este offline   ipsihi
Postat 01 March 2012 - 12:54 PM
...cel cu bridele sudate, 3A in sarcina cu elice de 60, turatia la 12V este in jurul a 3300 rpm !!!
#24 Useril este offline   Adistul
  • Postari: 1490
Postat 01 March 2012 - 03:42 PM
...cel fara bridele sudate, 2,5A in sarcina cu elice de 60, turatia la 12V este in jurul a 2800 rpm.
tel: 0771 088 207
adistul@yahoo.com
#25 Useril este offline   Adistul
  • Postari: 1490
Postat 01 March 2012 - 03:49 PM
Si un filmulet cu motorul de aeroterma in actiune cu un Li-po 4S incarcat full: 16,8V, elice de 50 cu 4 pale din alama, elice+kort: home-made.
Aceasta postare a fost editata de Adistul: 01 March 2012 - 03:51 PM
tel: 0771 088 207
adistul@yahoo.com
#26 Useril este offline   miuli74
  • Postari: 59
  • Inregistrat: 20-November 11
Postat 03 March 2012 - 06:41 AM
Vezi postareaAdistul, la 01 March 2012 - 03:49 PM, a spus:
Salutare!
Interesant, cumva intre ax si elice ai cardan???
#27 Useril este offline   cricri_pescar68
  • Postari: 401
Postat 03 March 2012 - 09:39 AM
daca folosesc o elice 4 pale dreapta da un randament mai mare?
#28 Useril este offline   ipsihi
Postat 03 March 2012 - 10:41 AM
...depinde ce urmaresti, viteza sau tractiune, si una si alta nu se poate, viteza o poti obtine doar usurand barca in detrimentul stabilitatii si autonomiei, daca vrei tractiune pui o elice de diametru si pas mai mare ,la motorul asta diferenta de consum este f mica, max 1A !!!
#29 Useril este offline   cricri_pescar68
  • Postari: 401
Postat 03 March 2012 - 06:50 PM
folosesc o elice de 60 3 pale sper sa faca fata la modelul lui NID
#30 Useril este offline   Adistul
  • Postari: 1490
Postat 05 March 2012 - 02:15 AM
Vezi postareamiuli74, la 03 March 2012 - 06:41 AM, a spus:
Salutare!
Nu. Elicea e fixa pe ax... axul este obisnuit... dar de la Raboesch. Doar kort-ul pivoteaza in jurul elicei... avand si rol de carma.
tel: 0771 088 207
adistul@yahoo.com
7 useri citesc topicul
