Modelism - RHC Forum: Set motorizare 840W - Modelism - RHC Forum
Set motorizare 840W Robbe Roxxy
#1 Useril este offline   silver arrow
  • Postari: 635
  • Inregistrat: 14-July 09
Postat 03 November 2011 - 07:38 PM
Vand set motorizare compusa din:
-motor BL Outrunner ROXXY 4250/ 07
Specificatii:
Nr. celule: 3-5 LiPo; 9-15 NiCd/ NiMH (20 V)
Curent nominal: 42 A
Curent maxim: 57 A (60 sec)
Turatie in gol: 720 rpm/ V
Elice: 13 x 6.5 inch
Putere maxima la ax: 840 W
Tractiune maxima: 3200 g
Masa: 195 g
Dimensiuni: D42 x L50 mm
Diametru ax: 5 mm
-Regulator electronic Brushless Roxxy BL-Control 950-6 (cu reverse optional programabil)
Specificatii:
Nr. Celule: 6-18 NiCd/ NiMH; 2-6 LiPo
Curent sustinut: 50 A
Curent maxim: 60 A pentru scurt timp
Functii: Inainte / Stop / Frana / Inapoi
Dimensiuni: 66 x 25 x 10 mm
Masa: 49 g (cu cabluri dar fara conectori)
BEC: 5.5 Volti/ max 3A
-Card de programare V2 pentru regulatoarele ROXXY
Auxiliary functions:
- Cut-off voltage NC / NiMH, LiPo
- Cut-off mode
- Motor timing
- Acceleration
- Start power
- Brake power
- Governor (speed regulator mode)
-Lipo 5s 4000mAh 20C (sub 8 incarcari)
http://img257.imageshack.us/img257/40/031120111076.jpg
Pret: motor+esc+programator=380lei (transport inclus)
motor+esc+programator+lipo=460lei (transport inclus)
tel. 0752063950
Asa "trage": http://vimeo.com/23968654
#2 Useril este offline   silver arrow
  • Postari: 635
Postat 10 November 2011 - 07:41 PM
Upp motor+esc+programator=370lei (transport inclus) valabil doar week-end-ul asta!!! :D
#3 Useril este offline   silver arrow
  • Postari: 635
Postat 11 November 2011 - 02:08 PM
vandut.
