Modelism - RHC Forum: EasyStar II - Modelism - RHC Forum
  • 14 Pagini +
  • 12
  • 13
  • 14
EasyStar II Continuare fireasca a EasyStar-ului...
#391 Useril este offline   Huffy
  • Postari: 811
  • Inregistrat: 30-July 08
Postat 12 February 2014 - 01:27 PM
Vezi postareaLev, la 05 February 2014 - 08:28 PM, a spus:
Am luat azi aripi de easy star II pentru easy star I si trebuie taiat foarte putin inspre cabina si intra la fix, o sa tai direct din avion ca oricum aripi pt easy star I nu se mai gasesc. E foarte bine ca oricum voiam eleroane.
Incerca sa-i pui aripi de Easy Glider ;).Am avut ocazia sa vad un EZ* 1 cu aripi de EG si am ramas uimit.Poate ca, zilele acestea, o sa incerc si eu aripile de EG pe EZ*2, ca si asa stau pe dulap si aduna praf.
Bondar cu 4 elici
Discus
Easy Star 2
HEPTAD 2200
Easy Glider
0722.464.922. - 0744.100.626.
Programari chei Logan
#392 Useril este offline   Radubv
  • Postari: 740
  • Inregistrat: 09-February 12
  • Interests:Aero-Auto RC.
Postat 05 December 2014 - 08:33 PM
Salutare,
Intentionez sa iau un Easy Star II ARF (fara baterie si Rx). Va rog sa-mi recomandati niste acumulatori compatibili cu acest model, ideal ar fi de la HK sau in tara daca gasesc mai ieftini.
Va multumesc anticipat.
AUTO
HPI Trophy Truggy 4.6 2013 2.4GHZ Waterproof- nitro
HPI Blitz2 Flux - electric
FG Baja Buggy Sportsline - benzina
AERO
Align T-Rex 450 Pro V2 - Augusta electric
Align T-Rex 500L Dominator - electric
Align T-Rex 700E DFC - electric
Drake by Dululutu -electric
Easy Star II by Multiplex - electric
Phoenix 2400 - electric
Sbach 342 by FMS 1300mm - electric
DJI Mavic Pro
Realacc Real5 215MM FPV Racing Drone
|||Spektrum DX9|||
#393 Useril este offline   stiganas
  • Postari: 8326
Postat 05 December 2014 - 09:03 PM
Un bun punct de pornire e recomandarea producatorului:
http://www.multiplex...83a6206094f81b7
The most impressive feature of the EasyStar II is its incredibly long flight times. With the recommended 2000 mAh ECO battery it is possible to rack up forty minutes of flying without thermal assistance. Fit a 4600 mAh ECO pack, and you can fly for 90 minutes, which equates to a distance of 70 km.
#394 Useril este offline   renatoa
Postat 05 December 2014 - 09:12 PM
Bateria este asta:
http://www.multiplex...-2000-m6-1.html
Dupa standardele HK este cam grea 2000mAh la 185g pentru 12C ... :unsure:
Chiar si dupa standardele Lindinger, am 2200mAh 30C la 174g
Dar astea sunt detalii, orice 2200 merge.
#395 Useril este offline   Radubv
  • Postari: 740
Postat 06 December 2014 - 11:44 AM
@stiganas & renatoa
Multumesc de raspunsuri. Evident ca m-am uitat intai la bateria originala, insa pretul m-a demoralizat putin. Plus ca preturile de la Multiplex mi se par...nesimtite. Ma gandeam ca la banii aceia as putea sa iau doua din acestea :
http://www.hobbyking...arch=2200%20mah
Credeti ca e prea grea ?
Din experienta cu elicopterele ,cele originale nu sunt atat de reusite ca nano-tech-le de exemplu. La Lindinger , de unde iau si avionul, au baterii wellpower, care pe mine m-au cam dezamagit la mCPX. Eventual sa iau kitul RR+ care contine si receptorul multiplex si o baterie originala(179,90 euro). Kitul fara receptor si baterie este 139,90 euro.Deci la bani ies cam tot pe acolo si mai si raman cu un receptor degeaba , deoarece eu am un Spektrum DX6i. Cam asta e motivul pentru care ezit sa iau bateria originala, fie in kit fie separat.
AUTO
AERO
DJI Mavic Pro
|||Spektrum DX9|||
#396 Useril este offline   renatoa
Postat 06 December 2014 - 11:57 AM
As lua zippy compact 25C, sunt cele mai reusite la ora actuala, nano tech-urile suna bine doar in reclama, dupa parerea personala si a multor altora.
De greutate nu ai grija, daca MPX vorbeste de echipare cu pana la 4600mAh !
Eu cu Wellpower am experiente bune, a petrecut una o noapte in multicopter conectata, dimineata era la 1.5V / cell si acum zboara bine merci. Am un set de 4 care inca nu au 10 zboruri fiecare, asa ca nu pot vorbi cat de durabile sunt. Dar adevarul este ca a fost o promotie la 15 Euro, nu as lua la preturile de acum...
#397 Useril este offline   stiganas
  • Postari: 8326
Postat 06 December 2014 - 03:43 PM
Pai cine a spus sa cumperi bateria originala, ar fi bani aruncati pe geam. EZ2 consuma 12A la blana. Asta inseamna ca orice baterie cat de mica, cat de obosita merge fara probleme. Poti sa folosesti pakuri obosite ramase de la Trex 450 sau pakuri de 800-1000mah daca vrei sa fie foarte usor.
E cel mai compatibil aeromodel cu putinta, orice intra inauntru si da curent e compatibil (3s bineinteles).
Daca vrei musai un pak nou asa cum a zis renato un Zippy Compact 25C e cel mai bun ca are multa energie raportat la masa.
#398 Useril este offline   AdrianDim
  • Postari: 562
  • Inregistrat: 29-April 12
  • Interests:aeromodelism
Postat 06 December 2014 - 07:55 PM
Uite cu ce zbor eu pe EZ II : http://hobbyking.com...po_Pack.html.Te plictisesti cat zbori cu el , in plus ca se echilibreaza la fix cu acumulatorul impins in model in fata cat merge (fara sa opuna rezistenta) . Eu zburam si cate 2-3 ore cu un acumulator .EZ II planeaza de te plictisesti.In plus ca pe el am invatat sa si zbor RC . :) Bafta si aterizari line (si cat mai multe) !
Adrian Dimitriu
Imagine postata
#399 Useril este offline   renatoa
Postat 06 December 2014 - 08:08 PM
Da, asta e cel de care scriam mai sus.
#400 Useril este offline   Radubv
  • Postari: 740
Postat 07 December 2014 - 12:44 PM
Va multumesc tuturor pentru raspunsuri. Sper sa am ...aterizari line si zbor lung cu el. O sa aleg kitul de 139.90 fara receptor si acumulator. Voi cumpara 2 baterii Zippy, iar ca si receptor pentru un DX6i DSM2, voi ce-mi recomandati ?
AUTO
AERO
DJI Mavic Pro
|||Spektrum DX9|||
#401 Useril este offline   Radubv
  • Postari: 740
Postat 01 January 2015 - 06:24 PM
La multi Ani tuturor !
Chiar daca Mosul a intarziat ...vreo 30 de ani.... :rofl: ...il iert si ma declar multumit cu ceea ce mi-a adus anul asta. :drinks:
Sosit Easy Star II, sosit acumulatorii. Cu aceasta ocazie tin sa va spun ca transportul GLS de la Lindiger si HK este fara repros. Comenzi facute in 20.12.2014 au sosit ambele in 26 respectiv 29.12.2014, in conditiile in care au fost sarbatori si weekend-uri la mijloc. Sunt cu adevarat incantat de serviciile prestate de cele doua firme. Asa ca in sfarsit am avut iar de mesterit ceva.
M-am apucat si am pus servourile de eleroane, prilej cu care am constatat ca sunt scurte cablurile servo-lor (lucru la care nu m-am gandit cand le-am comandat). Ulterior comenzii la HK am constatat ca nu-mi trebuie cablu in Y pentru ca cele 6 canale ale receptorului Orangerx 620 sunt suficiente pentru a monta fiecare servo pe alt canal. Si ca sa am ...am comandat 3 bucati, neobservand ca sunt 5 la punga...hahaha...asa ca am un kg de cabluri in Y acum. Asa ca mi-am permis sa stric 2 si sa prelungesc cablurile servourilor pana unde am montat prelungitoarele in fuselaj.
http://s25.postimg.org/ardn5x3tn/P1011252.jpg
http://s25.postimg.org/ugvxidbq3/P1011259.jpg
http://s25.postimg.org/7qwspdsij/P1011260.jpg
De aici incolo totul a mers ca uns . Ca sa nu tai cablurile bateriilor care au venit cu conectori XT60, am facut un adaptor XT60 la XT (Jeans) , am taiat conectorul verde ciudat de la ES si am pus unul XT.
http://s25.postimg.org/sg5dxjfkr/P1011253.jpg
http://s25.postimg.org/ib6q7yx0b/P1011254.jpg
http://s25.postimg.org/7pmuvyqor/P1011255.jpg
Acum totul e ok, am facut si testele cu un Orange 615 de imprumut totul functioneaza ca la carte, ramane de vazut primul zbor sau maiden-ul cum am observat ca se spune pe aici. Din pacate acest lucru nu se va intampla decat cand va fi vreme faina de iesit si cand imi vor sosi receptoare R620 comandate , din pacate pe BackOrder, stocurile HK fiind vraiste dupa sarbatorile astea.
A si pentru ca ma astept si la aterizari mai dure , i-am dat niste banda de fibra pe burtica si in bot, acolo unde probabil vor fi socurile mai mari. Ma gandesc ca rau nu-i face , cel mult din punct de vedere al aspectului.
http://s25.postimg.org/c7p5o26qj/P1011257.jpg
Rezultatul final pe care multi dintre voi il stiti este superbul trainer Easy Star II :
http://s25.postimg.org/nlboz9h97/P1011258.jpg
Pentru cine are ESII, va rog daca se poate niste sfaturi/poze cu modul cum ati montat si echilibrat acumulatorul si receptorul.Si din experienta celor care l-au avut/au va rog sa-mi spuneti daca acele balamale care vin din turnare tin sau trebuie sa le intaresc de pe acum cu banda cu fibra de sticla.
AUTO
AERO
DJI Mavic Pro
|||Spektrum DX9|||
#402 Useril este offline   YO2BTW
  • Postari: 312
  • Inregistrat: 02-January 15
  • Interests:Radioamatorism, Ceasornicarie, Modelism, Astronomie, Foto/Video, Bijuterii HandMade, Parfumerie, OffRoad, Tir cu arcul olimpic...etc
Postat 15 February 2015 - 10:54 PM
Am si eu un EasyStar II in constructie.
Am intrebat la sierra ce adeziv sa folosesc, au recomandat robbe Extra Speed Dick
http://sierra.ro/Ade...00C-p1681p.html
Am cumparat ...
Am trecut la teste, ca asa este prudent , pe bucatele de polistiren expandat.
Am incercat 4 adezivi, trei dintre ei se comporta super, lipire strong si buna.
Adezivi testati:
1 - BISON polyurethane - foarte bun, lipire dura lipire galbuie
2 - BISON Universal Hobby Glue, bun, lipitura transparenta dura.
3 - MOMENT - FIX, este si pentru lemn, lipire buna, dura
4 - ROBBE - Extra Speed Dick ...gauri mari in spuma, catastrofa
Dar acesta recomandat, a facut gaura, si tot inainteaza, se topeste vazand cu ochii. :pardon:
Voi ce parere aveti ?
Adrian - YO2BTW
YR - BTW
EASY STAR II
Phoenix 2000 EPO Composite R/C Glider
Tarot 680 Pro NAZA M V2 - GoPro 4 Black
DJI F450 NAZA-M V2 - GoPro 4 Black
FrSky TARANIS Plus-OpenTX
#403 Useril este offline   Adi-GVA
  • Postari: 739
Postat 15 February 2015 - 11:00 PM
Easystar-ul e construit din elapor si nu din stiren (spuma), are alta compozitie chimica; pe care nu o ataca adezivii gen superglue.
Fly Extreme! __EXTREME FLIGHT
#404 Useril este offline   ViorelX
  • Postari: 537
  • Inregistrat: 06-October 09
Postat 15 February 2015 - 11:01 PM
Adezivul poliuretanic monocomponent (Bison) e garantat. Umple goluri, are densitate mica, doar ca se ingalbeneste in timp (se degradeaza la UV).
#405 Useril este offline   stiganas
  • Postari: 8326
Postat 15 February 2015 - 11:11 PM
Cu riscul de a fi enervant; EasyStar are un manual gros, tiparit, o raritate in ziua de azi. La pagina 12 in manual gasiti asta:
Important note
This model is not made of Styrofoam™, and it is not possible to glue the material using white glue, polyurethane or epoxyadhesives. These glues only produce a superficial bond which fails immediately when stressed. Please be sure to use medium-viscositycyano-acrylate glue exclusively - ideally our Zacki -ELAPOR® # 59 2727, the super-glue designed and optimized expressly for ELAPOR® particle foam.
Oare cum e mai bine ? dupa ureche sau dupa manual ?
Astea fiind zise si eu am folosit poliuretanic monocomponent cu succes acolo unde am vrut sa am timp berechet pentru alinierea pieselor.
Aceasta postare a fost editata de stiganas: 15 February 2015 - 11:13 PM
#406 Useril este offline   YO2BTW
  • Postari: 312
Postat 15 February 2015 - 11:33 PM
Vezi postareastiganas, la 15 February 2015 - 11:11 PM, a spus:
Important note
Deci sa inteleg ca am gresit materialul pentru teste, am citit si eu manualul foarte atent, dar am si primit tot felul de informatii cu acesti adezivi.
Primul a fost recomandat, acest BISON Polyurethane, apoi altele...
In concluzie, am gresit materialul pentru test. :pardon:
Adrian - YO2BTW
YR - BTW
EASY STAR II
#407 Useril este offline   ViorelX
  • Postari: 537
Postat 16 February 2015 - 09:41 AM
Da, ce e drept, piesele de elapor cu suprafete netede nu se lipesc bine decat cu CA. Dar daca le slefuiesti cu hartie abraziva de granulatie mare, se lipesc f bine si cu adezivul poliuretanic. Altfel, mai e f bun si UHU Por, dar e mai scump si lipeste f repede: cum ai presat piesele, s-au si lipit, nu mai ai timp sa corectezi pozitiile.
Intr-adevar, polistirenul si elaporul sunt materiale f diferite. CA ataca polistirenul, dar nu si elaporul. Iar adezivul poliuretanic e bun pt ambele.
Aceasta postare a fost editata de ViorelX: 16 February 2015 - 09:45 AM
#408 Useril este offline   Radubv
  • Postari: 740
Postat 16 February 2015 - 10:12 AM
Vezi postareaYO2BTW, la 15 February 2015 - 10:54 PM, a spus:
Am cumparat ...
Adezivi testati:
Adrian - YO2BTW
Eu am folosit cu rezultate bune CA Aero-Bond varianta medium. (http://shop.lindinge...oducts_id=17777).Nu ataca materialul, momentan nu am observat sa se ingalbeneasca, lipitura pare strong.Am luat modelul tot de la ei si asta mi-au recomandat.
AUTO
AERO
DJI Mavic Pro
|||Spektrum DX9|||
#409 Useril este offline   YO2BTW
  • Postari: 312
Postat 16 February 2015 - 11:27 AM
Vezi postareaRadubv, la 16 February 2015 - 10:12 AM, a spus:
Am inteles, eu am facut testele pe un polistiren expandat ordinar, care nu este acelasi material cu cel din EasyStar II.
Problema este lamurita !
Adrian - YO2BTW
YR - BTW
EASY STAR II
#410 Useril este offline   Radubv
  • Postari: 740
Postat 21 February 2015 - 09:44 PM
Si in sfarsit a sosit si ziua maiden-lui :
https://www.youtube....h?v=TTLeZi6l2xk
Aceasta postare a fost editata de Radubv: 21 February 2015 - 09:45 PM
AUTO
AERO
DJI Mavic Pro
|||Spektrum DX9|||
#411 Useril este offline   YO2BTW
  • Postari: 312
Postat 21 February 2015 - 11:46 PM
Vezi postareaRadubv, la 21 February 2015 - 09:44 PM, a spus:
Toate au un inceput, felicitari !
A patit ceva la aterizare ?
Adrian - YO2BTW
YR - BTW
EASY STAR II
#412 Useril este offline   Radubv
  • Postari: 740
Postat 22 February 2015 - 11:27 AM
Vezi postareaYO2BTW, la 21 February 2015 - 11:46 PM, a spus:
Adrian - YO2BTW
Pfff...am pus celalalt avion, de fapt asta e videoclipul cu ES II.
https://www.youtube....h?v=MTI4cJzsyCw
Si da , aterizarea s-a lasat cu cateva "urme". Botul crapat , fuselajul crapat in zona de prindere aripa (inainte de aterizare, la o decolare nereusita), si o parghie de la profundor dezlipita si ea. Insa totul a fost deja reparat, astept sa se intareasca lipiturile. Sincer, ma asteptam la mai rau, dar avionul este bine facut si robust.
AUTO
AERO
DJI Mavic Pro
|||Spektrum DX9|||
#413 Useril este offline   YO2BTW
  • Postari: 312
Postat 22 February 2015 - 11:56 AM
Vezi postareaRadubv, la 22 February 2015 - 11:27 AM, a spus:
DA, acum este EasyStar II, bravo !
Filmarea este multumitoare. Cei care filmeaza au tendinta sa urmareasca ca si ochiul uman, gresit.
Camera trebuie sa stea cat mai fix si usor sa urmareasca modelul, nu trebuie permanent tinut in centru, se corecteaza usor
in funtie de pozitia in cadru si directia de zbor.
Multe zboruri line !
Adrian - YO2BTW
YR - BTW
EASY STAR II
  • 14 Pagini +
  • 12
  • 13
  • 14
44 useri citesc topicul
0 membri, 44 vizitatori, 0 utilizatori anonimi
