Modelism - RHC Forum: Motoare pt Jet - Modelism - RHC Forum
Motoare pt Jet
#1 Useril este offline   ady23
  • Postari: 724
  • Inregistrat: 06-October 07
  • Gender:Not Telling
Postat 31 May 2011 - 06:44 PM
Vand 3 motoare brushless Thyphoon noi in cutie pt jet.
HET Typhoon 2W-25 2720Kv (1100W) Brushless Motor disponibil 1 buc la 150 lei.
This is one of the most powerful brushless Motors available in its class. Stunning power in 70mm EDF units. Can also be used with a 4.7 x 4.7 prop (if a powerful ESC is used) for super fast pylon racers or pusher jets. Offering great build quality and maintainance free operation.
Specifications:
* Diameter: 28mm
* Length: 48mm
* Shaft Dia.: 3.17mm
* Weight: 110g
* No load current(lo): 2.2A
* Internal resistance: 16 mOhm
* KV: 2660
* Max Current: 50A
* Max efficiency: 87%
* Power Nominal: 1100 Watts (on 6S)
* Recommended Props: APC E 4.7 X 4.7
HET 700-83-1445Kv Typhoon disponibil 2 buc 250 lei bucata.
The HET 700 series 39mm Typhoon motors are specifically designed for 90-120mm fans. The HET 700-83-1445 motor used in a Stumax SM89-45 will produce around 2000W on 6S (~3.3Kg thrust ) depending on setup and temp.
Motor comes with heat sink.
Product Information:
-RPM Per Volt: 1445
-Diameter : 39 mm
-Length : 82.8 mm
-Shaft Dia. : 5/8 mm
-Weight : 460 grams
-Poles : 4
Aceasta postare a fost editata de ady23: 31 May 2011 - 06:47 PM
#2 Useril este offline   Iamzoli
  • Postari: 815
  • Inregistrat: 08-January 10
Postat 31 May 2011 - 08:21 PM
ce shaft are HET 700-83-1445Kv ?
....in Thrust we trust....
Flying Vampires Arad
#3 Useril este offline   ady23
  • Postari: 724
Postat 08 June 2011 - 07:07 PM
up
#4 Useril este offline   ady23
  • Postari: 724
Postat 17 June 2011 - 07:01 PM
up
#5 Useril este offline   ady23
  • Postari: 724
Postat 12 July 2011 - 09:14 PM
up
#6 Useril este offline   ady23
  • Postari: 724
Postat 20 July 2011 - 07:48 PM
up
#7 Useril este offline   ady23
  • Postari: 724
Postat 04 October 2011 - 05:31 PM
Urgent, pret pachet 300 lei +transport
Aceasta postare a fost editata de ady23: 04 October 2011 - 05:31 PM
#8 Useril este offline   ady23
  • Postari: 724
Postat 05 October 2011 - 05:52 PM
Urgent, pret pachet 250 lei +transport
#9 Guest_teamMec_*
  • Grup: Guests
Postat 05 October 2011 - 08:52 PM
Vezi postareaady23, la 05 October 2011 - 05:52 PM, a spus:
vreau eu motoarele de 39mm, amandoua 180 lei. daca e ok iti trimit adresa. multumesc.
mai sterge din mesagerie, e plina!
#10 Useril este offline   ady23
  • Postari: 724
Postat 06 October 2011 - 06:28 AM
E ok trimite adresa (sau suna-ma la 0761662853), mesageria nu e plina nu merge.
Aceasta postare a fost editata de ady23: 06 October 2011 - 06:28 AM
#11 Useril este offline   ady23
  • Postari: 724
Postat 06 October 2011 - 05:48 PM
2 motoare au plecat azi a ramas
HET Typhoon 2W-25 2720Kv (1100W) Brushless Motor disponibil 1 buc la 60 lei.
Specifications:
* Diameter: 28mm
* Length: 48mm
* Weight: 110g
* KV: 2660
* Max Current: 50A
#12 Useril este offline   ady23
  • Postari: 724
Postat 10 October 2011 - 09:40 PM
50 lei
#13 Guest_teamMec_*
  • Grup: Guests
Postat 10 October 2011 - 10:09 PM
Vezi postareaady23, la 10 October 2011 - 09:40 PM, a spus:
50 lei
doua motoare au ajuns la mine, in stare impecabila vizuala. nu le-am probat inca, caci nu am conectori disponibili. ms si bafta.
#14 Useril este offline   ady23
  • Postari: 724
Postat 17 October 2011 - 11:05 AM
UP
#15 Useril este offline   ady23
  • Postari: 724
Postat 17 November 2011 - 06:34 PM
vandut.
10 useri citesc topicul
