Modelism - RHC Forum: 2 sisteme video FPV in 900 mhz + antene - Modelism - RHC Forum
2 sisteme video FPV in 900 mhz + antene + Bonus 1 OSD
#1 Useril este offline   kempo
  • Postari: 670
  • Inregistrat: 17-October 08
Postat 02 April 2011 - 09:26 PM
Vand 2 sisteme video in 900mhz:
Sistem 1 500MW :
Cumparat de mine SH. tx si rx sunt astea:
http://www.rangevide...9a0593d7ddd07a6
Uitati-va prin filmele postate de mine si vedeti cum se comporta.
Sistem 2 400MW
http://www.bevrc.com...400mw-p-54.html
Nu prea l-am folosit.
Pret sistem 1 : 300 ron. Pret sistem 2 : 200 ron.
Oferta in cazul in care se cumpara ambele sisteme:
Pret: Sistem 1+ Sistem 2 500 ron si se adauga:
1 antena patch ptr rx 8dbi homemade in canalul 3 (e in masina si mi-a fost greu sa cobor sa-i fac foto, dar daca e nevoie...)
1 antena inverted Vee ptr tx in canalul 3
1 OSD de la RCMILE nefolosit( http://www.cnchelico...st-price/Detail http://rmilec.com/cp/html/?5.html )
"What you want to do today ? Same thing I do every day, try to take over the world !"
#2 Useril este offline   Olvi
  • ex rou162
  • Postari: 376
  • Inregistrat: 02-September 08
Postat 03 April 2011 - 10:14 PM
dai la schimb cel mai ieftin cu un sistem in 2.5ghz pt fpv??
Best way to get to next level is to practice. So fly fly fly and at the end of the day fly again.
Push your limits to a level you have never did before.
#3 Useril este offline   kempo
  • Postari: 670
Postat 04 April 2011 - 05:45 AM
Nu.
#4 Useril este offline   kempo
  • Postari: 670
Postat 04 April 2011 - 05:58 PM
Sau schimb cu EZ* sau alt aeromodel ptr incepatori(pusher sau trainer) + diferenta.
#5 Useril este offline   p_cipri
  • Postari: 955
  • Inregistrat: 20-August 03
Postat 06 April 2011 - 06:18 AM
Sal. Imi poti spune te rog Sistemul 2, daca l-ai testat, pana la ce distanta aproximativ bate?
Si .... daca la acesta, 200 ron ete ultimul pret? fiindca eu nu dispun momentan de acest buget
Multumesc anticipat.
Quad S500 cu Naza V2
EasyGlider Pro
#6 Useril este offline   p_cipri
  • Postari: 955
Postat 06 April 2011 - 10:42 AM
Salut din nou. Inainte de toate, spune-mi te rog, Daca stai pe loc cu avionul, motorul oprit, sistemul video pornit, Emitatorul se incalzeste? Caci eu unul am vazut un emitator in 1,2GHz care, dupa vre-o 3-4 minute fara radiator pe el, doar asa cum se vede la inne in poza, Se incalzea foarte tare de abia mai puteai pune mana pe el.
Acelasi lucru se intampla si cu astea ale tale?
Inteleg ca in zbor datorita curentului de aer dat de elice sau de viteza zboruluise raceste nitel Dar asa stationar?
Multumesc inca o data
EasyGlider Pro
#7 Useril este offline   kempo
  • Postari: 670
Postat 06 April 2011 - 03:28 PM
 p_cipri, la 06 April 2011 - 10:42 AM, a spus:
Cu sistemul 2 nu prea am zburat , dar teoretic duce relaxat 1 km. Sa ma uit prin filmele salvate, sa vad daca gasesc ceva.
Din cate stiu, cam toate TX-urile video se incalzesc. Nu prea am stat sa vad cat de tare se incalzesc, dar de multe ori, in timpul configurarii osd-ului/cand faceam teste in casa a stat alimentat si 30 minute si nu a crapat.
In timpul zborului, tx-ul il plasezi in curent de aer si nu ai nici o problema.
Pana acum eu nu am intampinat probleme vis a vis de incalzirea excesiva a tx-urilor (si tot timpul au fost alimentate de acumulatori Lipo de 3 celule).
Edit: Pretul e fix.
Aceasta postare a fost editata de kempo: 06 April 2011 - 03:30 PM
#8 Useril este offline   kempo
  • Postari: 670
Postat 19 April 2011 - 08:44 AM
up
#9 Useril este offline   kempo
  • Postari: 670
Postat 28 April 2011 - 09:18 AM
Se dau la schimb cu easy star/trainer/motoplanor , daca e nevoie platesc diferenta.
#10 Useril este offline   turtadulce
  • Postari: 64
  • Inregistrat: 18-June 10
  • Interests:tot ce misca...
Postat 28 April 2011 - 09:27 PM
Salut! te intereseaza un electro-rookie complet echipat in schimbul sistemelor fpv? rooki-ul a fost zburat 1 an si are si cateva crash-uri, dar fiind din spuma, s-a reparat sooper OK. Am si un profundor nou in punga! Vezi poze la EZ.
#11 Useril este offline   kempo
  • Postari: 670
Postat 28 April 2011 - 09:44 PM
 turtadulce, la 28 April 2011 - 09:27 PM, a spus:
Nu.
#12 Useril este offline   kempo
  • Postari: 670
Postat 10 May 2011 - 10:44 AM
up
#13 Useril este offline   kempo
  • Postari: 670
Postat 17 May 2011 - 01:34 PM
up
#14 Useril este offline   edy_lucian
  • Postari: 327
  • Inregistrat: 12-October 06
  • Interests:aero 1:1, aeromodelism
Postat 07 June 2011 - 07:23 PM
Spune-mi daca te-ar tenta un planor scale (Ventus 2bx, cu roata escamotabila, etc,). Nu a fost inca asamblat. Anvergura 2,65m.
Il gasesti inclusiv pe siteurile romanesti. Poate fi si motorizat, depinde de ce iti doresti de la el.
Succes !
#15 Useril este offline   kempo
  • Postari: 670
Postat 07 June 2011 - 08:27 PM
 edy_lucian, la 07 June 2011 - 07:23 PM, a spus:
Succes !
Planorul este super dar,din nefericire, imi depaseste cu mult calitatile de "constructor".
Daca-l iau , nu cred ca va zbura prea curand.
#16 Useril este offline   edy_lucian
  • Postari: 327
Postat 07 June 2011 - 10:40 PM
Ok.
Daca te decizi in directia asta, da-mi mesaj.
Saptamana buna in continuare !
#17 Useril este offline   draude80
  • Postari: 273
  • Inregistrat: 25-August 09
  • Interests:Aero, FPV
Postat 11 June 2011 - 12:28 PM
 kempo, la 07 June 2011 - 08:27 PM, a spus:
Salut!
Am la vanzare un planor ASW 15 si un minimag.
Aici ai postul:http://www.rhcforum.ro/topic/39245-asw-15-si-minimag/
Daca esti interesat baga un pm...eu doresc osd-ul si sistemul de 500mw!
#18 Useril este offline   Rivelino
  • Postari: 273
  • Inregistrat: 21-June 09
Postat 11 June 2011 - 11:24 PM
Ma intereseaza sistemul 2 de 400 mW.
Poti sa-l trimiti prin cineva in Bucuresti ?
Ca lui Fan Curier m-am saturat sa le tot dau bani.
Eventual Posta Romana.
#19 Useril este offline   zigotu
  • Postari: 231
  • Inregistrat: 29-June 09
Postat 13 June 2011 - 12:31 AM
Ma intereseaza sistemul 1 de 500 plus osd.Da-mi privat te rog.Mersi
#20 Useril este offline   kempo
  • Postari: 670
Postat 13 June 2011 - 06:29 AM
 Rivelino, la 11 June 2011 - 11:24 PM, a spus:
Pot trimite prin Posta Romana.
 zigotu, la 13 June 2011 - 12:31 AM, a spus:
Pm trimis.
#21 Useril este offline   Rivelino
  • Postari: 273
Postat 13 June 2011 - 03:35 PM
Salu,
Ai PM.
4 useri citesc topicul
