Modelism - RHC Forum: Stampede 4x4 VXL brushless - Modelism - RHC Forum
Stampede 4x4 VXL brushless discutii despre Monster Truck, modificari, etc Evaluare topic: -----
#31 Useril este offline   Florin1up
  • Postari: 132
  • Inregistrat: 09-November 10
  • Interests:Automodelism, electronica
Postat 27 January 2011 - 09:29 AM
REPLY:
Hello,
It sounds like you need to send your VXL-3s to us for inspection/repair. There is a 30 day warranty on all Traxxas electronics. Beyond that there is a repair charge of $50 for the VXL-3s plus $5 shipping within the US.
If you have not already registered your vehicle on our web site, please do so at http://www.traxxas.com/register
Once you have registered respond to this e-mail with the vehicles serial number your name, phone number, address and your Zip code. I will generate an RMA number for you to send it in.
Here is the service and repair information. http://www.traxxas.c...age-Electronics
Best regards,
Steve Lindholm,
aaaa.. si nu exista reprezentanta traxxas in romania.
Traxxas Summit 1:10 & Stampede 1:10
#32 Useril este offline   mihai_mag
  • Postari: 235
  • Inregistrat: 21-June 09
Postat 27 January 2011 - 11:17 AM
Salut! Traxxas electric poate sa aiba 3 feluri de motorizari: 1 Brushed, 2 Brushless VXL si 3 Brushless Mamba Monster.
Motorizarea 1 Brushed - Producatorul spune ca este waterproof dar adevarul este ca numai ESC-ul e waterproof. Motorul nu este. Este recomandat sa cureti motorul (atat cat este posibil din exterior pentru ca este capsat) dupa fiecare tura prin apa.
Motorizarea 2 Brushless VXL - La fel ca motorizarea 1, producatorul spune ca este waterproof. Aici, din experienta personala tind sa ii cred pentru ca nu am avut probleme din cauza apei/zapezii/noroiului pana acum. Ce ai patit tu cred ca ar fi tinut de garantie daca nu ai fi desfacut ESC-ul. Ca o paranteza pot sa iti spun ca eu spal Slash-ul meu (acelasi combo) cu dusul si nu are nimic.Cidat totusi ca Traxxas da garantie numai 30 de zile. Cei care vand Traxxas in Romania dau un an de zile garantie la partea electronica fara a fi nevoit sa platesti inspectia. Sigurele costuri legate de garantie sunt cele privind transportul prin curier al piesei defecte inapoi la vanzator. De aici si diferenta de pret intre State si Romania. Unii se bucura ca iau un produs mai ieftin de afara fara sa ia in calcul acest aspect.
Motorizarea 3 Brushless Mamba Monster - Nu este waterproof. Sunt tot felul de metode de a izola ESC-ul (chiar si aici pe forum au fost descrise cateva) dar asta inseamna sa il desfaci ceea ce duce automat la pierderea garantiei. Motorul nu prea are cum sa fie izolat complet insa atata timp cat nu il bagi prea mult prin apa nu cred sa aiba vre-o problema. Cativa stropi nu cred sa ii faca prea mult rau.
Sper sa iti rezolvi problema si sa te bucuri de modelul tau in continuare.
Respect the forum staff
#33 Useril este offline   Florin1up
  • Postari: 132
Postat 27 January 2011 - 08:49 PM
Problema am rezolvat-o si acum e aproape submersibil. L-am izolat complet cu silicon in interior. Am imbunatatit si racirea punand un alt termalpad, mai bun, folosit si la laptopuri. (este vb de acel cauciuc ce face transferul termic).
Eram sigur ca o sa rezolv problema, motiv pentru care am decis sa-l desfac. Asa as mai fi asteptat cel putin o luna.. caz nefericit... :wub:
#34 Useril este offline   davidd
  • Postari: 371
  • Inregistrat: 23-March 10
  • Interests:Everything
Postat 04 February 2011 - 09:21 AM
Vezi postareamihai_mag, la Jan 27 2011, 11:17 AM, a spus:
motoarele brushed (atata timp cat ai grija la coroziune), eu stiu ca nu au nimic cu apa... se vorbea despre asta undeva pe forum
(scz de off-topic)
fain modelu, asteptam poze dupa montarea senzorilor, si poate chiar un filmulet
"I reject your reality and substitute my own"
david_dinamovistu@yahoo.com
0742128727
#35 Useril este offline   Florin1up
  • Postari: 132
Postat 06 February 2011 - 02:03 AM
trebuia sa se intample si asta: am rupt bascula stanga si mi-a sarit si capacul unui amortizor..cu tot cu ulei :). Are cineva idee de unde o pot cumpara (preferabil Ro)? model: stampede 6708
As prefera tot din plastic compozit; schimbandu-le cu unele din aluminiu, risc sa rup altceva data viitoare. Deocamdata nu am decat poza asta.
amortizorul pare ok, numai ca trebuie curatat, ulei nou si reasamblat.
Pana una-alta am gasit azi vaselina cu bisulfura de molibden, :D care nu se mai spala asa usor si este extrem de rezistenta la apa. Se foloseste la planetarele automobilelor.
  • Imagine atasata: untitled.JPG
#36 Useril este offline   RC-Toys
  • Postari: 35
  • Inregistrat: 30-January 11
Postat 06 February 2011 - 10:34 AM
Codul piesei este 3655X si se gaseste in stoc in Romania, chiar in Bucuresti :)
Pe viitor ia codul piesei de pe pagina de scheme explodate ale automodelului si apoi cauta codul pe google romania (ex. traxxas 3655x) - nu intotdeauna cei de pe forum stiu sau vor sau pot sa te ajute - cea mai rapida solutie este cea pe care ti-am oferit-o eu (dupa parerea mea, desigur) :)
Aceasta postare a fost editata de RC-Toys: 06 February 2011 - 10:37 AM
#37 Useril este offline   Florin1up
  • Postari: 132
Postat 07 February 2011 - 07:50 PM
imi vinde cineva ulei cat sa umplu un amortizor? i-a sarit capacul si s-a dus.. Cat ulei se pune in ele? 80%
S-a rezolvat cu basculele.
#38 Useril este offline   tiberius
  • Postari: 15
  • Inregistrat: 30-May 10
Postat 07 February 2011 - 09:58 PM
http://www.youtube.c...h?v=7_uxlmsHddQ . Teoretic nu trebuie sa mai ramana nicio bula de aer in interior.
#39 Useril este offline   ovidiugm
  • Postari: 1031
Postat 07 February 2011 - 10:59 PM
Vezi postareaFlorin1up, la Feb 7 2011, 07:50 PM, a spus:
Pentru comportament echilibrat al masinii se recomanda umplerea tuturor amortizoarelor cu acelasi tip de ulei. E ieftin, 15-20 lei sticluta, si ajunge pentru 3-4 umpleri. Daca folosesti un ulei de alta densitate decat ai in celelalte trei amortizoare e posibil sa "topaie" mai mult pe partea aia.
Aceasta postare a fost editata de ovidiugm: 07 February 2011 - 10:59 PM
#40 Useril este offline   Florin1up
  • Postari: 132
Postat 08 February 2011 - 12:46 AM
da, asa este. o sa-mi iau o sticla intreaga, sigur o sa mai am nevoie.
#41 Useril este offline   Vladutzzz
  • Postari: 472
  • Inregistrat: 20-December 10
Postat 13 March 2011 - 10:51 AM
salut ceva noutati cu sistemul de lumini? mam chinuit si eu sa fac asa ceva dar ma enerveaza ca se tot ard ledurile si as vrea sa fac ceva asemanator ca la tine dar o schema cev ce sa le cer la aia de la magazin ce tip de leduri ce imi mai trebuie?
Go BIG or go HOME
#42 Useril este offline   Florin1up
  • Postari: 132
Postat 15 March 2011 - 11:57 PM
pai pune-le cate o rezistenta de limitare a curentului si nu se vor mai arde. Incearca cu una de 100 ohmi daca le alimentezi la 5v sau cu una de 470 ohmi daca le pui la 12.
azi mi-am montat racire pe motor; am modificat un radiator de laptop (de cupru). O sa vad daca mai e necesar ventilator. Deocamdata tre sa-mi cumpar planetara fata :pardon:
Imagine atasata: IMG_7388.JPGImagine atasata: IMG_7389.JPG
#43 Useril este offline   Florin1up
  • Postari: 132
Postat 22 March 2011 - 09:48 PM
Am si eu nevoie de niste planetare dar ceva mai bun decat cele stock.. mi se rup mereu, probabil din cauza cuplului si a uzurii.
http://www2.gpmd.com.../t/trac6859.jpg
Asa arata cele originale. Stie cineva daca se gasesc metalice? dar nu bonehead.
Multumiri.
Am montat supape la amortizoare, pentru rebound. (revenire lenta)
Se simte diferenta la offroad, este mult mai controlabila. :D
#44 Useril este offline   Florin1up
  • Postari: 132
Postat 30 June 2011 - 11:35 PM
update-uri: protectii noroi amortizoare, planetare otel fata (CVD), revizie completa si inlocuit oring-uri la diferentiale + ulei nou, si inlocuit supape din amortizoare :ph34r:
  • Imagine atasata: DSCN0599.jpg
  • Imagine atasata: DSCN0597.jpg
#45 Useril este offline   Florin1up
  • Postari: 132
Postat 30 June 2011 - 11:41 PM
..si un filmulet facut cu camera montata pe masina, si alta cu filmare slow motion :ph34r:
#46 Useril este offline   lamav4
  • Postari: 1133
  • Inregistrat: 19-May 10
Postat 01 July 2011 - 08:29 AM
Mai adaugati inca un membru pe lista :good: Pede 2wd
Imagine atasata: IMG00189-20110701-0918.jpg
Imagine atasata: IMG00185-20110624-2028.jpg
Imagine atasata: IMG00183-20110624-2028.jpg
Imagine atasata: IMG00182-20110624-2027.jpg
Aceasta postare a fost editata de lamav4: 01 July 2011 - 08:30 AM
Fan Nokia.
#47 Useril este offline   davidd
  • Postari: 371
Postat 01 July 2011 - 11:06 AM
jos palaria pentru filmare :good:
0742128727
#48 Useril este offline   gabyshor
  • Postari: 80
  • Inregistrat: 03-October 07
Postat 10 August 2011 - 09:43 AM
Vezi postareadavidd, la 01 July 2011 - 11:06 AM, a spus:
jos palaria pentru filmare :D
vreau sa-mi iau si eu asa ceva. cum e in comparatie cu slash ultimate 4x4?
suspensia pare f moale, cum se piloteaza pe asfalt sau drum mai bun? nu pentru asta il iau, dar probabil o sa-l folosesc si pe strada.
il vreau doar pt distractie, nu pentru concursuri.
slash mi se pare prea orientat spre drumuri bune.
#49 Useril este offline   Ady.
  • Postari: 1141
  • Inregistrat: 06-May 09
Postat 22 August 2011 - 01:24 PM
Salut, de unde ai luat radiatorul ala de la motorul velineon?
#50 Useril este offline   Florin1up
  • Postari: 132
Postat 07 January 2012 - 08:11 PM
Vezi postareaAdy., la 22 August 2011 - 01:24 PM, a spus:
Si-a mai luat cineva stampede 4x4? :rolleyes:
ADY: Radiatorul a fost facut dintr-un radiator de laptop, cu ceva munca.. intre timp mi-am cumparat planetare de otel si pe spate..au costat "o avere" toate 4 (~400 ron)
mai nou i-am montat si turbina :drinks: (cooler adica) O sa revin cu poze
PS. scz intarzierea de cateva luni ady.
#51 Useril este offline   Florin1up
  • Postari: 132
Postat 08 January 2012 - 10:09 PM
Nu mai las neastupate gaurile de la roti niciodata. Am scos o "roaba" de nisip din ele :). Intreba cineva cum vin planetarele de otel pe stampede...
  • Imagine atasata: DSCN2972.jpg
  • Imagine atasata: DSCN2973.JPG
#52 Useril este offline   Florin1up
  • Postari: 132
Postat 29 December 2013 - 09:19 PM
Ma supara faptul ca prinsese joc din toate incheieturile. Asa ca am reusit sa pun bucsi de bronz grafitat cu tije de otel, toate recuperate din unitati optice de laptop. Nici noua n-a fost asa inchegata. Eu cred ca am facut o treaba buna, o sa vad in timp cum rezista. Am pus bucsi la articulatia sasiu-bascula si bascula-fuzete (spate). Fuzetele fata mai au ceva joc, dar alea cred ca le inlocuiesc.
  • Imagine atasata: 5.jpg
  • Imagine atasata: 1.jpg
  • Imagine atasata: 3.jpg
  • Imagine atasata: 6.jpg
  • Imagine atasata: 7.jpg
  • Imagine atasata: 8.jpg
#53 Useril este offline   hamsterik
  • Postari: 311
  • Inregistrat: 05-November 10
  • Interests:Automodelism , offroad,
    onroad/drifting.
    Ciclism XC.
Postat 30 December 2013 - 06:30 PM
Imi place ideea bucselor , singura problema ar fi frecarea mai mare decat pe plastic.
Edit: Acum am vazut ce fel de bucsi sunt , deci probabil va fi ok.
Aceasta postare a fost editata de hamsterik: 30 December 2013 - 06:30 PM
Auto : Hpi firestorm flux.
Navo : Homemade.
Aero : Piper J3 cub.
#54 Useril este offline   Florin1up
  • Postari: 132
Postat 30 December 2013 - 09:29 PM
Crede-ma este foarte ok. Pentru asta sunt facute. In anumite conditii se comporta mai bine decat rulmentii; vibratiile nu le distrug
#55 Useril este offline   hamsterik
  • Postari: 311
    onroad/drifting.
    Ciclism XC.
Postat 31 December 2013 - 04:08 AM
Axurile de la bascule sunt aceleasi? Cat despre plastic , a fost gaurit ca sa intre sau cum ai procedat? Ma tenteaza sa desfac ceva unitati optice.
Navo : Homemade.
#56 Useril este offline   Florin1up
  • Postari: 132
Postat 31 December 2013 - 09:34 AM
am inlocuit axul si l-am taiat la dimensiunea potrivita, cele originale sunt mai groase putin si oricum aratau rau.
Si da, am gaurit peste tot unde am pus bucsi, altfel nu intra si riscam sa sparg bucsa.
Vezi ca sunt si optice care nu au bucsi la mecanismul optic. Cele de desktop mai ales merg pe plastic direct :)
33 useri citesc topicul
0 membri, 33 vizitatori, 0 utilizatori anonimi
