Modelism - RHC Forum: Fox Fiberglass 1.5m - Modelism - RHC Forum
Fox Fiberglass 1.5m from hobbyking
#1 Useril este offline   silver arrow
  • Postari: 635
  • Inregistrat: 14-July 09
Postat 27 December 2010 - 02:51 PM
http://img27.imageshack.us/img27/1995/pict0010po.jpg
Pana sa-l puna mosul sub brad, foxul a parcurs cateva etape in asamblare. Asa ca o sa incep cu inceputul.
Spec.
Type: Fox Aerobatic Glider
Construction: (Fuse=Fiberglass) (Wings=Balsa & CF-Spar)
Wingspan: 1.5m
Length: 780mm
Channels: 3
Motor: 29mm Diameter
Battery: =>1300mah
Servo: 9~20g 32x12mm
ARF Weight: 480g (kit only)
Calitativ kitul arata foarte bine, aripile nu au nicio cuta. Prinderea aripilor este eficienta, asta dupa ce va obisnuiti sa puneti arcul. Daca uitati penseta acasa mergeti degeaba la camp. Nu are directie, insa eu cred ca suprafata mare a eleroanelor va compensa lipsa acesteia.
#2 Useril este offline   silver arrow
  • Postari: 635
Postat 27 December 2010 - 02:56 PM
Prinderea aripilor:
Fisier atasat  P101210_17.28.jpg (120.12K)
Number of downloads: 32 Fisier atasat  P111210_08.56.jpg (154.78K)
#3 Useril este offline   silver arrow
  • Postari: 635
Postat 27 December 2010 - 02:59 PM
Montarea ampenajului orizontal:
Fisier atasat  P101210_17.28__01_.jpg (149.54K)
Number of downloads: 23 Fisier atasat  P111210_08.56__01_.jpg (135.12K)
Number of downloads: 23 Fisier atasat  P111210_08.57.jpg (133.77K)
#4 Useril este offline   silver arrow
  • Postari: 635
Postat 27 December 2010 - 03:45 PM
Tija originala am inlocuit-o cu o tija de alama protejata de o teava de carbon pentru a nu flamba.
Fisier atasat  PICT0013.JPG (125.91K)
Number of downloads: 24 Fisier atasat  PICT0014.JPG (110.8K)
Number of downloads: 22 Fisier atasat  PICT0015.JPG (116.16K)
Number of downloads: 22 Fisier atasat  PICT0023.JPG (124.59K)
Aceasta postare a fost editata de silver arrow: 27 December 2010 - 03:46 PM
#5 Useril este offline   silver arrow
  • Postari: 635
Postat 27 December 2010 - 04:04 PM
Echipare:
-motor Turnigy 2217 16turn 1050kv 23A Outrunner,
-esc Turnigy plush 25A,
-lipo 3s 1300mAh 25c,
-3 x hxt900,
-rx hitec optima 7,
-con turbo de 30mm,
-pale robbe dynamic 10x6.
Fisier atasat  P101210_17.27.jpg (161.72K)
Number of downloads: 24Fisier atasat  PICT0019.JPG (158.41K)
Montarea motorului:
Fisier atasat  PICT0017.JPG (111.38K)
#6 Useril este offline   silver arrow
  • Postari: 635
Postat 27 December 2010 - 04:07 PM
Fisier atasat  P111210_08.59.jpg (153.29K)
Number of downloads: 13Fisier atasat  PICT0018.JPG (149.65K)
Number of downloads: 13 Fisier atasat  P101210_17.30.jpg (128.51K)
#7 Useril este offline   silver arrow
  • Postari: 635
Postat 27 December 2010 - 04:15 PM
Programarea esc-ului:
Fisier atasat  PICT0021.JPG (147.47K)
Fisier atasat  PICT0024.JPG (142.53K)
Fisier atasat  PICT0022.JPG (141.22K)
#8 Useril este offline   pccdtk
  • Postari: 1747
  • Inregistrat: 09-June 02
Postat 27 December 2010 - 07:40 PM
Frumos !!! Deabia astept continuarea !!!
#9 Useril este offline   silver arrow
  • Postari: 635
Postat 27 December 2010 - 07:52 PM
Multumesc de aprecieri. :D
Problema apare la carlinga. Singurul lucru inclus in kit este cupola de plastic. Daca aveti idei referitoare la realizarea acesteia sau detalii despre cockpitul unui fox adevarat va sunt recunoscator. :D
Ps sper ca la final sa arate asa http://www.google.ro/url?sa=t&source=w..._cy3Pcq16VdkGJQ
Aceasta postare a fost editata de silver arrow: 27 December 2010 - 07:58 PM
#10 Useril este offline   silver arrow
  • Postari: 635
Postat 29 December 2010 - 03:29 PM
Alte cateva poze din constructie: :)
Fisier atasat  PICT0025.JPG (153.19K)
Fisier atasat  PICT0026.JPG (151.58K)
#11 Useril este offline   silver arrow
  • Postari: 635
Postat 29 December 2010 - 03:37 PM
Si asa arata acum:
Fisier atasat  PICT0027.JPG (149.55K)
Fisier atasat  PICT0028.JPG (126.84K)
Fisier atasat  PICT0029.JPG (156.34K)
#12 Useril este offline   pccdtk
  • Postari: 1747
Postat 30 December 2010 - 09:42 AM
Cockpitul a inceput sa prinda "forma" foarte frumos . BAFTA !!!
#13 Useril este offline   protheus
  • 日本語
  • Postari: 1719
  • Inregistrat: 26-August 07
Postat 30 December 2010 - 11:19 AM
Arata foarte bine, trebuie sa trec iar sa vad live ce si cum ;) . Totusi, pacat ca nu vrei sa pui un "constipat" pe unul din scaune.
Cu "geamul" cum a ramas? Ce mai schimbi si pe la el, sa fie in pas cu cockpitul? Ceva dunga pe la mijloc, bordura? Manere? :lol:
Aceasta postare a fost editata de protheus: 30 December 2010 - 11:24 AM
#14 Useril este offline   pavcostel
  • Postari: 1596
Postat 30 December 2010 - 05:42 PM
Da' tija originala ce avea?? Acolo ai nevoie de o tija zdravana de otel, GREA, nu de ceva usor si shic... Sa-l zbori cu placere si aterizari cu bine!
#15 Useril este offline   silver arrow
  • Postari: 635
Postat 30 December 2010 - 08:12 PM
Multumesc de urari. Cupola de plastic va fi ultima cosmetizata, intai trebuie sa termin interiorul. :)
Alte poze:
Fisier atasat  PICT0034.JPG (148.04K)
Number of downloads: 28 Fisier atasat  PICT0030.JPG (152.46K)
Number of downloads: 28 Fisier atasat  PICT0041.JPG (144.08K)
#16 Useril este offline   silver arrow
  • Postari: 635
Postat 30 December 2010 - 08:23 PM
Vezi postareapavcostel, la Dec 30 2010, 05:42 PM, a spus:
Tija cu care a venit este din otel de 2mm. Dreapta, avea frecari prea mari, iar cand am indoit-o putin in S flamba foarte tare. E prea groasa ca sa o trec prin tub de plastic, asa ca asta este solutia:
Fisier atasat  PICT0043.JPG (43.18K)
Linia neagra e carbon, cea verde e tub de plastic iar prin ele trece o tija de alama de 1mm. :)
#17 Useril este offline   ilie F1A
  • Postari: 1249
  • Inregistrat: 17-April 09
Postat 01 January 2011 - 06:10 PM
Frumos modelul.Zboruri reusite. Din ce tara a sosit mosul cu el? Se pare ca mai are un frate la Alba Iulia care deja zboara.Numai bine.
#18 Useril este offline   silver arrow
  • Postari: 635
  Postat 01 January 2011 - 06:27 PM
Multumesc de urari. Mosul a venit din Hong Kong, scrie si in titlul topicului <_< . Invit fratele din Alba Iulia sa posteze si el. As fi interesat de un filmulet si de CG daca se poate. ;)
Fisier atasat  PICT0047.JPG (137.63K)
Number of downloads: 13Fisier atasat  PICT0045.JPG (139.28K)
#19 Useril este offline   Adi-GVA
  • Postari: 739
Postat 01 January 2011 - 07:02 PM
Nu avem acelasi model. Al meu este din elapor, e un pic mai mare si e facut de Hype.
Am facut si un kit review. Aveti o gramada de informatii aici:
http://www.rhcforum....showtopic=32309
Acum sunt foarte multumit de el.
Fly Extreme! __EXTREME FLIGHT
#20 Useril este offline   ilie F1A
  • Postari: 1249
Postat 03 January 2011 - 06:17 PM
La multi ani! Scuze pentru neatentie,am vazut ca aveti acelasi nume de familie [FOX]si am considerat ca sunteti frati,totusi zic eu, ca sunteti doi frati vitregi unul mai mare si celalalt mai mic.Principal este sa va bucurati cat mai mult de zborul lor. Numai zboruri reusite.
#21 Useril este offline   silver arrow
  • Postari: 635
  Postat 03 January 2011 - 07:46 PM
Multumesc, La multi ani si aterizari line tuturor!
Cateva poze la "firu' ierbii"
Fisier atasat  PICT0049.JPG (340.83K)
Number of downloads: 30 Fisier atasat  PICT0051.JPG (104.25K)
#22 Useril este offline   silver arrow
  • Postari: 635
Postat 03 January 2011 - 07:48 PM
Fisier atasat  PICT0053.JPG (94.98K)
Number of downloads: 16 Fisier atasat  PICT0050.JPG (307K)
7 useri citesc topicul
