Modelism - RHC Forum: turbina kinktech k80 E - Modelism - RHC Forum
turbina kinktech k80 E stare f buna
#1 Useril este offline   Iamzoli
  • Postari: 815
  • Inregistrat: 08-January 10
Postat 09 October 2010 - 06:47 AM
vand turbina Kingtech k80 E achizionata in martie 2010 in stare f buna +accesorii upgradate
Diameter: 3-3/4"
Length: 10" (including starter)
Weight: 2 lb. 14oz. (including starter)
Maximum RPM: 145000
Thrust: 19 lb. @ 70 F.
Idle: 45000rpm
Exhaust temperature: 650 C max
Fuel consumption: 8.46 oz/min
Maintenance cycle: 25 hr
Oil: 5%
Timp total functionare: 6:50h
Combustibil:kerosen / motorina
nu am ce sa zic despre ea decat ca este o turbina f buna (am fost si sunt f multumit de ea)
da vreti pareri despre ea cititi aici http://www.rcgroups.com/forums/showthread....8859&page=6
ce spune Mart C...,unul dintre guru in turbine de pe rcgroups
the K80 in my opinion anyway is extremely well made and reliable. I would say also its probably at present anyway the best value for dollar comercially available full auto start turbine currently on the market.Put it this way I think your definetely not going to be dissapointed with the Kingtech... and at the end of the day thats probably the telling difference
Pret 1149 EUR
Pachetul contine
1 buc turbina k80E
1 buc ECU (original)
1 buc Terminal Ecu (original)
1 buc baterie nicad ptr turbina (baterie JETCAT)
1 buc pompa kerosen (schimbata cu una Flightworks Turbojet cea originala crea probleme 140 $)
1 buc e-valva kerosen (schimbata cu una de la Jet Tronics 55 eur)
1 buc e-valva gas (originala nu am avut probleme)
1 buc regulator gaz (29 de eur)
1 buc filtru kerosen
1 buc valava gaz sigura directie (9 eur)
furtune de 3mm gaz,4 mmm kerosene ,conector festo si pisco in valoare aprox de 50 de eur
1 buc manual
Deci tot ce ai nevoie ptr a utiliza turbina si a o zbura
turbina se poate testa dau si test standu daca cumparator opteaza sa o ridice personal
optional : 1 buc stingator c02 tip g2 + 2 recipiete noi gaz pornite turbina +1 unul pe jumate golit la 150 de ron (noi ar fi 270 de ron), le dau ca nu mai am ce face cu ele
am incercat sa fac un filmultez da nu prea a iesit ,vizualizati in hd ptr o calitate mai buna
am crezut ca sa oprit camera din greseala si am mai incercat odata cand defapt se pare ca din cauza zgomotului camera decupleaza weird da na asta e
0744625950
Fisier atasat  IMG_3968.JPG (100.07K)
....in Thrust we trust....
Flying Vampires Arad
#2 Useril este offline   MLGore
  • Dream Team Forever
  • Postari: 2332
  • Inregistrat: 08-March 04
Postat 09 October 2010 - 01:57 PM
Vreau eu stingatorul si buteliile de gaz daca le dai separat. Sambata viitoare sunt in Arad.
#3 Useril este offline   Iamzoli
  • Postari: 815
Postat 09 October 2010 - 04:02 PM
Buna domnule din pacate nu pot sa le dau separat din urm motive
1) daca reusesc sa o dau si omu vrea sa o testez live imi trebuie stingatorul just in case
2) poate omu vrea sa cumpere stingatorul si gazul cu tot cu turbina
daca dau turbina si ramane stingatorul vei fi primul pe care il contactez si desigur pot sa ti le tin.
Apropo vezi ca la Siria pista e arata numai ca zbori de pe drum , daca e vreme buna si vrei sa zbori da un tel si poate iesim undeva
te salut
#4 Useril este offline   Iamzoli
  • Postari: 815
Postat 23 October 2010 - 09:09 AM
up
#5 Useril este offline   Iamzoli
  • Postari: 815
Postat 04 December 2010 - 10:19 AM
criza... 1099 EUR
#6 Useril este offline   Iamzoli
  • Postari: 815
Postat 11 December 2010 - 09:22 AM
up...
#7 Useril este offline   Iamzoli
  • Postari: 815
Postat 18 December 2010 - 11:39 AM
up..
#8 Useril este offline   Iamzoli
  • Postari: 815
Postat 22 January 2011 - 12:15 PM
up...
#9 Useril este offline   Iamzoli
  • Postari: 815
Postat 05 February 2011 - 10:55 AM
up...
#10 Useril este offline   Iamzoli
  • Postari: 815
Postat 05 November 2013 - 01:10 PM
Din nou la vanzare 899 EUR
- 740 de min / 12.3 H
- turbina ramane pe stand in caz ca doreste cumparatorul un start live inainte
- in schimbul platii combustibilului ma pot deplasa 200 km spre cumparator
#11 Useril este offline   Iamzoli
  • Postari: 815
Postat 17 November 2013 - 08:43 AM
849 EUR
#12 Useril este offline   Iamzoli
  • Postari: 815
Postat 23 November 2013 - 10:44 AM
black friday saturday all year :D 749 EUR Limited Offer :D
#13 Useril este offline   fly
  • Postari: 3415
  • Inregistrat: 09-November 08
  • Interests:Jeturi ,f3j ,f5j
Postat 24 November 2013 - 10:48 AM
O turbina excelenta ca si pretul dealtfel , :D
#14 Useril este offline   fly
  • Postari: 3415
Postat 24 November 2013 - 11:27 AM
Am vazuto zburand si este de calitate foarte buna ,porneste usor si fara probleme ,la acest pret va fi foarte greu de gasit o alta turbina.este foarte buna pentru inceput :drinks:
#15 Useril este offline   Iamzoli
  • Postari: 815
Postat 15 December 2013 - 12:03 PM
UP
#16 Useril este offline   Iamzoli
  • Postari: 815
Postat 21 December 2013 - 09:45 AM
up
4 useri citesc topicul
