Modelism - RHC Forum: LEVIOSA F3A 2x2m - Modelism - RHC Forum
LEVIOSA F3A 2x2m model de competitie
#1 Useril este offline   Cataero
  • Postari: 325
  • Inregistrat: 14-September 06
Postat 20 September 2010 - 10:23 PM
Leviosa Pro / F3A Lorenz
fuselaj - composite/ aripi si profundor - foam with balsa.
anvergura 1840 mm
lungime 1990 mm
masa RTF 4,75 Kg
setup:
motor OS 160 FX
gat F3A Lorenz
rezonator Webra
soft mount Budd Engineering
nose ring
APC 17x12
con composite
Digi Switch PowerBox Systems
pompa Perry
needle valve actionata de servo separat
servo eleron 2x Futaba S9551 low profile
servo elevator 2 x Futaba S9650
servo directie 1x Futaba BLS 451 brushless
servo throttle 1 x Hitec HSG 5084 MG
pret: 1300 Euro
#2 Useril este offline   Cataero
  • Postari: 325
Postat 20 September 2010 - 10:24 PM
#3 Useril este offline   Cataero
  • Postari: 325
Postat 20 September 2010 - 10:25 PM
#4 Useril este offline   oachidori
  • F22 Raptor Fan
  • Postari: 2391
  • Inregistrat: 05-August 09
Vezi postareaCataero, la Sep 20 2010, 11:24 PM, a spus:
Asta e cel zburat la Sirna? :rolleyes:
Olivian Diaconescu
Radio:
Multiplex Royal Pro 16 2.4GHz
Aero:
FREEWING - F22 Xicoy X45 Jet
ROBBE - Mistral 2.0m
F22 depron
AERONAUT - Triple RES 2.0m
Auto:
TRAXXAS - E Revo 1/16
ARRMA - Typhon 6S
#5 Useril este offline   Cataero
  • Postari: 325
Postat 20 September 2010 - 10:35 PM
Da, este modelul cu care am concurat la CN F3A 2010.
#6 Useril este offline   Cataero
  • Postari: 325
Postat 05 October 2011 - 07:30 PM
1000 Euro. adica 50% din cat m-a costat.
  • R.D.
  • Postari: 5482
Postat 05 October 2011 - 08:55 PM
Nu as vrea sa deranjez... pe mine m-ar interesa DigiSwitch-ul !
Dar nu sa il cumpar ci sa il impumut pentru o vreme daca se poate .... n-as putea spune inca pentru cat timp ...
Multumesc anticipat !
P.S.
Nici pompa Perry nu e rea la casa omului .
Aceasta postare a fost editata de REAL DESIGN: 05 October 2011 - 08:57 PM
#8 Useril este offline   ERASER
  • Vintage
  • Postari: 2256
  • Inregistrat: 23-March 03
  • Interests:F3A , veliere
Postat 06 October 2011 - 07:36 AM
Salutare,
Ofer 250 Euro pe aeromodel + servo eleron 2x Futaba S9551 low profile + servo elevator 2 x Futaba S9650 + servo directie 1x Futaba BLS 451 brushless, fara motor, elice, digi switch, rezonator, pompa perry.
Datorita Ebay -ului nemtesc, unde configuratia pe care o vinzi se poate lua la 350 - 450 Euro, nu iti pot oferi mai mult chiar daca modelul are palmares si au fost investiti multi bani in el.
Aceasta postare a fost editata de ERASER: 06 October 2011 - 07:39 AM
TEL. 0726.191.725
#9 Useril este offline   wabo1
  • Postari: 1550
  • Inregistrat: 04-August 05
Postat 06 October 2011 - 07:48 AM
Cu 700 ma intereseaza pe mine.
Walter Born
rhc@born.ro
#10 Useril este offline   REAL DESIGN
  • R.D.
  • Postari: 5482
Postat 06 October 2011 - 09:21 AM
Vezi postareaERASER, la 06 October 2011 - 07:36 AM, a spus:
Salutare,
Am rugamintea sa ne dai si noua link-ul de Ebay ca vreau si eu la banii astia ... chiar 2 Buc ( e pomana ) !
Eu nu am gasit cel mai ieftin decat kit-ul pe la vre-o 750-850 Euro si ala neterminat ( nevopsit fuselajul si carlinga, la aripi netaiate eleroanele si neinfoliate, ampenaj orizontal spate la fel , plus ca nu contine nici maruntisurile - tren, con, echii,balamale surubaraie ....- un kit finisat sare de 1.400 Euro doar coaja.
La 350 Euro e super ieftin cam cat un model de balsa banal dar mai maricel putin fara nimic pe el asa ce tentatia e mare .
P.S.
Numai servourile cred ca as putea lua la 250 Euro - cred nu sunt sigur.
P.S. la P.S.
Ca sa nu mai scriem aici ( stricam topic-ul de vanzare ) ori deschidem un topic nou ori p.m.am rugamintea.
#11 Useril este offline   ZOD
Postat 06 October 2011 - 09:45 AM
Salutare,
Esti praf.
#12 Useril este offline   ERASER
  • Vintage
  • Postari: 2256
Postat 06 October 2011 - 11:25 AM
Lazulite de Wolfgang Matt, peste Leviosa ca performante, neechipat s-a dat cu 62 Euro :
http://www.ebay.de/i...984.m1435.l2649
Momentan sunt la vanzare doar doua F3A 2x2m, modele cam de acum 8 - 10 ani, unul cu 100 Euro si altul cu 180 Euro.
http://www.ebay.de/i...=item1c1f73853c
http://www.ebay.de/i...=item2eb83aafec
Pe la 350 - 450 apar modele mai noi din categoria Leviosa , Otop , Smaragd , Tojeiro, Synergy
Aceasta postare a fost editata de ERASER: 06 October 2011 - 11:29 AM
TEL. 0726.191.725
  • R.D.
  • Postari: 5482
Postat 06 October 2011 - 11:54 AM
Mda ... ceva nu inteleg : adica Raven-ul urmator costa doar 100 si ceva de euro cu elice carbon tripala, con carbon, cu motor boxer , cu servourile precizate etc etc .... nu cred.
http://www.ebay.de/i...550837780479068
Habar nu am germana asa ca .... dar oricum ceva e putred in Danemarca ..
P.S.
Iar un model de 10 ani .... merci nici cadou nu il vreau .
Eu vroiam unul identic Leviosa din topic ca performante de zbor , design, etc.
Aceasta postare a fost editata de REAL DESIGN: 06 October 2011 - 11:58 AM
#14 Useril este offline   ZOD
Postat 06 October 2011 - 02:03 PM
Vezi postareaERASER, la 06 October 2011 - 11:25 AM, a spus:
Tu glumesti nu ? Spune-mi ca glumesti ... Nu vezi nicio diferenta intre LEviosa si genesis .... zero diferente .. ti se pare ca sunt acelasi lucru.
Sau ala Karat ( http://www.ebay.de/i...=item1c1f73853c) nu observi nicio diferenta ?
Pe asta de pe Ebay l-ai ratat ?
http://www.ebay.de/i...=item4a9e02a0a4
1650 de euro.... te rog frumos pune mana si spune-i si lui ca genesis e mai eftin..
Io Otop pe ebay.de nu am gasit si nici Leviosa .
Eu cred ca minti.
#15 Useril este offline   ZOD
Postat 06 October 2011 - 02:04 PM
Vezi postareaREAL DESIGN, la 06 October 2011 - 11:54 AM, a spus:
P.S.
Gigi ... licitatia incepe de la 100 si ceva ....are un prag sub care nu il da..
#16 Useril este offline   wabo1
  • Postari: 1550
Postat 06 October 2011 - 02:12 PM
STERGETI toate astea, si opriti i va sa incurcati vinzarea articolului.
Pretul oferit este cit sa poate de corect si lasati pe cei care cred ca stiu mai bine sa aduca din Germania modelul cu 300 eur cost de transport :)
Aceasta postare a fost editata de wabo1: 06 October 2011 - 02:14 PM
Walter Born
rhc@born.ro
#17 Useril este offline   REAL DESIGN
  • R.D.
  • Postari: 5482
Postat 06 October 2011 - 02:13 PM
Vezi postareaZOD, la 06 October 2011 - 02:04 PM, a spus:
Stiu ZOD ... dar imi era jena sa ii spun lui Eraser direct ca oferta facuta de el e de fapt ori o gluma ori ..... o "scapare".
Am spus asa mai pe ocolite ca de banii aia nici servourile si conu nu poate sa le ia si de aia rugasem sa deschida un topic separat sau sa "vorbim" pe p.m.
Doar o singura verificare pe site-ul lui Lorenz si se lamurea problema preturilor :
http://www.f3alorenz...ex-home-f3a.htm
Iar de aici rezulta un singur lucru : ori nemtii au luat-o razna din cauza crizei ori Lorenz e rupt de realitate.
#18 Useril este offline   ZOD
Postat 06 October 2011 - 03:21 PM
Vezi postareawabo1, la 06 October 2011 - 02:12 PM, a spus:
Ai dreptate .
#19 Useril este offline   Cataero
  • Postari: 325
Postat 06 October 2011 - 05:55 PM
Imi pare rau, dar ultimul pret afisat nu este negociabil.
Avionul este intr-o stare foarte buna, bine lucrat, fara crash sau alte defecte.
Si foarte important: a demonstrat ca are un comportament de zbor precis.
#20 Useril este offline   REAL DESIGN
  • R.D.
  • Postari: 5482
Postat 06 October 2011 - 06:24 PM
Vezi postareaCataero, la 06 October 2011 - 05:55 PM, a spus:
Aaaa ! Este super ! Amabil ca intotdeauna si maxima promptitudine !
Atunci te astept in 1-2 zile cu digi-switch-ul si pompa Perry !
Multumesc tare mult .
Aceasta postare a fost editata de REAL DESIGN: 06 October 2011 - 06:25 PM
#21 Useril este offline   Cataero
  • Postari: 325
Postat 01 January 2012 - 06:36 PM
UP!
#22 Useril este offline   zigotu
  • Postari: 231
  • Inregistrat: 29-June 09
Postat 14 April 2012 - 04:27 PM
mai e valabil anuntul?
6 useri citesc topicul
