Modelism - RHC Forum: dg1000 de la hobbyking - Modelism - RHC Forum
#31 Useril este offline   Airflow
  • Postari: 173
  • Inregistrat: 05-December 08
Postat 10 June 2010 - 06:53 PM
Vezi postareapetrutviulet, la Jun 10 2010, 07:49 AM, a spus:
neata!
directia este partea mobila a ampenajului vertical
iar deriva este partea fixa
daca gresesc ,va rog sa ma corectati
Eh era un pic de ironie fiindca in poza postata nu se prea distinge nimic http://www.rhcforum....tyle_emoticons/default/smile.gif
Don't drink and drive, smoke weed and FLY.
Postat 10 June 2010 - 06:57 PM
Atat cat se vede, mie mi se pare corectabila cu trim, nu as mai despica... deriva in doua
Aceasta postare a fost editata de renatoa: 10 June 2010 - 06:59 PM
#33 Useril este offline   petrutviulet
  • Postari: 331
  • Inregistrat: 04-August 07
  Postat 11 June 2010 - 06:17 PM
seara buna!
iata si ceva poze cu impricinatii :)
SA NE AJUTE DOMNUL SA ATERIZAM...CU BINE!!!HI HI HI!!!
#34 Useril este offline   petrutviulet
  • Postari: 331
Postat 15 June 2010 - 06:23 AM
neata!
ei,am ajuns la motorizare
stie cineva ce motor ar fi bun?
#35 Useril este offline   renatoa
Postat 15 June 2010 - 07:30 AM
Socotitoarea zice ca daca il scoti la 1500 grame gata de zbor, si il alimentezi din 3s, optimul ar fi un 640kv cu elice de 14*10, ESC 40A. In conditiile acestea ai avea:
Minimum Battery Capacity: 1500 mAh, 20 C, lithium polymer.
Suggested ESC Rating: 33 A to 39 A.
Power Into / Out of Motor: 324.0 watts in / 243.0 watts out.
Power To Weight Ratio: 216.00 watts/kg.
Estimated Stall Speed: 32.7 km/hr.
Wing Loading: 52.6 gm/dm2.
Cubic Wing Loading: 4.1 gm/dm3.
1600gr thrust @ 5177 RPM, 79kmph
Ca sa fie alternativa si cu o elice mai mica: 860kv, 12*8, 1482gr thrust @ 6955 RPM, 85kmph
Motoare apropiate:
http://www.hobbycity.com/hobbyking/store/u...?idProduct=7074
Aceasta postare a fost editata de renatoa: 15 June 2010 - 07:36 AM
#36 Useril este offline   petrutviulet
  • Postari: 331
  Postat 15 June 2010 - 02:50 PM
Vezi postarearenatoa, la Jun 15 2010, 08:30 AM, a spus:
Motoare apropiate:
ziua buna!
multam de respuns!
eu am un flyermate 3s 3300mah cu 20c
si o elice plianta de asw15 este 9x5
bune?
are cineva si un manual al planorului?
#37 Useril este offline   danny_39
  • Postari: 2022
  • Inregistrat: 06-September 06
Postat 15 June 2010 - 03:04 PM
Vezi postareapetrutviulet, la Jun 15 2010, 03:50 PM, a spus:
Vezi daca e ceea ce iti trebuie.
http://webcache.googleusercontent.com/sear...=clnk&gl=ro
Toate aeromdelele sant iubite de Terra,diferenta o face viteza cu care se apropie...sau o face tipul ala cu statia?
Postat 15 June 2010 - 03:06 PM
Vezi postareadanny_39, la Jun 15 2010, 04:04 PM, a spus:
Glumesti? :rolleyes:
Alea sunt de la planorul DG1000 1:1, cel mare http://www.rhcforum....tyle_emoticons/default/smile.gif)
Merge cu 9*5, cu un motor de 1400-1500 kv, dar lesinat, tractiune de numai 1100-1200grame.
Si motorul in continuare va trebui sa aiba 300w ca in specificatiile initiale, ca sunt multe motoare de 1500kv http://www.rhcforum....tyle_emoticons/default/wink.gif
Aceasta postare a fost editata de renatoa: 15 June 2010 - 03:11 PM
#39 Useril este offline   danny_39
  • Postari: 2022
Postat 15 June 2010 - 03:43 PM
Vezi postarearenatoa, la Jun 15 2010, 04:06 PM, a spus:
Glumesti? http://www.rhcforum....tyle_emoticons/default/smile.gif
Alea sunt de la planorul DG1000 1:1, cel mare :D)
Si motorul in continuare va trebui sa aiba 300w ca in specificatiile initiale, ca sunt multe motoare de 1500kv :rolleyes:
Upss, am gresit link-ul,sa il caut pe cel bun.. http://www.rhcforum....tyle_emoticons/default/blink.gif
#40 Useril este offline   MaDsHaRk
  • Postari: 286
  • Inregistrat: 27-August 05
Postat 16 June 2010 - 03:17 PM
Eu am avut pe el motor 3548-06 de la Roxy si elice 12x6 pale de carbon si con de aluminiu.Regulator de 60 A acumulator lipo 3s unu de 2200 care se cam incalzea si unu de 3300 cu care mergea fara probleme.
#41 Useril este offline   Rhaoul
  • Postari: 543
  • Inregistrat: 17-March 09
  • Interests:Jocurile de noroc si alcoolul :)
Postat 16 June 2010 - 06:03 PM
Vezi postareadanny_39, la Jun 15 2010, 04:43 PM, a spus:
Upss, am gresit link-ul,sa il caut pe cel bun.. :blink:
Ii dau eu un motor 1250 Kv si un accu de 190 g de 4200 3 S ... Merge ?
Avioane
YaK 54 2.7m Wing Spam - DLE 111 cc Under Construction
T50 EDF 70mm
Easy Glider Pro RTF
ACROMaster RTF
TELINK YAK 54 RTF
Heli
Ornith 7.5 cc RTF
SJM 325 SE - RTF
Ornith-TReX 600 8.5 cc ARTF
#42 Useril este offline   petrutviulet
  • Postari: 331
  Postat 21 June 2010 - 07:00 PM
seara buna,tovarasi!!!
rhaoul,nu stiu ce stie motorul
am ajuns la servouri...
pt eleroane pot sa folosesc as 100 si pt elevator as170?
pe astea le am...
pt directie am unul standard,gata instalat
#43 Useril este offline   petrutviulet
  • Postari: 331
  Postat 23 June 2010 - 08:53 AM
Vezi postareapetrutviulet, la Jun 21 2010, 08:00 PM, a spus:
pe astea le am...
ceva idei?
:lol:
#44 Useril este offline   draude80
  • Postari: 273
  • Inregistrat: 25-August 09
  • Interests:Aero, FPV
Postat 23 June 2010 - 09:07 AM
Vezi postareapetrutviulet, la Jun 23 2010, 09:53 AM, a spus:
ceva idei?
:lol:
AS 100 am si eu .......sunt foarte slabe si ar fi pacat sa se strice in timpul zborului!!
#45 Useril este offline   djandrey
  • Postari: 600
  • Inregistrat: 15-June 09
  • Interests:Automodelism , Aeromodelism , IT
Postat 25 June 2010 - 09:02 AM
Macar un sg90 .
ON-AIR
TX : Spektrum DX9
ParkZone VisionAire - Electric
F3P Mustang 3D - Electric
Multiplex Twister EDF - Electric
OFF-ROAD
Traxxas TRX4 4WD - Electric
#46 Useril este offline   petrutviulet
  • Postari: 331
  Postat 19 August 2010 - 10:08 AM
ziua buna!
am reusit sa repar botul si zona de fuselaj din dreptul derivei
am folosit fibra de carbon
urmeaza si poze
#47 Useril este offline   petrutviulet
  • Postari: 331
Postat 22 August 2010 - 07:35 PM
Vezi postareapetrutviulet, la Aug 19 2010, 10:08 AM, a spus:
ziua buna!
urmeaza si poze
iatasi imagini
http://www.youtube.c...h?v=fSG5vfohkA0
astept si sugestii
8 useri citesc topicul
