Modelism - RHC Forum: Modele deosebite - Modelism - RHC Forum
  • 24 Pagini +
  • 18
  • 19
  • 20
  • 21
  • 22
Modele deosebite Viitoarele noastre proiecte ?
#571 Useril este offline   dan_mitea
Postat 02 March 2009 - 06:47 AM
Cu dedicatie pentru Kriminel:
http://rcuvideos.com...-3-Piper-Cub-Vi
Un Piper 1:2 care face nastrusnicii...
#572 Useril este offline   Calin
  • Postari: 2468
  • Inregistrat: 11-June 07
Postat 02 March 2009 - 08:23 AM
Multumesc! Fara numar fara numar! http://www.rhcforum....tyle_emoticons/default/smile.gif
Pilotul meu favorit e Bill Hemple, acesta pare Piperul sau dar nu sunt covins. Daca cautati pe youtube Bill Hemple 1/2 Piper cup veti vedea ce nastrusnicii poate face el cu acest avion "greu de zburat" :)
Numai bine,
Calin
#573 Useril este offline   Dexter_Jr
Postat 02 March 2009 - 10:58 AM
Vezi postareaDexter_Jr, la Jan 29 2009, 03:35 PM, a spus:
How to properly fly a J-3 Cub http://www.youtube.c...h?v=M7DiToPWgTk
Caline de asta zici?
#574 Useril este offline   Calin
  • Postari: 2468
Postat 02 March 2009 - 05:27 PM
da si in filmul ala trage de el, dar nu asa cum trage in filmul asta ;)
#575 Useril este offline   renatoa
Postat 27 March 2009 - 08:56 AM
Ce concept de "biplan" mai e si asta ?!
http://www.rcgroups.com/forums/attachment....hmentid=2421130
Prima oara cand vad asa ceva...
#576 Useril este offline   macsimc
  • Postari: 129
  • Inregistrat: 09-January 08
Postat 27 March 2009 - 09:36 AM
vezi mai multe detalii aici http://www.rcgroups....ad.php?t=715020 , aici este un 'plan' http://www.rcgroups.com/forums/showthread....hlight=twinwing .
Gasisem si niste detalii tehnice acu vreo doua luni dar acu nu le mai gasesc.
Twinwing because ; Like a biplane, a lot of area in a compact size, but shorter/lighter fuselage than a bipe ; interaction of flows between wings enables higher angles of attack before stall, so higher lift co-efficient = slower flight posiible ; useful for taking pics/video, and easier take-off/landing.Each wing struts the other, so strong airframe using less material than usual ; low induced drag in cruise due to interaction of tip flows ; all in all ideal for UAV/AP, FPV use. Confirmed by wind-tunnel tests, and practical uses.Several hundred have flown.
#577 Useril este offline   renatoa
Postat 02 April 2009 - 08:42 AM
Si un build log al modelului, inceput la 3 zile dupa mesajele de mai sus:
http://www.rcgroups....d.php?t=1025934
#578 Useril este offline   dan_mitea
Postat 21 May 2009 - 05:27 AM
Testul unui ,,motoras'' de 2,2Kw:
http://www.rcuvideos.com/video/Tamjets-Neu...-15153D-Motor-T
Aceasta postare a fost editata de dan_mitea: 21 May 2009 - 05:29 AM
#579 Useril este offline   dan_mitea
Postat 08 June 2009 - 06:54 PM
Un nou competitor pe piata motoarelor brushless. Este vorba de Super Tigre. Si preturile sunt interesante...zic si eu:
http://www3.towerhobbies.com/cgi-bin/wti00...s&search=Go
Aceasta postare a fost editata de dan_mitea: 08 June 2009 - 06:55 PM
#580 Useril este offline   musashi
  • Postari: 7
  • Inregistrat: 19-September 05
Postat 13 June 2009 - 11:39 AM
Buna ziua,
pentru ca topicul era despre proiecte, am indraznit sa scriu si eu .
Pina acum am construit un beaver din depron si sunt la 98 % cu el .
Am dat pe net peste o fotografie de IAR 818 si pot spune ca arata nemaipomenit.
Problema e ca nu am gasit planuri nicaieri,doar citeva vederi care nu par prea exacte.
Va atasez o imagine a impricinatului .
Daca este vre-un membru al forumului care sa aiba mai mult va rog sa ma contactati.
Multumesc :D
  • Fisier atasat  8181.jpg (457.87K)
#581 Useril este offline   uncris
  • Postari: 59
  • Inregistrat: 30-July 08
Postat 13 June 2009 - 10:44 PM
Deocamdata atat.
#582 Useril este offline   lefmir
  • Chupacabra
  • Postari: 724
  • Inregistrat: 14-March 09
  Postat 21 June 2009 - 05:45 PM
Daca o sa trec vreodata pe EDF.... :mellow:
DeHavilland Vampire(plan apropiat), Gloucester Meteor(plan departat)
http://1.bp.blogspot.com/_KgIqQvYUs3I/SBRkQ0_f7sI/AAAAAAAABGI/vDctOd_VFzo/S660/DeHVampire-01,GlosterMeteor.jpg
si Dehavilland Comet...primul jet de pasageri de serie mare...imi place forma aripilor, dar si pozitia motoarelor...
http://www.centennialofflight.gov/essay/Commercial_Aviation/Opening_of_Jet_era/Tran6G1.jpg
daca va referiti la deosebite in sensul de bizare...
Dornier Do335 Arrow
http://www.secondworldwarhistory.com/imgs/do335_pfeil.jpg
si nu in ultimul rand...prea cunoscutul, iubitul, prea bondocul GEE BEE R2(am o slabiciune pentru modelul asta...e prea jucaus pentru binele lui :wub: )
http://acro.aerobaticsweb.org/images/geebee_400x307.gif
Aceasta postare a fost editata de lefmir: 21 June 2009 - 05:54 PM
#583 Useril este offline   dan_mitea
Postat 01 August 2009 - 01:02 AM
Caline, Cub-ul acesta
http://rcuvideos.com...l-Hempel-60-Cub
este pentru sufletul tau.
#584 Useril este offline   degetzica
  • Postari: 152
  • Inregistrat: 17-February 03
Postat 03 September 2009 - 10:38 AM
O chestie haioasa
  • Fisier atasat  booth.jpg (42.6K)
Ala Bala Portocala ...
#585 Useril este offline   Calin
  • Postari: 2468
Postat 03 September 2009 - 10:52 AM
Vezi postareadan_mitea, la Aug 1 2009, 02:02 AM, a spus:
acum am vazut... fantastic!
uite si aici!
Las' ca ma fac eu mare...
Aceasta postare a fost editata de Calin: 03 September 2009 - 10:56 AM
#586 Useril este offline   Ahernar
  • Postari: 739
  • Inregistrat: 20-December 08
Postat 03 September 2009 - 11:10 AM
Asta ar duce la extinderea pietei de esc si brushless-uri din Romania !
http://en.wikipedia.org/wiki/File:Bundesar..._%22Do_X%22.jpg
Ma bate si pe mine gandul ca dupa ce trec la urmatorul model sa tai varfurile curbate ale EG-ului si sa-i mai adaug doua motoare .
Scopul ... 4 motoare se aud sublim !
#587 Useril este offline   Blue Raven
  • Postari: 742
  • Inregistrat: 07-August 05
Postat 10 September 2009 - 03:27 PM
Un avion deosebit pentru timpul lui a fost de asemeni Kyushu Shinden proiectat si executat de japonezi spre sfarsitul WWII.
http://tanks45.tripod.com/Jets45/Histories...den/Shinden.htm
Blue Raven
#588 Useril este offline   Dragos Avramescu
  • Postari: 528
  • Inregistrat: 01-August 08
Postat 10 September 2009 - 08:42 PM
Caproni Stipa:
http://www.seqair.co...ds/Legends.html
http://www.seqair.com/Hangar/Zuccoli/Legends/stipa4.jpg
#589 Useril este offline   renatoa
Postat 14 October 2009 - 08:10 AM
Coanda forever...
Iarasi unii care din criza (de idei) scot de la naftalina o farfurie zburatoare si o boteaza VTOPL UAV, bazata pe batranul efect Coanda:
http://www.gizmag.co...-vehicle/12813/
in timp ce asa ceva aproape identic se facea de acum 3 ani din depron:
http://jlnlabs.onlin...fsuav/index.htm
#590 Useril este offline   Rasputin
  • Postari: 64
  • Inregistrat: 26-October 08
Postat 14 October 2009 - 07:01 PM
Vezi postarearenatoa, la Oct 14 2009, 09:10 AM, a spus:
Coanda forever...
Adevarul e ca-s deosebite modelele in cauza , adevarul este ca autorii proiectelor au muncit mult la realizarea lor.Tot atat de adevarat este si faptul ,ca francezul a gasit de cuvinta sa specifice, din capul locului, ce principiu sta la baza creatiei sale .In fapt e vorba de recunoastere si bun simt .Acest ultim punct ,la vorbitorul de engleza,trece pe plan secund . In fapt , oameni si oameni, unii cu o doza mai mare ,sau mai mica, de bun simt .
#591 Useril este offline   docmarius
  • Postari: 398
  • Inregistrat: 05-July 08
Postat 14 October 2009 - 08:25 PM
Normal a principiul trece in plan secund, dat ca oamenii lucreaza pentru departamentul apararii si vor sa-si vanda produsul.
Daca vrei sa vinzi biscuiti nu incepi cu "sunt facuti din grau care este cultivat din cele mai vechi timpuri in mesopotamia, acea mirifica zona dintre Tigru si Eufrat". Zici in primul rand ca au 52 de dinti, ca-s aurii si buni si numai firma ta stie sa-i faca.
Ca veni vorba.... Cati dintre cei care folosesc cablul Bowden stiu cine a fost C.E.Bowden prin anii 30 si il citeaza la fiecare model cu asa ceva?
Sau l-a mentionat cineva pe H.J. Taplin, ca doar el a facut primul model electric? Sau nu ar trebui....
Aceasta postare a fost editata de docmarius: 14 October 2009 - 08:34 PM
West Hobby Team
Modele: Robbe Pitts S12, GL-450C, Pelikan X-treme, Ripmax Bossanova 15cc, Raptor 620SE
R/C: Futaba FF9C 35MHz/Jeti Duplex 2.4GHz, ESU ECoS II
#592 Useril este offline   Men
  • Postari: 634
  • Inregistrat: 05-May 03
Postat 14 October 2009 - 08:48 PM
Foarte interesant tot ce se vede pe aici dar as zice ca trebuie facute 2 subiecte separate, ca acu sunt cam de-a valma
1. AVIOANE deosebite (ca subiectul se chema modele deosebite, parca)
2. Piper (Prietenii stiu de ce, nu Caline?)
Ambele sunt interesante, dupa parerea mea, dar sunt 2 cafele diferite
Stima si consideratia
#593 Useril este offline   renatoa
Postat 14 October 2009 - 09:04 PM
Vezi postareadocmarius, la Oct 14 2009, 09:25 PM, a spus:
...Ca veni vorba.... Cati dintre cei care folosesc cablul Bowden stiu cine a fost C.E.Bowden prin anii 30 si il citeaza la fiecare model cu asa ceva?
Se pare ca exista dinaintea lui, si nu lui i se datoreaza numele, coincidenta, sau alt mit, pe langa cele doua inregistrate deja de wiki. http://en.wikipedia....n_cable#History
#594 Useril este offline   docmarius
  • Postari: 398
Postat 15 October 2009 - 09:58 AM
Ok...
Ce vroiam sa zic este ca daca vrei sa faci un jgheab pe care dau drumu la caramizi de pe casa nu trebuie sa incepi neaparat multumindu-i lui Newton ca a descoperit legea gravitatiei. Si nici la o masina nu se incepe cu fapul ca Otto a descoperit motorul pe benzina. Sau daca faci un avion nu incepi ca merge pe princpiul aripii inventate de Otto Lilienthal.
Coanda a descoperit efectul ce-i poarta numele (respect...) dar totusi e un fenomen natural. Si daca nu e pe primul rand in descrierea unui produs, ci pe al 5-lea, nu cred ca e nevoie sa declari ca e lipsa de respect.
Doar parerea mea...
West Hobby Team
#595 Useril este offline   Rasputin
  • Postari: 64
Postat 16 October 2009 - 07:45 PM
Colegu docmarius , laudabil efortul dvs. de a-mi explica cum sta treaba cu vanzarea .Acum sincer am avut o oarece strangere de inima ,sa postez s-au nu, cele de mai jos.
Eu cunosc o firma ce produce ventiloconvectori.Un model de ventiloconvectori al acestei firme, foloseste efectul Coanda.Ei bine, aceasta firma a gasit de cuvinta sa trambiteze acest aspect . Adevarul e ca aceasta firma e " vorbitoare "de limba franceza.Deci ori frantuzii astia au mai mult bun simt decat altii (asa cum am spus eu), ori astia nu stiu sa vanda ( asa cum ati spus dvs.). In fapt, asta nu esplica in nici un fel , cele postate de mine.Pentru a nu lasa loc de dubii si interpretari , tin sa precizez ca ,eu ca roman , nu sunt dispus sa trec cu vederea astfel de scapari de la vorbitorii de engleza .De asemeni nu sunt dispus sa accept drept noutate un model al carui principiu nu este nou ,si pe deasupra mai seamana izbitor cu un model realizat in urma cu trei ani.
In rest , legat de biscuiti si departamentul apararii, imi permit o sugestie : Corelati nr. dintilor cu nr stelelor de pe drapelul departamentului in cauza, si cine stie ..., poate cresc sansele de vanzare .
PS. La chestia din urma.... , va rog sa nu o puneti la suflet. In fapt se vrea o gluma , mai mult s-au mai putin sarata.
#596 Useril este offline   docmarius
  • Postari: 398
Postat 17 October 2009 - 09:13 AM
Acesta masina de pe care se trimite mesajul se bazeaza pe conceptul lui Alan Turing.
Arhitectura dupa IBM. Browserul se bazeaza pe Mosaic.
Si acum mesajul:
Ok. Fiecare cu parerea lui.
Legat de biscuiti, cei cu reclama cu 52 de dinti sunt de la firma Leibnitz, sunt nemti si nu au legatura cu stelele. Doar ca exemplu. :rolleyes:
O zi buna.
PS: Ca sa respectam pe cat mai multi: elicopterele din semnatura sunt relizate dupa conceptul lui Sikorski. Iar carburatorul de pe motorul termic dupa Otto functioneaza pe principiul lui Bernoulli.
Aceasta postare a fost editata de docmarius: 17 October 2009 - 09:20 AM
West Hobby Team
#597 Useril este offline   renatoa
Postat 17 October 2009 - 09:34 AM
Vad ca ati luat-o razna rau...
Pe langa faptul ca AESIR este firma engleza si nu americana, si este privata si nu lucreaza pentru departamentul apararii, nu stiu de unde ati scos pe asta cu englezul si francezul. Folosirea efectului Coanda este subliniata peste tot pe site-ul firmei (in 5 pagini), inclusiv in locuri unde nu era cazul, cum ar fi la "Despre noi": http://www.aesir-uas.com/aboutus.htm
Sau poate ca asta arata cu atat mai mult respectul pe care i-l poarta pentru aceasta descoperire...
Cat despre francezi, poate ar fi bine sa traiesti putin in mijlocul lor sa descoperi cat de nationalisti pot fi... daca subliniaza acolo ca este vorba de efectul Coanda, este deoarece era in trecere pe la ei cand l-a descoperit, si nu m-ar mira sa aflu ca autorul nu stia ca de fapt Coanda nu ar fi francez...
Hai sa revenim la modele deosebite.
#598 Useril este offline   lefmir
  • Chupacabra
  • Postari: 724
  Postat 17 October 2009 - 10:01 AM
Vezi postarearenatoa, la Oct 17 2009, 10:34 AM, a spus:
Intrasem zilele trecute pe site-ul great planes sa vad ce mai au nou...si vad mare pe prima pagina Shoestring :D .
http://www.greatplanes.com/airplanes/gpma1328-main-lg.jpg
Am gasit planul...e pentru unul de 860mm, dar merge marit, l-as face de 1100-1200mm.
#599 Useril este offline   lefmir
  • Chupacabra
  • Postari: 724
Postat 17 October 2009 - 10:12 AM
am uitat planul :D
http://i853.photobucket.com/albums/ab99/lefmir/Shoestring.gif?t=1255767106
#600 Useril este offline   docmarius
  • Postari: 398
Postat 17 October 2009 - 08:51 PM
@renatoa: ai dreptate.
Ca sa revin on-topic...
Tot nu pot crede ce urat arata Caproni Stipa asta. Merita incercat de facut model :blink:
Mai ales ca exista si planurile pe site-ul mentionat.
Aceasta postare a fost editata de docmarius: 17 October 2009 - 08:55 PM
West Hobby Team
  • 24 Pagini +
  • 18
  • 19
  • 20
  • 21
  • 22
22 useri citesc topicul
