Modelism - RHC Forum: EXTRA 300 50 cmc - PILOT RC - Modelism - RHC Forum
#61 Useril este offline   old-boy
  • Postari: 887
  • Inregistrat: 13-June 03
Postat 04 May 2011 - 06:49 PM
O surpriza de la
http://www.carf-mode...extra330sc.html
#62 Useril este offline   florin100%
  • Postari: 2685
  • Inregistrat: 20-June 06
Postat 04 May 2011 - 07:14 PM
flumos, frumos, dar 3m la CARF te rupe la buzunar :lol:
Team Aeropower
#63 Useril este offline   REAL DESIGN
Postat 05 May 2011 - 03:12 PM
In asteptarea unor zile mai frumoase :
#64 Useril este offline   Teo-Costin
  • T.C.I.
  • Postari: 1399
  • Inregistrat: 13-June 07
Postat 05 May 2011 - 03:50 PM
Mie imi place suportul avioanelor :good:
#65 Useril este offline   REAL DESIGN
Postat 05 May 2011 - 05:43 PM
Vezi postareaTeo-Costin, la 05 May 2011 - 03:50 PM, a spus:
mmm...da !
Mi-a zis mie un coleg de forum acum cati-va ani : " ..... stii ce patesc rotile daca sta modelul mult pe ele cand este " parcat " ? "
Si am aflat .... in primavara urmatoare ... capata colturi !
suportul este Rococo combinat cu stilul Florentin ( Petre ) ! - executam la .... comanda ..... 2 beri la baiatu va rog !
Aceasta postare a fost editata de REAL DESIGN: 05 May 2011 - 05:44 PM
#66 Useril este offline   REAL DESIGN
Postat 06 May 2011 - 04:30 PM
Astazi am avut de ales doua grupe de setari pentru cursele suprafetelor de control si anume :
1 - Varianta propusa de Pilot Rc si anume :
Eleron 15 grade ( low rate ) : 30 grade ( hight rate ) EXPO - 40 : 70
Directie 30 grade ( low rate ) : 45 grade ( hight rate ) EXPO - 40 : 70
Profundor 15 grade ( low rate ) : 40 grade ( hight rate ) EXPO - 40 : 70
2 - Varianta din manualul Sukhoi Sebart ( 2,2 m ):
Eleron 20 grade ( low rate ) : 45 grade ( hight rate ) EXPO - 40 : 80
Directie 30 grade ( low rate ) : 50 grade ( hight rate ) EXPO - 30 : 60
Profundor 20 grade ( low rate ) : 50 grade ( hight rate ) EXPO - 25 : 80
3 - Varianta din manual EXTRA Extreme Flight ( 2,2 m )
Eleron 20 grade ( low rate ) : EXPO - 18-20 Height se face dupa " gust "
Directie 20 grade ( low rate ) : EXPO - 40-50 Height se face dupa " gust "
Profundor 8-10 grade ( low rate ): EXPO - 18-20 Height se face dupa " gust "
Am mers pe varianta 2 ( Sebart ) desi am temerea ca profundorul este pe Low cam agresiv cu 20 grade si doar 25 % Expo si la aterizare este posibil sa " valureasca " daca nu este actionat extrem de fin asa ca am sa mai maresc EXPO la 35-40 %.
Daca are cineva alta propunere pentru maiden astept cu interes.
Si ceva poze asamblat dupa verificare C.G. ( buna elicea aia mai grea caci m-a scutit cam de 100 - 150 grame plumb )
Nu am reusit sa il cantaresc decat pe bucati dar apar ceva abateri din rotunjiri - 8,5 Kg ( fara gaz )
#67 Useril este offline   SILVIU66
  • Postari: 6866
Postat 06 May 2011 - 05:22 PM
Eleron - Sebart
Profundor - Pilot RC
Directie - Pilot RC
Expo intre 60-80 la primul zbor.
#68 Useril este offline   REAL DESIGN
Postat 06 May 2011 - 05:58 PM
Vezi postareaSILVIU66, la 06 May 2011 - 05:22 PM, a spus:
Eleron - Sebart
Directie - Pilot RC
Multumesc frumos ! ... mi s-a parut mie ca se cam agita profundorul cu setarea Sebart pe low rate.
#69 Useril este offline   Maverick
  • Postari: 719
  • Inregistrat: 10-October 08
Postat 20 July 2013 - 04:51 PM
RD, nu stiam ca ai fost la Joe Nall in 2012
http://youtu.be/BB2CtHZFXFA?t=21m43s
#70 Useril este offline   REAL DESIGN
Postat 20 July 2013 - 05:33 PM
Vezi postareaMaverick, la 20 July 2013 - 04:51 PM, a spus:
Ha ! Ha ! A aluia nu are conul ca a mea cu stelute precum modelul 1:1 , papucii sunt vopsiti gresit, nu are inscrisurile si nici inmatricularea corecta una peste alta nu e asa misto ! E naspa si urata ! Si nici io "nu" as vrea sa merg acolo ca sunt avioane numai din spuma d'alea mici de la Artech .. urate !
39 useri citesc topicul
0 membri, 39 vizitatori, 0 utilizatori anonimi
